Oil drain bolt size? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 02-17-2006, 06:27 PM   #1
Registered Member
Whats the size of the drain bolt for a socket wrench/torque wrench? and the manual says to torque it to 33lbs. i heard 25lbs. somewhere. which one is best?
euroStyle is offline   Reply With Quote
Old 02-18-2006, 04:37 AM   #2
Registered Member
so no one knows what the size is?
Old 02-18-2006, 05:21 AM   #3
Registered Member
drkangel348's Avatar
Usually I just finger tighten it and then tighten it with a ratchet/wrench as much as I can with slight force and for the final touch I tighten quite firmly from the 3 o'clock to 6 o'clock position (or as close as possible to the 6 o'clock position). The crush washer will be a buffer for stripping and cracking the oil pan, always use new crush washers.
The socket size is 14mm.
drkangel348 is offline   Reply With Quote
Old 02-18-2006, 05:27 AM   #4
Registered Member
Also if you really want to torque it down, if it says 33lbs/ft in the manual then do it, 33lbs/ft sounds right.
Old 02-18-2006, 05:30 AM   #5
Registered Member
Quote:
Thanks, thats what i was really looking for.
Old 02-18-2006, 12:17 PM   #6
Registered Member
It's actually a 17mm hex, and the torque spec is 33 lb-ft with a new crush washer.
poltergeist is offline   Reply With Quote
Old 02-18-2006, 12:26 PM   #7
Registered Member
I will 2nd the 17mm.
I have had a tough time getting my 1/2" drive torque wrench to fit between the plastic air deflector and the drain bolt head (my 17mm socket is too long). The plastic access panel opening doesn't give me enough room toward the rear of the car. I just torque it by hand, no leaks, no thread-stripping so far.
Master47 is offline   Reply With Quote
Old 02-18-2006, 03:02 PM   #8
Registered Member
I dont know what size it is. I just try the ones that look like it will fit and the one that fits is what i use to loosen and tighten it. It is a metric one though.
Alin10123 is offline   Reply With Quote
Old 02-18-2006, 04:06 PM   #9
Registered Member
Oops correction it is 17mm. Sorry it was late.
Old 02-18-2006, 04:32 PM   #10
I strongly recommend replacing oil drain plugs with Fumoto Engineering's oil drain valves. They never leak, they eliminate need for any tools to open or close, there is never a lost drain plug or gasket to worry about and you will never have to worry about someone stripping the oil pan drain threads. I've used them for almost 20 years without any problems whatsoever. These valves are available on their website.
Bert Kanne is offline   Reply With Quote
Old 02-18-2006, 06:04 PM   #11
Registered Member
Quote:
Have you installed one on a TSX? Do we need the extension adapter for the 2.4L Honda engine?
Old 02-18-2006, 06:24 PM   #12
drain plug extension
Quote:
Fumoto's website should be able to tell you if you need an extension; you might want to call them to confirm. I haven't tried one on a TSX myself. If they send you the wrong part in error, they are good at getting you the correct one quickly, in my experience.
Old 02-18-2006, 07:22 PM   #13
Registered Member
Had 210,000 mlies on my previous '88 Acura Integra. Still had the original oil pan and plug when I sold it. If you change the crush washer every time and don't over-do the torque on the plug, you have no need for aftermarket "valves" or the like.
Old 02-19-2006, 08:22 PM   #14
True but...
True, if you change your oil yourself, like I do, you won't likely strip a drain plug or an oil pan. It's repair shops and quick lube places where the damage will likely occur. A new oil pan installed costs a fortune and I have seen them replaced frequently just for this reason.
The drain valve eliminates one tool you need to change your oil; all you need is an oil filter wrench. If you need an oil change and you are away from home, who is going to do it? Obviously you would have to take the car somewhere to have it done. With the drain valve you never have to fish the drain plug out of the dirty oil (if it slips from your hand) and you can drain oil out easily if you accidentally overfill the crankcase. The Fumoto valves are supposedly standard equipment on many cars sold in Japan.
Old 02-19-2006, 09:26 PM   #15
Registered Member
You definitely have me sold on the idea, it looks like it would cost about $30 if we need the extender.
I spent a half hour trying to get my girlfriend's Camry drain plug out a couple weekends ago. She had taken it to one of these instant oil change places the time before, and some gorilla tightened it down way more than needed.
Thread Thread Starter Forum Replies Last Post
Fluid leak fifer16 First Generation RL (1996-2004) 2 10-16-2015 09:54 AM
September 27th Sunday - Touge.ca Cayuga TMP track event 5-8pm/Dusk! #20 of 20+ Events Mugen TSX Eastern Canada 0 09-16-2015 10:52 PM
Maintaining Transmission After Engine Swap ghuns Second Generation TL (1999-2003) 5 09-16-2015 05:26 PM
Side Marker coykiam 3G TL Problems & Fixes 4 09-11-2015 04:43 PM
September 13th Sunday - Touge.ca Cayuga TMP track event 5-9pm! #18 of 20+ Events Mugen TSX Eastern Canada 0 09-02-2015 12:05 AM
Tags
acura, bolt, crush, drain, integra, leak, mdx, oil, plug, size, socket, torque, tsx, washer, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
