Sponsored by: DashLynx
Exhaust tips for 2012 Acura TL SH-AWD
Old 03-14-2012, 06:48 PM
Recall's Avatar
I was wondering if these exhaust tips would fit the 2012 Acura TL SH-AWD. Please for your help with this.
http://www.ebay.ca/itm/NEW-POLISHED-...item4841602721
It is Prozone exhaust 3.5in outer dia tips.
http://www.magnadirect.ca/product/35167
This is Magnaflow exhaust 3in outer dia tips
Old 03-14-2012, 08:21 PM
potmilkz's Avatar
Received 1,020 Likes on 792 Posts
3.5 tips would work better.. i have 3 inch tips and they look small
Old 03-15-2012, 04:50 AM
KarKraze's Avatar
You will need to get staggered tips unless you plan on modding the straight one's you are looking at ,check out Corsa clones they range from 3" - 4" with various inlets and are already staggered.
Old 03-15-2012, 06:25 PM
Recall's Avatar
Hi KarKraze, the staggered tips is it the ones that are turned up slightly at the tips, I was thinking to get straight tips. Thanks for your suggestion though. The inlet of the exhaust tips is that the part that has to be weld on?
Old 03-15-2012, 06:53 PM
potmilkz's Avatar
recall
this is staggered tips..
one tip sticks out more than the other.
this is straight tip, where they are exactly the same lenght.
Old 03-15-2012, 08:10 PM
KarKraze's Avatar
^^^^ Potmilkz has explained what staggered tips are,and yes the inlet is the part that is welded/clamped on,if you look at the original tip you will notice that one has a slight offset than the other,if you use tips that are equal length it will not flow well with the back bumper/skirt .
Recall's Avatar
Thanks, potmilkz, I wonder which one would look better on the car though, any suggestion is more than welcome.
regard
karkraze, yes I notice that the original tips are staggered. The CT engineering muffler and the ATLP muffler tips are they staggered? these looks good on the car.
Old 03-15-2012, 08:45 PM
KarKraze's Avatar
Yes they are as well as the xlr8 system,ct engineering tips seem a little too small for the Tl imo but will be the mildest sounding of the aftermarket systems available for our cars.
Old 03-15-2012, 08:55 PM
Recall's Avatar
I did some more research and came upon these. I think they should look good they are 3.5in outlet, 4in outlet might be too big. http://solo-performance.com/exhaust-...um?tip=T601-3R
Old 03-16-2012, 10:51 AM
potmilkz's Avatar
those look good but not for that price.. its about 120 a side..
Old 03-18-2012, 08:50 AM
6th Gear
Jullia's Avatar
dual look very cool
Old 03-18-2012, 09:11 AM
The Sicilian
jspagna1's Avatar
The bigger diameter looks better because of the openings and you should definitely go with the staggered ones so you follow the contour of the body. Shop around and go to a custom exhaust shop and have them do it just the way you want it. Right!!!!
Old 03-19-2014, 09:48 PM
2013 Acura TL Tech
Vi3tguy2000's Avatar
Are these dual tips exhaust to be weld onto the original exhaust system? Just changing out the tips right?
Old 03-20-2014, 07:11 AM
was thinking about swapping out my tips as well...what is the inlet size we need? thx in advance
Old 06-29-2015, 11:33 PM
fryrice's Avatar
Hey guys,
Just picked up a certified tl awd advance package really excited about the car. I notice the 2011 and below had the quad looking exhaust tips do u guys think those are cheaper than these ones?
Old 02-27-2017, 06:37 PM
toferdisobey
Christopher Michael's Avatar
Does anyone know if the exhaust size of 2.25" in is the same for the base TL? I'm looking for tips. I know most are saying go with 3.5 or 4" out but I want to confirm the in. Also I suppose staggered is the way to go, but what about angle cut? Any webshop purchase links would be much appreciated
Old 02-28-2017, 02:43 PM
joemcfarnham's Avatar
I just ordered 2.5" in 4" out staggered. The length is key. If your running stock mufflers anything longer than 9.5" will look silly. To answer your question however I believe its 2.25" out, but a shop will make it work.
Old 02-28-2017, 02:51 PM
toferdisobey
Thanks man for your reply. I'm doing it myself, have a full garage so I just wanted to use stock mufflers for now and get something that fits direct, seems to be hard to find staggered tips :/
Old 02-28-2017, 03:23 PM
lltfly's Avatar
NEW POLISHED EXHAUST TIP PONTIAC GRAND PRIX DUAL CAR
Welcome magnadirect.ca - Hostmonster.com
Hi, be careful of length of tip. I was looking around. and also installed a bad one. now I am using the one below. it is perfect fit and slant which can fit the rear bumper.
PAIR OF TWO COLT STAINLESS STEEL UNIVERSAL DUAL EXHAUST TIPS 4"
Old 02-28-2017, 03:24 PM
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=262851511563&cat egory=33633&pm=1&ds=0&t=1488316926063
Thats what i ordered, they'll need to be welded on however.
Old 02-28-2017, 03:25 PM
lltfly's Avatar
Hi, 2.25 inlet.
I am runing on this one below.
PAIR OF TWO COLT STAINLESS STEEL UNIVERSAL DUAL EXHAUST TIPS 4" | eBay
Soal Man (03-01-2017)
Old 02-28-2017, 03:28 PM
toferdisobey
Originally Posted by lltfly
Hi, 2.25 inlet.
PAIR OF TWO COLT STAINLESS STEEL UNIVERSAL DUAL EXHAUST TIPS 4" eBay
Perfect. Thanks for that info!
Old 02-28-2017, 03:48 PM
lltfly's Avatar
No problem.
I think this is the best one I could find. as mentioned by members, the tip should have the different length on offset, then it can fit the bumper. this one is also good quality as I feel. when you install just ask to cut a little bit on inlet and do not make it parallel. because when you stand behind your car. you are looking at the rear with angle. say 2016 WRX, stock dual tips, looks too low. so remember to ask them to make it tilt up a little bit when welding
BTW I am not the seller~~~~
Old 03-07-2017, 10:49 AM
I'm lost, I brought a pair of Magnaflow 11225 mufflers and these tips Dual 4" Quad Staggered Stainless Steel Exhaust Tips Fits Acura TL 2004-2014 | eBay to get welded in at a local muffler shop.
They informed me that the muffler is an inch too long and the tips wouldnt be doable without sticking out too far even on the stock mufflers (the tips are 9.5" long at the longest part, they're staggered). How have others made out with these mufflers?
most seem to use STAINLESS STEEL DUAL EXHAUST TIPS 4.0 2.5 ACURA 04-08 TLS . 09-11 TL . 12-14 TL | eBay which from what I can tell are even longer?
Old 03-07-2017, 11:53 AM
6th Gear
ua7_dav's Avatar
i think 3.5 or 4" tips would be perfect! they look nice, and their fat as f*** which is what i like .... looks extra mean
Old 03-07-2017, 04:24 PM
toferdisobey
I'm lost, I brought a pair of Magnaflow 11225 mufflers and these tips Dual 4" Quad Staggered Stainless Steel Exhaust Tips Fits Acura TL 2004-2014 eBay to get welded in at a local muffler shop.
most seem to use STAINLESS STEEL DUAL EXHAUST TIPS 4.0 2.5 ACURA 04-08 TLS . 09-11 TL . 12-14 TL eBay which from what I can tell are even longer?
Check out this page. I think you should look at another shop besides eBay for the tips but also you should ask another shop for a second opinion on install. It sounds like they don't know what they're doing...
Old 03-07-2017, 09:57 PM
LostProphet's Avatar
I got this tips from Amazon
https://www.amazon.com/gp/product/B00W572U0Y/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00W572U0Y/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
and got them installed with Magnaflow 11225 with no problems, this was 4 weeks ago. I agree on the suggestion of going to a different shop.
Old 03-09-2017, 02:43 AM
How far out do your tips sit past your bumper? Can u upload a pic,he explained that the bend was too tight to use the mufflers and not have the tips sticking out several inches.
Old 03-13-2017, 02:58 PM
Soal Man's Avatar
A pro exhaust shop can modify however you want it to your liking. The inner part of the tip was perfectly aligned with the lower rear of my bumper(half inch pass give or take) and the outer tip aligned with the right corner of my rear lip kit. Idk if you can see it from this angle but gives you an idea of how it flows with the car. Excuse the dirty pipes this was taken awhile back. Hope this helps.
ssjkev16
03-08-2020 08:17 PM
ExcelerateRep
12-11-2015 12:58 PM
IIDXholic
10-08-2015 07:53 AM
Nitin
09-30-2015 08:22 PM
PAK74
09-03-2015 09:02 PM
Quick Reply: Exhaust tips for 2012 Acura TL SH-AWD
