Better Headlights than OE?
I got a slight annoyance with the stock headlight bulbs on the daytime running lights. They're too yellow! I'm looking for a nice set that are clean & clear white. Nothing too blinding though, as i don't want the attention. Here's what's mine look like now.
Yellow bulbs
Yellow reflection
Yellow bulbs
Yellow reflection
Get some LEDs to drop in and call it a day.
I like that idea. Would you recommend the bulb replacement or the LED strip? Also has anybody had experience with the halogen strip?
https://acurazine.com/forums/fourth-generation-tl-2009-2014-123/jlc-lighting-drl-led-module-09-12-tl-831247/
are you up for the task of modifying your headlight to install a strip? Just do the bulb for plug and play functionality. get some relays, get some LEDs and load resistors and have fun
Found this thread but the pics don't work.
https://acurazine.com/forums/fourth-...n-drls-827442/
Curious what the look of this would be. Obviously not as bright as LED's or as clean looking, but it also is not an attention grabber for cops. Easier installation than LED's I would imagine.
Also be careful replacing the DRL's with LED's. The DRL is also the headlight high-beam, so if you go with a dedicated LED for the DRL you lose the focus/distance of the high beam. If you really want a whiter look, go with a brighter halogen bulb (like silverstar, etc), but be aware they will burn out faster than a normal bulb. but will have a brighter/whiter appearance....
Thanks for the advice, this is what I'm going after. Something that looks cleaner than the yellow but doesn't grab too much attention. I'll post what i do here once it's installed. I was thinking led but didn't realize it could burn out faster than a halogen and didn't know that it would affect the high beam performance.
andy
This is correct. In my experience the Silverstars will last about a year before one of them goes out. I have heard the PIAA's last a little longer, but they are a little more expensive as well.
Keeping TL until 2029
I had a chat with a retrofit rep...
H-Series Morimoto XB LED Bulbs - Automotive LED Signal Bulbs - The Retrofit Source
Make sure to get right bulb. The drl/hi-beam is 9005. That will be next upgrade.
So after digging deeper in acurazine search I see this question comes up alot! My first post so i apologize for being noob here. Anyways I'm partial to this kit found on amazon from kensun. Does anyone have experience with their stuff. I've read some bad reviews about the Nokya arctic white stage 1 camp and i was leaning towards that. I don't want to be under powered/luminated but i don't use the high beams much either so i don't know if that makes a difference.
I got a halogen silverstar axe that says they are the white halogens. Bottom line is halogens are more then likely to be yellow or a light yellow. I am going retrofit source because everyone that has a 2012 TL has these on their fog lights....
https://acurazine.com/forums/fourth-...type-s-915221/
The following 2 users liked this post by thisaznboi88:
echodigital (09-29-2015),
hashbrown (09-28-2015)
If you don't want the attention, just pull the DRL fuse. Your high beams will still function as normal, and you won't have to deal with piss yellow headlights
I am going to seriously consider some halogen rings since they do enhance the view on my 12' enclave.
hashbrown (09-29-2015)
How long have they lasted?
I just put them on...maybe 9 months. It is the ZXE version. No issue so far but still yellow. I am going to google Noyka white...
I think I may go LED cause I know it will be white for sure.
I can't find the answer here so i have to ask. Say you were to put LED's w/ resistor harness for your drl's and lose the high beam function. Does anything happen when you manually flicker the high beams or leave them on? Does the display say they're on but no change in actual brightness? I'm thinking about 5000k brightness for drl and doing the fog lights over to white led too. No resistor harness needed for for LED fog lights?
How you get better weather to enjoy that project. What did you go with? I bought a pair of Phillips Crystal Vision for now. Waiting for them to get delivered. Researching replacing alot of the stock bulbs to led now. The bright "white light" obsession bug for my TL has me deeper in the rabbit hole. I want to do either a 6 or 9 strip led mount near the fog lights, change the tail lights and trunk to led. I'd also like to do an led switchback for the turn signals but don't want to take apart the housing to remove the orange reflectors.
Be careful when you take those outta the package as they are a little snug in the plastic. Also wear gloves or use a napkin so you don't ever actually touch the bulb directly. This will help it last longer. My dad had these on his Subaru for awhile and they looked nice.
I haven't decided what I'm going with yet. Most likely silverstars or the zxe version. I just want something that looks a little cleaner and less yellow as I think the stock DRL's really take away from the cars looks. But who knows...ill prolly catch the bug as well and update to all led next month hah
The passenger side is the Phillips crystal vision.
In pictures they look more like the stock Sylvania on the driver's side. I don't know, i like it and it's brighter than what was in there. But i think I'm going to do the 6 or 9 strip led's and mount on bottom and use that as drl's. I'll keep these for brights.
DRL light
I did the same and I got a DRL check.
Get the right bulbs. Its too much bullshyt to keep replacing to find out.
I just ordered replacements for the low and high/driving bulbs.
I ordered some Hipro Power 9005 + 9006 5900k 100 Watt Super White Xenon HID Headlight Bulbs - Low/High Beam.
I still have the bulbs in but i pulled the drl fuse for now. Just did my 30k service and this is project is on the to-do list(looking at rear sway bar). From research there are some really cool ways to get a fresh look for lighting.
I like the accord led strip that you feed through the turn signal inlet. But i don't think it would work in a TL.
http://store.ijdmtoy.com/Honda-Accord-Install-LED-Running-Lights-a/573.htm
And then there's the 4-9strip add-on to the lower front end.
http://www.myhellalights.com/index.php/products/daytime-running-lights/universal-daytime-running-lights/
DRL is usually at 6V versus hi beams at 12V. You may need to install a relay harness if you want the ZXE's at full power.
One of my fog lights are going out, i thinking the morimoto type s treatment is in store. This may solve my issue for led drl too.
What would cause the reflector in the fog lamps to recess like this below?
This one looks like it's normal with the reflector close to the glass and it works.<br/>
The reflector on this fog lamp is now recessed. Wasnt like this before and the bulb is out.
Went ahead and got morimoto xb type s fog light replacements. Hope to have time this weekend to put them in. I'd like to either run these as drl's or replace drl's with opt7 led's. Just don't know about the fit since a heat sink/fan is built into the back of the bulb.
Well i can't run fog as led. Morimoto type S in place.
So i got the jdmtoy SMD 68 @ 6000K in place.
There not that bright at night but that's not the idea i has in mind.
9th Gear
AmplifiedDetails
09-24-2015 02:55 PM
