Acura TSX no heat but air blowing
Old 09-14-2015, 08:29 AM
mv01's Avatar
I had an oil change done on my 2007 Acura TSX. Since then the heat is not working, especially on the drivers side. The air blows fine. Heating appears to be working on other vents but not efficiently.
My local garage is not able to identify the problem.
Any suggestions?
Old 09-14-2015, 09:12 AM
Received 5,829 Likes on 3,850 Posts
You need to bleed your cooling system.
This is the wrong forum though.
Old 09-14-2015, 09:42 AM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
<p>Moved to correct forum. &nbsp;</p><p>Welcome to Acurazine mv01 <img alt="" src="images/smilies/wave.gif" title="Wave" /></p><p>&nbsp;</p>
Old 09-15-2015, 10:36 AM
TexasHonda's Avatar
Also check air mix motor for smooth movement from max to min temp. They are a frequent source of heat/cool problems.
Problem should be similar for cooling, poor cooling control or stuck on one temp.
good luck
Heyzuez20
10-14-2015 07:18 AM
Bahamanurse1
09-10-2015 10:05 PM
08 NBP TL
09-08-2015 08:49 PM
dlknight
09-03-2015 07:54 PM
Quick Reply: Acura TSX no heat but air blowing
