HFL Swap Out
Old 12-11-2016, 09:22 PM
3rd Gear
seedub's Avatar
HFL Swap Out
This month, I got a 2006 that has a dead HFL (no response when pressing the Phone button on the wheel).
I've got access to a 2004 TL that has a working HFL unit. Can the one be switched out for the other?
Old 12-11-2016, 09:23 PM
Received 8,584 Likes on 6,630 Posts
Compared part numbers on oemacuraparts.com
If same, yes, else no.
Old 12-11-2016, 11:20 PM
Sorry, my last post was a bit confusing.
What I meant to suggest was for you to go to a dealer site like Acura Parts | OEM Acura Parts | Factory Acura Parts and put in both cars and compare the parts numbers on both. If they are the same, they should be interchangeable!
Old 12-12-2016, 01:23 PM
3rd Gear
seedub's Avatar
Understood; thank you for your quick response.
P.S. The units aren't interchangeable, and oemacuraparts wants to charge me $875...sadly, that's after a 30% discount.
Old 12-12-2016, 01:45 PM
Former Sponsor
acurapartsdiscount's Avatar
pm me your vin and ill see if there is anything I can do for you.
Old 12-12-2016, 01:51 PM
Honestly, if I were you, I would get an aftermarket bluetooth unit, plug it into your AUX port and then you have the added functionality of being able to stream music as well!!
FWIW, I've used this one and had zero complaints: https://www.amazon.com/Kinivo-BTC450...=kinivo+btc450
