2012 FWD transmission fluid change
HI,
due to shitty TC and useless 16-030 software update, TC judder is getting obvious. (totally I did 4-5 times fluid change withing 40,000 miles.) plan to change the fluid every 10,000 miles myself.
I plan to change the fluid by myself. with the transmission fluid drain by gravity, how much fluid I should refill in?
the car will only drain 3 quarts at a time....so, this means you fill it 3 quarts....
and the recommended amount of times you should do this is 3.
drain 3 quarts...fill 3 quarts..
drive 500 miles.
drain 3 quarts...fill 3 quarts...
drive 500 miles..
if you followed along, you will need 9 quarts all together
drive 500 miles.
drive 500 miles..
drive 500 miles.
drive 500 miles..
drive 500 miles.
drive 500 miles..
Hi
Thanks for advising. I plan only to do one time drain and refill. cause I did the fluid change often before. the fluid looks very clean and red.
If I only do one time change, after refill, should I rev up engine a little bit for a while in gear N?
justnspace (02-15-2017)
Thanks.
So after one time drain and refill, I just drive as usual.
I used 10 quarts when I did my 09 TL. I used 3 1/3 each time. I believe the 09-10 manual said 3.5 quarts for FWD. SH-AWD is different using 3 quarts for ATF fluid change.
After a drain my car takes approximately 4 quarts to get to the upper mark (as measured per the owner's and service manuals)
