Windshield Wipers
Old 01-24-2009, 01:25 PM
  #41
annwon's Avatar
Originally Posted by davidspalding
I'd be surprised (or would I) if there wasn't an adjustment fixture for the spring.... I know this was asked, and I just got around to realizing why this would help. (duh)
Another clue would be if this happens at rest or at highway speeds. In the case of SpoiledKari's 2006 model, the ICON style wiper assemblies should "push" the down to the windshield a little at 55MPH. Perhaps not enough, though, if the wiper arm is faulty.
Those with the problem, let us know if this happens at rest, at high speed, or both....
mine happens at rest, at speed, while using the washer spray, when it rains
Old 01-25-2009, 10:46 AM
  #42
Make a hole, coming thru!
davidspalding's Avatar
Originally Posted by MuGen7Modulo
Just get a new car from the dealer. Very satisfied!
Fixed.
Old 08-27-2009, 03:44 PM
  #43
5th Gear
illinibenz's Avatar
Can I ask how this was fixed? I am experiencing the same issue. I replaced my wipers with ICON and it's missing a 12" x 12" spot right smack in the middle of the windshield. I replaced those with Bosch Excel and same issue. Very frustrating.
Old 08-31-2009, 08:25 PM
  #44
arshu78's Avatar
ordered Valeo from tirerack hopefully resolves the issue
Old 09-02-2009, 08:55 AM
  #45
Just a new Honda Insight pull up to the service dept. Monday while having my TSX serviced. Lo and behold, the Acura-like ICON-style wipers on the windshield. So replacement blades may become easier and cheaper to purchase (IF they're the same length).
Fixed.
I changed his text.
Dunno what your problem is, either the wipers aren't making full contact, or they need adjustment. Maybe the spring on the wiper arm? What year TSX do you have?
Old 09-02-2009, 01:22 PM
  #46
5th Gear
illinibenz's Avatar
I have an '06. The weird thing is that I have replaced with the same make/model wipers a few times. All of a sudden they won't make contact with the windshield. I'm about to try my third brand. Frustrating.
Old 09-02-2009, 01:28 PM
  #47
I don't know why you aren't using the Acura ICON style wiper assemblies, then. They work great on mine, and it costs < $12 to replace the blades (mail order from an online Acura parts dealer).
I would try the Acura wipers and see if that resolves the problem (maybe the aftermarkets aren't working with the way your wiper arm is adjusted). Or have the wiper arm checked/adjusted.
Old 09-02-2009, 01:48 PM
  #48
5th Gear
illinibenz's Avatar
I'll give it a shot. Thanks for the tip.
Old 09-10-2009, 02:15 PM
  #49
mxhammypx's Avatar
Does anyone have a picture of the factory blades? I'm not sure if what mine has on it is the original blades? Thanks.
Old 09-14-2009, 11:05 AM
  #50
Did you look at my wiper replacement DIY thread?
Old 09-15-2009, 05:49 PM
  #51
8th Gear
shay333's Avatar
I had this problem on my 07. I bought it new and had the oem blades on. I went to the dealership about 7 or 8 months later and complained. They replaced the entire wiper on both sides, blades & arms, and told me it was a common complaint. Haven't had a problem since. They said the actual wiper arms were slightly off (not angled correct) and that was causing the blade to miss.
They did try new blades at the dealership (didn't help) before replacing everything.
Old 09-15-2009, 08:15 PM
  #52
it's a car-drive it
nj2pa2nc's Avatar
I must be lucky as I still have the oem wipers on my 06 tsx with almost 92,000 miles
Old 09-16-2009, 09:22 AM
  #53
suzook's Avatar
I have this problem on my newly aquired 04 tsx. Has anyone found out a real fix?
Old 09-16-2009, 10:38 AM
  #54
Yes, Kathy, you are our lucky charm. (Cue Madonna song....)
Old 09-16-2009, 12:09 PM
  #55
suzook's Avatar
update, i just made it about 90% BETTER. I took the metal arm and bent very slightly. It puts more pressure on the end of the arm now. I will try a little more bend to get it 100%
Old 09-17-2009, 10:12 AM
  #56
Proud Acura Owner
deepen03's Avatar
did you make sure the blade is sitting above that little metal part of the driver side of the arm?? if you put it underneath it by accident the blade won't curve properly and you will miss a lot. the same thing happened when i switched to rainx latitudes, but i noticed during installation and put them on properly.
Old 01-16-2015, 12:03 AM
  #57
Dominivacano's Avatar
FOUND THE SOLUTION!!! I struggled with this, tried bensing the arms, was even about to buy the 06 arms for like 100 bucks, but at the end, its that stupid little clip! Its like a clip on the left side of the driver wiper. When the wiper goes up it may wipe sometimes, but when it comes down, it leaves a huge patch cause newer style "reflex" type blades dont really fit in it, so it hold it on an awkward angle causing uneven pressure on one Side of the wiper.
SOLUTION: unscrew the little clip/holder and get a new wiper ( since the other one is worn unevenly. Worked for me after owning my 04 nbp a spec for about 10 months! Tell me how it goes for all of you!!
Old 12-23-2016, 04:41 PM
  #58
classical420's Avatar
Lightbulb
Hey guys - Dominivacano was 100% correct.
I've had my '05 TSX for nearly 9 years and just dealt with the crappy wipers. I've consistently purchased the most expensive blades I could find hoping it would fix the problem, but everytime it rained/snowed there'd be a large swath of unwashed windshield. And I live north of Boston... so basically I'm an enormous idiot for waiting this long.
I took the 45 seconds to remove the "little clip/holder" with a phillips head, and it works like it's supposed to... and I didn't even have to replace the wiper. Upsettingly hilarious. Photo of the "little clip/holder" attached.
mrhector (03-06-2017)
Old 03-06-2017, 03:08 PM
  #59
mrhector's Avatar
Holy crap thank you! Replaced my wipers on a '05 TSX with some Bosch ICON's and was going nuts cause of the little spot left over on the return stroke. Was getting ready to try to return them or buy another brand. Popped out the little piece and saw on the wiper where it was rubbing. Works perfectly now, no more streaks.
Old 05-05-2017, 03:28 PM
  #60
Resident Smart@ss
ProfessorFunk's Avatar
After reading this thread, I ordered an OEM driver's side wiper for my woman's '06 TSX. This joker's curved like a cartoon villain's mustache!
2006 TSX driver's side wiper, or cartoon villain's mustache!? You decide!
Old 05-07-2017, 10:05 PM
  #61
green_henry's Avatar
Whatcha talkin' bout Willis?
I have had zero issues with RainX wipers (but I live in Cali where it only rains during the fall and winter -- if we're lucky). Love 'em
Old 05-11-2017, 06:27 PM
  #62
hanknj's Avatar
Icons are the way to go, have never had an issue with them besides maybe not lasting too long..
Old 05-11-2017, 06:52 PM
  #63
Resident Smart@ss
All I can say is that my woman had, for several years, the infamous lower windshield gap, but installing the OEM wiper shit corrected it.
TheMuffinMan
06-02-2022 07:11 AM
csmeance
09-10-2018 09:15 AM
bluetl04
08-16-2016 02:49 PM
blacktsxwagon
10-27-2015 10:12 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: Windshield Wipers
