Warranty expiring
Warranty expiring
My warranty is up in a couple of weeks. Any words of wisdom to share? Anything I should try and do, or look for before its all over?
Rep'n Taxbrain.com
Moderator Alumnus
I'm nearly 7K miles beyond the warranty... my advice, enjoy your car and don't think about anything else. The TSX, as we all know, is a very good car. I suggest you go out and treat yourself to Hondata if you haven't already.
John Starks - The Dunk
Originally Posted by Tsx536
I have about 1,000 miles left. Any one have any ideas?
if any of you guys ever had any trouble with your auto up on the drivers side window..might wanna get it checked out...i had trouble with it not wanting to go up every once in a blue moon...had it checked out..turns out that the regulator was going bad...had it replaced for free..i think i read that a few people here had the same problem before..not sure
Someone stole "My Garage"
Originally Posted by sauceman
Actually, what is you VIN, fdl?
Last 5 digits are all that really matters... if its low (like under 100 or 200), how's your oil consumption been???
Moderator Alumnus
Originally Posted by curls
^^ Just what I was thinking.
I bought my tsx a couple of months after it came out, so its an early run (green key ring baby! )
I am having the seat rails issue taken care of, but what I have been told so far is that the new seat rail design is not in yet. IE, every new TSX off the lot has the same faulty seat rails.
Oil consumption has never been a problem for me.
I had the new seat rails replaced too (VIN #6400 and part of the green ring club) and they felt better than the first set new. I'm going to check to see if the part number changed.
Okay, I looked up the seat rail parts:
2004 Original seat rail: 81510-SDB-A71
2004 replacement: 81510-SBD-A72
2005 Original seat rail: 81510-SBD-A72
2005 replacement: 81510-SBD-73
2006 Original seat rail: 81510-SEC-A01
2006 replacement: 81510-SEC-A02
Interesting. Either my dealer is full of crap, or there is yet another seat rail design in the works.
Moda_Way: Interesting -- the 2004's got the 2005 "normal" rails, and the 2005's replacement rail is something else (73, not 72 or 71). Does this mean any 2004 which had the seat rail replaced before the 2005 replacement was done, has yet another defective seat rail and should have the "73" model installed instead of the "72" model?
Sauceman: What is the HVAC problem you speak of?
Is the seat problem a shifting problem?? I notice my seat shifts forward a bit when i come to a hard stop. It seems loose then, but otherwise I really cant tell.
Moderator Alumnus
The problem consists of a deficient resistance in the radio unit behind the headunit. The radio needs replacement.
I have that problem, but it's intermittent, so I'm leaving it as is for now. It's worth 800$ + install.
Dim or dark Head Unit. I don't know why they call it "HVAC" Or maybe it's just me who got it all wrong.
kixo
09-25-2015 03:07 PM
