Sponsored by: DashLynx
Trip meter resets itself
Old 07-25-2012, 11:12 AM
MyBlackBeauty's Avatar
So I have been having this issue with my car since day one. I have set my trip meter to reset to zero when I fill the tank. I like to see how many kms I get out of a tank. The problem is, the trip meter automatically resets to zero once the tank is 3/4, so I never get to see how many kms I would get in a tank using trip meter A, trip meter B however works fine and that's what I use for my calculations.
Anyone with the same issue?
Old 07-25-2012, 11:45 AM
Pete2010's Avatar
That is by design - I believe you can change that setting in the menu options (when the car in in park).
Alternatively - you can check your km/gallon before you fill up.
Old 07-25-2012, 11:59 AM
I took the car to the dealership and explained and they never said it was by design. They kept the car for the entire day and later said they couldn't figure it out and will talk to Honda about the issue and I haven't heard back from them in 6 months. That's how efficient, Acura 2000 in Brampton is.
Old 07-25-2012, 12:18 PM
sojue's Avatar
This happened to me too once. Under personal setting menu, I set to reset Trip A every time I refuel the gas. However, the trip A reset itself even though I did not fill the gas. So I just disabled that feature and I just mannually reset it once I fill the gas.
Go to your setting and disable that feature. I think yours is set to reset the trip A when you fill up the gas.
Old 07-25-2012, 12:23 PM
I know that option is ON and I want it that way and it should work fine and if it doesn't, they should fix it. Why should I try to find work arounds? It's not a cheap car!
Old 07-25-2012, 12:56 PM
Mr Marco's Avatar
Eh-um, Use trip "B" dude.
Old 07-25-2012, 04:56 PM
I am, DUDE! but I wanted to know if others have noticed the same issue.
Old 07-25-2012, 06:21 PM
sojue's Avatar
You are absolutely correct!
Old 07-25-2012, 06:27 PM
KPSBUDS420's Avatar
I have different issues with my car, but feel the same dude... Give em hell! Why should I have to listen to a spooling whine from 15-50mph ( which is 90% of my driving) when other tl's don't make that noise. Just cause they can't pinpoint it don't mean squat.. Fix my 40k NEW car.
Old 07-25-2012, 06:41 PM
Exactly!!!
Old 07-25-2012, 06:45 PM
Hogan9166's Avatar
I have seen the same issue with the auto reset but, not at the same intervals.
Old 07-25-2012, 07:04 PM
BLEXV6's Avatar
Mine does this periodically for no particular reason.
Old 07-25-2012, 07:06 PM
Did you contact Acura? What did they say?
Old 07-25-2012, 10:47 PM
wrek94's Avatar
Mine was doing something similar.
https://acurazine.com/forums/4g-tl-problems-fixes-297/trip-odometer-avg-mileage-ipod-automatically-resetting-858244/
Old 07-25-2012, 10:50 PM
8th Gear
mdxsilversurfer's Avatar
Could it be that you are pressing the fuel cap button instead of the trunk release at one point? This would cause your trip meter to reset.
Old 07-26-2012, 08:34 AM
No, because I have seen it happen while driving.
Old 07-26-2012, 08:47 AM
Hogan9166's Avatar
So, it just happened to me again this morning. As I said above, it doesn't happen at consistent gas levels, but what I have noticed may be a coincidence, but it is a little odd if it is.
It has happened to me 4 times now. Three times, including this morning, it happened at a gas station where I fill up about 80% of the time, but I had just gone into the store for something and didn't gas up. The other time it happened was when I went into the store of a gas station that I had filled up at several times the weeks prior to that.
I know this is an odd question, but it isn't tied to the GPS location somehow, is it?
It has never reset while driving, but always after shutting the car off and restarting at a gas station where I have filled up several times previously.
Weird.
Old 07-26-2012, 08:56 AM
Mr Marco's Avatar
Good man/dude.
Hanger bearing issue.
Old 07-26-2012, 09:50 AM
Can't be that because it happened to me while driving.
Weird.
Old 07-26-2012, 09:54 AM
Hogan9166's Avatar
Could be separate issues.
Old 01-23-2019, 08:08 PM
Nev05's Avatar
Sorry for the thread revival, but I am having the same problem. Trip A is set to reset when I fuel, and it does, but then it resets itself again before I even fuel the next time. Most of the time I'm just fueling up half tank. Anyone found a fix for this yet? Is there even a fix at all ?
Old 01-24-2019, 06:26 PM
sockpuppet's Avatar
Best I can figure is that the system resets based on pressure change within the tank, such as when you remove the cap to fuel up. Perhaps that's not how it works, but that's the only way I see it, and I'm the smartest guy I know. If I'm correct, the problem might be an issue with your gas cap, where pressure is being released in between refueling. Perhaps try a new cap?
Old 01-25-2019, 12:06 PM
dregsfan's Avatar
I have trip A set to reset when refueling. It will do that whether or not I actually fill the tank. AFAIK this is normal. Refueling != filling up. Note that it doesn't actually reset until the car moves after fueling.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
brboy
10-05-2015 11:34 AM
Skirmich
10-01-2015 12:59 PM
Froid
09-27-2015 06:16 PM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: Trip meter resets itself
