i can't seem to find my AUX input!!
im trying to find my aux input in my car, i took out the storage bin, ran my hands around but i still can't find it or I might've missed it. Anyone know exactly where it is?
yea i have NAVI in it already, and i did feel a plug. Is that plug connected to anything? or is it just a dummy. the plug i see has that black spiral cover on the wire, and its plugged into to something.
https://acurazine.com/forums/audio-video-electronics-navigation-22/finally-i-have-xm-my-auxillary-input-my-05tsexw-navi-312281/
It's the plug at the bottom of the HU. This might help.
thanks, i found it and put the adapter in and it didn't work. Seems like the idiot sent me the one w/o navi >
Its not the SNHOND3, its the blitzsafe adapter. Can i still convert it the same way like in the DIY thread?
Yes you can convert it that way, but it interupts your XM input. The XM input is the AUX input. You're basically splicing the signal from you XM box. You need to buy an adapter like the SOundgate Aux3. You can't just add a RCA Y cable because your XM signal is constant and doesn't shut off.
oh yea, this is kinda off topic, but im having a hard time trying to find a place to draw power. I bought some wire taps which i will be using, i dont want to get too complicated with it, i just want the project done. Anyway, got any ideas? Also, which color wires in the TSX will i need for ACC and battery. I already know the ground is black.. Thanks!
http://www.cifrancis.com/acuratsx_sm...udiosystem.jpg
This is a wire diagram of the OEM amp plugs. I used the power from here when I installed everything.
https://acurazine.com/forums/audio-video-electronics-navigation-22/%2A%2Aaudio-video-diy-info-faq-all-models-%2A%2A-299065/
Go here and read the TSX threads and you will find most of your answers.
https://acurazine.com/forums/showthread.php?t=299065
This thread will probably get closed since it's in the wrong area.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
14
10-31-2015 08:16 PM
navtool.com
09-25-2015 05:15 PM
