Spring clips on dumbbells? - AcuraZine - Acura Enthusiast Community
LinkBack Thread Tools
Old 01-30-2008, 11:02 AM   #1
Someone stole "My Garage"
curls's Avatar
Hey guys.
I bought a set of used weights and bars, but they have the stupid collars on the dumbbells that require the little tool. Pain in the arse to change weight frequently.
I was thinking of getting some of the spring clips (standard 1" bar, not olympic). Are these spring clips REALLY secure? IE: If I buy 4 of them (2 per dumbbell), will I have a weight drop off of the dumbbell bar and onto my head?
The bars aren't threaded so spinlock won't work obviously.
Thanks.
Eric
These are the kind I'm talking about:
curls is offline   Reply With Quote
Old 01-30-2008, 11:13 AM   #2
Registered Member
cibs's Avatar
spring clips are secure i've used them for huge amounts of weight and never had them fail me... how much weight are you going to use on a dumbbell bar anyways?
they have some new clips out now that they have at my gym that are absolutely fantastic I'll see if I can find some pics, way faster than spring clips and apparently more secure too
cibs is offline   Reply With Quote
Old 01-30-2008, 11:17 AM   #3
Registered Member
cibs's Avatar
something like this... I found 'em in 1" sizes too
http://www.amazon.com/Regular-Style-...709805&sr=1-34
Old 01-30-2008, 09:12 PM   #4
curls's Avatar
$54/pair vs $3.25/pair. I'll go with the regular spring clamps if they're strong enough, which it sounds like they are.
Not a lot of weight per dumbbell... it's just that I am used to the fixed-weight dumbbells from the gym but now with the basement dumbbell/barbell set I got, the complete set of fixed weight dumbbells aren't an option. Neither is the bowflex select-a-weight set, either. $$$$.
Old 01-31-2008, 08:29 AM   #5
Registered Member
cibs's Avatar
i'm sure the regulars will work good enough... wow my bad I didn't notice the price at all, I'm sure it can be had for cheaper than $54, but I doubt cheaper than $3.25
Old 02-01-2008, 11:57 PM   #6
giggity giggity giggity
HQuakers's Avatar
I would say you can use regular spring clamps. I have also used quite a bit of weight with them doing deadlifts with no problems at all. Make sure you just get some quality ones and not some thin, crappy springs.
HQuakers is offline   Reply With Quote
Old 02-02-2008, 11:34 PM   #7
curls's Avatar
Quote:
Deadlifts are one thing -- the bar is horizontal. That means almost no force on the clips... however with the dumbbells, the bar at times can be vertical. Will the spring clips slide and cause the weights to fall on my head?
Old 02-03-2008, 11:53 AM   #8
HQuakers's Avatar
Quote:
I actually just thought of that, but if you get the good ones then you shouldn't have a problem. Hell, sometimes I have trouble getting those suckers on, so I cannot imagine what kind of forces it would take to get them off of dumbbells.
Thread Thread Starter Forum Replies Last Post
FS: 2003 Acura CL-S 6MT ABP ★★Location of Vehicle : Edmonton, AB, Canada★★ rp_guy Member Cars for Sale 7 09-17-2016 06:42 PM
Some details and info about KW V1 Damper kits MrHeeltoe 1G TSX Tires, Wheels, & Suspension 2 09-30-2015 03:06 AM
KW Suspension Pics and Product Feature MrHeeltoe 2G TSX Tires, Wheels & Suspension 3 09-29-2015 11:43 PM
Product Highlight: KW Variant 1 Dampers MrHeeltoe 3G TL Tires, Wheels & Suspension 0 09-28-2015 06:43 PM
Tags
2, bar, clip, clips, dumbbell, dumbbells, dumbell, good, spring, sprng, stay, threaded, weigh, weight, weights
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
