2G CL Frequently Asked Questions No New Threads Please.
CLS Front Bumper Removal DIY
Old 09-21-2006, 08:13 PM
fuzzy02CLS's Avatar
Step 1
Open hood. You will see the black plastic cover around the top of the bumper
There are 8 clips you need to remove on this cover.
Once removed you can pull the black plastic cover off
Step 2
You will see 3 phillips head screws. These can be hard to remove without stripping them. I used an impact screwdriver & that broke them loose.
Step 3
There’s a screw at the corner of the bumper at the wheel well.
Remove this. You may need to move the wheels left or right to get the screw out. Repeat for the other side. Blurry I know but you can see it.
Step 4
There’s a 10mm bolt under the back edge of the bumper near the wheel well. Remove this, & repeat on the other side.
Step 5
There are 4 clips along the underside of the bumper. Remove these
Step 6
Pull the sides of the bumper out, & push down & pull the entire bumper. It should slide off. I had to finesse the bumper off. It was stuck on there
Reverse to install.
I never removed my bumper before & it took me about 10 minutes. So anyone can do it if they need to. There’s not much involved as you can see.
To get the clips off use a flathead screwdriver.
If you break a clip or 2 it’s not a big deal. Acura dealers should stock the parts, & they are less then $1.
When putting the bumper back on, the sides may be tricky to get in. They were for me. And BE CARFULL not to scratch the bumper, or nick it, or drop it.
NOTE: If you have stock road lamps you will have to remove them. The 03 has inserts & do not need to be removed.
Old 09-21-2006, 08:16 PM
Moderator Alumnus
BigLizard's Avatar
Your links to your pics aren't showing.
Old 09-21-2006, 08:19 PM
fuzzy02CLS's Avatar
I see them?
Old 09-21-2006, 08:23 PM
'08 MX5 GT 6spd.
MarbleGT's Avatar
Received 1,192 Likes on 485 Posts
you just made treyster very happy!
Old 09-21-2006, 08:28 PM
fuzzy02CLS's Avatar
So the pics are working?
Old 09-21-2006, 08:35 PM
Uses turn signals in my
TCM 01 CL-S's Avatar
I see the pixs fine. Thanks for the great DIY, I may be putting it to use in the near future.
Clips are around $1 (@ my local honda) for those who break them (like me).
Damn pop-screws.
Old 09-21-2006, 09:25 PM
VinceBlkCLS's Avatar
Great DIY man that should really help out a lot of new members on the site if they ask are you going to put that in the DIY thread?
Old 09-21-2006, 09:35 PM
Moderator Alumnus
BigLizard's Avatar
My bad...I don't see them cuz I'm at work and there is a site blocker on the network...I'll see them when I get home
Old 09-22-2006, 02:36 AM
Cosmic Cowboy
g1underground's Avatar
Thanks....I needed this one
Old 09-22-2006, 09:20 AM
A clean ride is in
treyster's Avatar
Fuzzy!! It's funny that you posted this last night. By the time you posted, I had already taken off the bumper and put it back on. I used Soopa's instructions from '02. I was trying to switch out my '01 for '03 headlights and hit a snag and ran out of daylight. By the time I finally get them installed, I'll be a pro at bumper removal.
Old 09-22-2006, 10:40 AM
Moderator Alumnus
BigLizard's Avatar
fuzzy-I see the pics just fine...it WAS the damn site blocker. Good DIY by the way!
Old 09-23-2006, 06:56 PM
Missing My CL-S
SG81's Avatar
thanks fuzzy . i've got to take mine off soon for the first time
Old 09-25-2006, 09:09 PM
fuzzy02CLS's Avatar
Can this be moved to the info thread?
Old 09-25-2006, 09:50 PM
Moderator Alumnus
BigLizard's Avatar
Already done
Old 09-26-2006, 08:05 AM
GreenMonster's Avatar
It's scheduled to be added as soon as one of the mods (probably me) does the next round of updates. We've got a lot of stuff that needs to be added (see the "know it all" sticky for details)..
Moving this to the FAQ forum...
Old 06-09-2007, 02:29 AM
eh
implicit's Avatar
Great post - Thanks - this was exactly what I needed.
I just finished replacing a balast control so of course I had to take the bumper off.
A few comments for anyone else considering taking the bumper off themselves:
Total work time for me was about 2 hours but I went pretty slow and I don't do this type of stuff very often.
I didn't need any power tools, the three tough screws on the top of the bumper were tight but I had no problems with a descent philips head screwdriver.
The bumper takes a bit of work coming off and going on so you might want plan on a little extra time unless you're experienced at taking off body panels.
The whole process isn't technically difficult at all ... and for anyone that's curious....once the bumper is off swapping the balast was easy (10-15 minutes if you're slow)
Old 06-09-2007, 12:42 PM
m733l's Avatar
can any one tell me the part number for the screw in step 4 and the clips in step 5.
i tried to look for them but came up empty. thanks
Old 06-09-2007, 05:56 PM
03BungeCL-S's Avatar
Great DIY...i just bought a new stock bumper for my 03 CL-s...This will save me lots of money and time. THanks man.!
Old 05-05-2008, 12:39 PM
Chamorro
dave586270's Avatar
This is what I needed! Took me a half hour to find someone who would post pics with this. Everyone just explains it but doesn't show the pics.
Old 09-13-2008, 07:56 PM
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,775 Likes on 1,234 Posts
Thanks for the great write up. I will be r&r'ing my headlights next week so I will be using this info.
Thanks!
Old 03-26-2014, 09:21 PM
1TrUTypeS's Avatar
Yo, I'm trying to buy a stock front bumper, where did you get yours from and what accesories did you have to get along with the bumper its self?
Old 04-15-2014, 12:07 PM
I Wanna Beer
TheWeez's Avatar
Any chance of hosting the pictures again? Seems photohost.org no longer exists.
Old 04-01-2015, 01:29 AM
CL smashin
Outlaw's Avatar
Pictures no longer showing. Check out the thread below for bumper removal with working pictures:
D.I.Y. - Clearing Headlights!
https://acurazine.com/forums/frequen...lights-495390/
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
leerbgdup
09-06-2015 11:01 PM
Sixers12
ILX
09-06-2015 07:54 PM
robowarrio
09-01-2015 09:25 PM
Quick Reply: CLS Front Bumper Removal DIY
