Sponsored by: DashLynx
2010 Acura TL Steering
Old 03-02-2017, 08:40 PM
Arod123's Avatar
Everytime i turn left or right my steering wheel doesn't go back to the center and i have to do it my self. Can somebody tell me what's the problem with that.
Old 03-02-2017, 11:50 PM
real_mckoy's Avatar
Maybe alignment is needed this is just my guess. Someone will chime to tell you exactly what the problem is. Has the car been in any accidents esp. front end. When was the last time the car received an alignment?
Old 03-03-2017, 08:48 AM
wreak's Avatar
Are you running aftermarket wheels and tires? Any aftermarket suspension or anything like that?
Old 03-03-2017, 08:51 AM
Received 8,583 Likes on 6,630 Posts
We're going to need a LOT more to work with OP.
Old 03-03-2017, 09:55 AM
Soal Man's Avatar
^^^You got that right thoiboi, I mean did you curb check anything before this took play or did you run over something? But from what OP is describing it's most likely your having issues that's called poor steering returnability. It could be caused by many factors such as steering gear that is too tight or improperly adjusted. Sticking or binding components, such as a king pin, ball joint, bell crank or even the steering column can prevent the steering wheel from returning to center after a turn. Alignment can also be a factor; improper caster, improper toe-in, can be contributing factors. The list goes on, but more than likely these are the common ones, but best suggestion is to take it to a trust worthy suspension/ alignment shop.
Old 03-03-2017, 10:11 AM
Arod123's Avatar
I was driving and outta no where my left side suspension broke and i was not able to driving after that. But i get it fix and now when i turn my steering wheel doesn't return back to the center it just returns back slow and then i have to do it my self
Old 03-03-2017, 10:37 AM
Arod123's Avatar
And now i got a message saying vehicle Stability Assist: 12
Old 03-03-2017, 10:58 AM
Now we're talking..... There's obviously something up on the left side. Did you do an alignment? Sounds like VSA sensor may be damaged as well.
Old 03-03-2017, 11:01 AM
Soal Man's Avatar
Ok that helps a lil bit. I believe that whoever installed/replaced your suspension parts they might've tightened the steering sector too much that's why the steering is returning slow. So in that essence take it back and have them correct their errors. As I mentioned earlier if it feels like its sticking or maybe binding components, such as a king pin, ball joint, bell crank or even the steering column can prevent the steering wheel from returning to center after a turn. If thats not it then hell all I could think of is your steering rack bushings needs to be replaced as well. I'm not quite knowledgeable on the stability assist thing but I would just try to reset it or take it to the shop and have Acura look at it.
Old 03-03-2017, 12:06 PM
joemcfarnham's Avatar
Definitely take it back to the shop to fix it.
Old 03-03-2017, 09:47 PM
Arod123's Avatar
Could it be tie rod end i have a little play in my steering wheel
