Sponsored by: DashLynx
2010 Acura TL AWD timing belt question
Old 09-08-2015, 08:53 AM
vaughanml2's Avatar
Hello all,
I'm a new and proud owner of an 2010 Acura TL AWD. I bought it used, and it currently has 112k miles on it. When reading the service records before buying, I saw that the timing belt service was declined at the local Acura dealership at the 100k service (probably because the owner traded it in for a brand new one a month later). My question is, is the factory recommended change at 100k a little premature? Some folks are telling me timing belts can go for 150k+, so thats why I am coming here for all of your advice. Thanks for any feedback and suggestions!
Old 09-08-2015, 02:03 PM
fsures's Avatar
Timing belt service is due at 105,000 miles
ggesq (09-14-2015)
Old 09-08-2015, 10:25 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Manual states 105K for normal folks, 60K interval if doing severe duty driving. Some people run them until 150K but that's taking a gamble on the engine getting destroyed. I've heard of failures starting after 124K+ on belts so I personally wouldn't go past 120K. The spark plugs are great until 105K as long as you stick with the NGK's.
Valve adjustment is recommended at 105K also.
ggesq (09-14-2015)
Old 09-10-2015, 09:36 PM
Reorge's Avatar
- Absolutely get the timing belt done soon; in the next 5-10k miles. The timing belt change is one of the true negatives of H/A J engine ownership.
And change the water pump at the same time because it's behind the timing belt.
- Plugs have to be taken out to rotate the engine during timing belt change so might as well put in new ones. Or if your neighbor is Dwayne Johnson (aka The Rock) he can help turn the engine with the plugs installed.
- Valve adjustment? I've done three times on three different vehicles and it didn't make a difference. Meh. If you pay someone it's expensive because the H/A recommends totally removing the upper intake manifold. I just unbolt it and move it side-to-side (car front-back) for access. The manifold MLS gasket is reusable on some models. I'm NOT gonna do mind at 105K unless the valves are excessively noisy.
ggesq (09-14-2015)
Old 09-21-2015, 08:33 AM
Type34's Avatar
Originally Posted by vaughanml2
When reading the service records before buying, I saw that the timing belt service was declined at the local Acura dealership at the 100k service.
First of all, welcome to the board.
The 105K is a common discussion thread on this board; partly because it's 1) so expensive and 2) very necessary.
Having saw the report before purchase, hopefully you were able to negotiate a lower purchase price if indeed it wasn't done. The vehicle is over 80K miles (so no Acura Certified Pre-Owned), but if it was CPO, it would have been highlighted as a glaring "coming soon" to-do in the 182-point inspection.
To give you an idea cost-wise, I paid $1100 for having the timing belt, water pump, drive belt replacement, transmission drain & fill, rear differential fluid replacement, and tensioner replaced at my local Acura dealer. I had a 10% off coupon. Obviously the rear diff is MDX specific.
And as others have stated, I waited until 116K miles and that was too long. The last thing you want is for that belt to snap and seize the engine. Wayyy better to be safe than sorry on this one.
Old 09-30-2015, 10:16 AM
jim_c's Avatar
Question
I forget the terminology but there are (at least) two types of engines: some engines are designed so the valves will hit the pistons if the timing belt breaks. (The timing belt operates the cam(s) and coordinates the valve in and out with the piston up and down.) This is the biggest risk with a broken belt. If the pistons hit the valves (before the engine stops turning), it is probably major damage.
Other engines are built so that the pistons will not hit the valves, even if the timing is way off or the belt is broken.
What type is the TL 3.5L ??
The timing belt broke on my Integra (different engine obviously)
when the engine was at idle. The engine suffered no damage whatsoever. I was just lucky. I only state this to point out that a broken belt does not always mean disaster. However I would definitely recommend following the Acura recommended change interval, or do it earlier.
Old 09-30-2015, 10:21 AM
jim_c's Avatar
Again, obvious?
An engine with a broken timing belt will not run.
But you can try to start it. The starter will turn the crank and the pistons will operate but the valves will not. When an engine quits the tendency is to try to re-start it. (!)
Old 09-30-2015, 10:22 AM
Received 16,260 Likes on 11,971 Posts
interference engine
Big Mac (08-03-2022)
Old 09-30-2015, 10:23 AM
if timing belt breaks, the pistons will interfere with the valves and break/bend the valve stems
Old 09-30-2015, 10:43 AM
jim_c's Avatar
Thanks Justin. I assume you are saying our J engine is an interference engine. But as I said, not all engines are.
Old 09-30-2015, 10:31 PM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Hey Justin, how do you know our engine is an interference engine?
Old 06-17-2016, 08:54 AM
3rd Gear
pillguy's Avatar
this is great information, thank you
Old 06-17-2016, 10:46 AM
Reorge's Avatar
This source states YES (interference): Interference Engines - The Complete List - Your Car Angel - Your Car Angel
jim_c (06-22-2016)
Old 08-15-2021, 07:42 PM
3rd Gear
Camelot's Avatar
Hi All,
I know this is the Acura forum, but the Pilot is very similar so I thought I would share this. Just finished the 100,000 mile service on my 2005 Honda Pilot EX-L 4WD with 3.5L V6 engine. The car actually has only 92,000 miles but is long past the 7 year recommended timing belt replacement interval. I learned so much from the various user forums, YouTube videos and viewer comments so I thought I would pass along some of my own experience and tips that may help some others who are contemplating this service on their car. This is not intended to be a step-by-step procedure for doing the job; that is available in many places, just do a Google search. It is just a collection of extra tips and advice based on my experience doing this job.
First, let me caution you that this procedure is not to be taken lightly and requires a fair degree of experience, mechanical skill and tools that go beyond the typical driveway maintenance tasks such as oil changes and brake jobs. Over the years, I have done 5 timing belt jobs but always on 4 cylinder engines with a single overhead cam. This was my first experience with a V6 dual cam (and probably my last since I am 77 years old). On the other hand, if you are determined, have the right tools and watch lots of videos you can probably do this. I found it incredibly satisfying to turn the key and have the engine start and run perfectly after finishing. Not to mention saving hundreds of dollars in repair cost.
The biggest problem most people face is removing the notorious Honda crankshaft bolt so I suggest starting with this task. If you can’t remove the bolt there is no point in going any further. Since most DIY people don’t have the luxury of a lift, there is very little space to get a long breaker bar with a cheater on the bolt for leverage. Removing this bolt requires several hundred lb-ft of torque! You could try the “bump starter” method or bring it to a shop to get the bolt loosened. I managed to get the bolt off relatively easily using a heavy duty impact wrench and special heavy 19mm socket:
Ingersoll Rand 2235TiMAX 1/2” Drive Air Impact Wrench Amazon.com: Ingersoll Rand 2235TiMAX 1/2” Drive Air Impact Wrench – Lightweight 4.6 lb Design, Powerful Torque Output Up to 1,350 ft-lbs, Titanium Hammer Case, Max Control, Gray : Everything Else
77080 19mm Harmonic Balancer Socket Amazon.com: 77080 19mm Harmonic Balancer Socket 3 Times Momentum Power of Standard Impact Sockets Fits for Honda Engines : Automotive
Even with these tools, I had to use PB Blaster and alternated between forward and reverse on the gun before the bolt finally broke free. It took less than a minute and was well worth the $15 price of the socket that I will likely never use again. The impact wrench was a really nice Father’s Day gift from my kids. I will use that tool a lot and it replaced my 25 year old Craftsman impact wrench that had much less torque and finally stopped working. Thanks guys!
After you deal with the crank bolt, you need to remove the serpentine belt (which should be replaced along with the timing belt). This is easily done using a breaker bar on the upper tensioner pulley bolt and pushing it toward the rear of the car to relieve tension on the belt. Don’t worry about loosening the bolt since it has a left-handed thread. The mistake I made was to start with the breaker bar close to the front of the car. When I removed the belt and tried to release the tensioner, the breaker bar hit against the radiator support and I could not get the socket off the bolt. I had to move the tensioner back, put the belt back on and reposition the breaker bar. I found that the bar hit the hood before I could release the belt so I braced the hood as high as it would go with a 2x4 instead of the hood support.
Next is the issue of access. Some people recommend moving the power steering pump and others do not. Same with the pump hose. I found the easiest solution was to move the pump but first take off the pump pulley. I had not seen anyone else do this but the pump bolts are not easy to get to and it is not worth the struggle. Just stick a screwdriver through the pulley slot to brace it in place and remove the one bolt holding it on. Easy! Then remove hose connecting the pump and reservoir and cap off the openings. Put a towel under it to catch the small amount of fluid that will come out.
The 3 timing belt covers are held on with a total of 17 small bolts – 5 on each of the top front and rear covers and 7 on the bottom cover. An air ratchet is helpful in speeding up removing these bolts. Look at a diagram and count the bolts to make sure you get all of them off since some are well hidden. They are all the same size so no need to identify which bolt goes into which hole. One of the bolts (I believe near the top of the bottom cover) is next to a similar bolt that secures the timing belt tensioner. No problem if you remove the wrong bolt like I did since you will be removing the tensioner anyway.
The biggest concern I had was getting all 3 gears aligned properly. After gaining access to the old belt and getting the timing marks lined up, I used white nail polish to mark the arrows on the gears, the engine block arrows and the corresponding points on the old belt (I used different colors on the belt to identify the corresponding gears). The gear indicator marks are on the edge of the gear away from the engine block so I made a mark close to the block on each gear. Especially with the rear cam gear, viewing it an angle makes it difficult to see when the marks are in alignment. I used a small inspection mirror to confirm they were lined up. After removing the belt, I transferred the marks to the new belt and confirmed the locations by counting the number of teeth between each mark (counted each belt twice to be sure). A painstaking and time consuming process but well worth it in the end. Note that you can’t mark the belt where the crank gear alignment mark is located since the belt does not contact the gear here. So I marked the belt and gear directly opposite this point and also at the right and left 90 degree points where the belt just starts engaging with the gear.
Changing the water pump, idler pulley, tensioner pulley and tensioner was straightforward. There is a Honda Service Bulletin regarding the idler pulley:
Service Bulletin 08-045 - Chirp From the Timing Belt Area Service Bulletin Chirp From the Timing Belt Area (Supersedes , dated May 21, 2010, to revise the information marked by the black bars) - PDF Free Download
I did not have this noise but decided to add the shim anyway. Looks like a simple little piece of metal but costs at least $25 on eBay and even more from the dealer.
Putting the new belt on was tedious and I ended up doing it 4 times before I was satisfied that it was correct. The rear cam gear is the hardest since it tends to suddenly jump ¼ turn clockwise from the aligned position due to the valve spring pressure. My biggest fear was that it would jump while I had my hand there putting on the belt and would cause some nasty injury. Fortunately that did not happen to me, but be careful. Even though the service manual says to start the belt installation at the crank gear and work counterclockwise, my first inclination was to start at the rear cam gear since it was the hardest. That did not work out so I went back to the recommended sequence. I also did not remove the spark plugs since they were recently changed. It made moving the crank gear a bit more difficult since I had to wait a few seconds for the compression to release after each piston reached TDC. The rear cam gear did jump a couple of times but I was able to turn it back easily (CCW) with a breaker bar. It was like a balancing act to get it to stay in place.
The marks I made on the new timing belt really helped getting things aligned. Even when I thought all the slack had been taken out between the crank and front cam, the marks on the gear and the belt did not line up. I used a small clamp to hold the belt on the bottom of the crank gear while routing it around the idler pulley to the front cam gear. I found it helpful to move the front cam gear slightly clockwise to get the marks lined up and then moved it CCW to stretch the belt. Same procedure with the rear cam gear except that even the slightest movement would cause it to jump so I held it with the breaker bar slightly off center and then moved it back in alignment to stretch the belt.
Even without the tensioner applying pressure, I found it very difficult to get the timing belt over all the gears and pulleys. It is a very snug fit. It helped to loosen the idler bolt a few turns to allow the idler to move providing a bit more slack in the belt. The bolt is tapered so when you tighten it the belt will tighten.
All was good and seemed correctly positioned. At this point the instructions say to rotate the crank gear two rotations clockwise to ensure everything is still aligned. I was hesitant to release the tensioner grenade pin since if there is a problem, it is rather difficult to reset it. So I rotated the crank without the tensioner released. Big mistake! The belt almost immediately skipped a couple of teeth off the crank. Another contributing factor was that I had removed the belt guide plate from the crank gear and did not put it back. That plate helps to hold the belt in place on the crank gear. So I went through the whole process again. This time I released the tensioner, installed the guide plate and rotated the crank and everything stayed lined up. Success at last!
This is the timing belt and water pump kit I used. It costs a bit more than some others but has good reviews and very complete instructions:
AISIN TKH-002 Engine Timing Belt Kit with Water Pump Amazon.com: AISIN TKH-002 Engine Timing Belt Kit with Water Pump : Automotive
There is a Honda Service Bulletin regarding the replacement serpentine belt tensioner pulley:
Service Bulletin 08-082 - Drive Belt Tensioner Replacement https://bit.ly/3yAvXEd
This involves trimming one of the plastic ribs on the top front cover and needs to be done before installing it.
After putting the covers back on, I installed the crank pulley and bolt. The instructions are to torque the bolt 47 lb-ft and then another 60 degrees. I think the final torque spec is about 180 lb-ft but most people don’t have a torque wrench that goes that high. So after I did the initial 47 lb-ft torque, I marked a bolt point and corresponding spot on the next flat of the pulley. Each flat (and point) of a hex bolt is 60 degrees apart. I used the impact wrench and special socket to nudge the bolt slowly until the marks I made lined up. When torquing the crank bolt you need to hold the crank pulley so it does not move and there is a special tool for that purpose:
BETOOLL 50mm Crankshaft Crank Pulley Wrench Holder Amazon.com: BETOOLL 50mm Crankshaft Crank Pulley Wrench Holder Tool Removal Holding Spanner kit for Honda and Acura Engines : Automotive
The instructions say not to use an impact wrench to tighten the bolt but I think this is because just using an impact wrench would give an imprecise torque, either too loose or too tight. My method follows the instructions for how much to tighten and I can’t see any possible downside. It would have been very difficult to get that much leverage without a lift for the final 60 degrees using a breaker bar with a cheater. (By the way, one of the upper timing cover bolts sheared off when tightening even with a small torque wrench set to 9 lb-ft. It is a middle bolt so I’ll just leave it off. Not critical so no worries. At least it wasn’t one of the pulley bolts or water pump bolts like some people have reported.)
Finally, I installed the new serpentine belt and tensioner assembly:
Gates Premium Micro-V Serpentine Belt K060841 https://amzn.to/3yHU4ke
Continental 49349 Accu-Drive Tensioner Assembly https://amzn.to/3fVGbrD
Just make sure the serpentine belt is correctly positioned and centered on all the pulleys.
Although it had to be removed to access the timing belt, I did not replace the right motor mount since it was still in good condition and is not difficult to do at a later time (unlike the water pump). In fact, all the belts and pulleys I removed, including the water pump, seemed to be in good condition. There was only a slight oil seepage from the timing belt tensioner. I hope all the new parts last as long. If you need to change the motor mount, try this one:
Anchor 9299 Engine Mount https://amzn.to/3iEtMK9
(I bought and returned the ones made by DEA and Beck Arnley since they did not match the OEM mount. I did not buy the Anchor 9299 mount but the picture looks like it is an exact replacement and it is less expensive than the others.)
Also, if you need to change the spark plugs I suggest that you get this tool. It makes the job so much easier with the hidden spark plugs:
LEXIVON 5/8" Magnetic Spark Plug Socket, 3/8" Drive x 6" https://amzn.to/3iE2rrN
Then came the the “moment of truth”. I put in the key, held my breath and turned it to the start position. The engine started right up and runs like new.
Sorry for the long post. Hope you find some helpful tips for your job. I know a video and photos would have been helpful and I really admire and appreciate those who take the time to do that. Most of the links I posted are for Amazon sources but of course you can buy these items at other places. Some of the tools can be borrowed at auto parts stores. Good luck with your project.
The following 6 users liked this post by Camelot:
2012AcuraCPB (10-17-2021), csmeance (08-16-2021), echodigital (11-01-2021), heyjon (11-09-2021), Riboflavin (11-01-2021), Sam_P (11-01-2021) and 1 others liked this post. (Show less...)
Old 08-15-2021, 08:14 PM
MileHighSH's Avatar
Good site to use for ref! Have used it for 5+ years never let me down!
Old 11-01-2021, 10:16 AM
Sam_P's Avatar
Thanks for the tip sheet! Planning to tackle mine on 2003 Acura TL @ 217,000 miles. Last was at 121,000 on 5/12 so cutting it close.
Nitin
09-30-2015 08:22 PM
GhostTL09
09-19-2015 01:57 PM
PAK74
09-03-2015 09:02 PM
datadr
09-02-2015 06:46 PM
Quick Reply: 2010 Acura TL AWD timing belt question
