Check Engine Oil Level
Old 12-30-2007, 11:44 AM
TSXFL's Avatar
The "check engine oil level" message flashed on my MID yesterday. I was close to home, so I checked my oil, and it was at the low end of the dipstick. I added oil and everything seems to be ok.
Has anyone had this happen? My car is only 10 months old, just had it in for second service in November, seems very odd that it would be either consuming oil or leaking. There is no evidence of leaking oil in my driveway or in my spot at work.
I switched to Mobil 1 at the second service in Nov, not sure if that could have caused this?
Old 12-30-2007, 12:02 PM
dwest1023's Avatar
Thats not good. Its very possible the rings did the seat during breakin. I would have this checked by the dealer and get this on record.
Old 12-30-2007, 12:31 PM
Photography Nerd
Dan Martin's Avatar
It's normal to add some oil between changes. It even says so in the manual...
Old 12-30-2007, 01:41 PM
TSXFL's Avatar
I agree that is normal to add oil between changes, but it seems very unlikely that the engine should consume so much oil to trigger the oil level warning to turn on. I assume that the oil level warning is controlled by the oil pressure.
I plan on having the dealership look at this after the holiday, just to be safe. Wasn't sure if this happend to anyone else
Old 12-30-2007, 02:37 PM
JayRoam's Avatar
is your exhaust blowing any smoke? that does sound odd
Old 12-30-2007, 06:17 PM
still plays with cars
nbtx's Avatar
Did you check the level after the Nov oil change? Maybe they didn't fill it completely.
Just because the car is new doesn't mean that you can just drive it. A new engine require constant attention until you can characterize its performance so oil and coolant levels should be at each gas station stop.
Old 01-09-2008, 07:16 PM
TSXFL's Avatar
Dealer reports that the oil drain plug had some problem with the threads and was leaking very slightly. They put in a new drain plug.
They are the only ones who've changed the oil on this car, and I suspect they stripped the threads or something similar.
Might be time for a new dealership or just go back to doing my own oil changes.
Old 01-09-2008, 07:42 PM
Old Guy
Simba91102's Avatar
Congrats. that's all that it was. Just my 2 cents on oil consumption mentioned on this thread: I have an 05 and an 07 TSX and neither of them have ever used a drop of oil between changes (64K miles on the 05 and changed every 5K and 18K on the 07 and changed twice so far; should be due soon).
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
whitesoxsfan12
09-07-2015 04:07 PM
Quick Reply: Check Engine Oil Level
