2004 TSX transmission problem
Old 11-26-2015, 02:15 PM
6th Gear
Rafaelalcala's Avatar
I have a 2004 tsx with 183,000 miles.. it started with a whinning noise 3 weeks ago coming from the transmission then like a week ago it started slipping so I stopped driving it and today when I turned it on vsa, check engine, caution triangle came on along with a flashing green D indicator...any ideas would be helpful I'm planning on taking it to the dealer next week since I don't trust any local mechanics.
Old 11-27-2015, 01:26 PM
kipsy's Avatar
have you ever done a transmission service on the car ?
Old 11-27-2015, 01:55 PM
6th Gear
No I have not...what do they do when they do that??
Old 11-27-2015, 05:08 PM
kipsy's Avatar
a tranny service is usually they drain the tranny, 3 quarts come out usually, and they put 3 its back in and if you do this every 15k it usually changes the fluid every 3 years.
important to use honda at fluid.
Old 11-27-2015, 05:41 PM
6th Gear
Thanks I will take in to service on monday...
Old 11-27-2015, 08:36 PM
kbh
kbh's Avatar
Have you had fault codes read?
Old 01-03-2016, 06:42 PM
version 2019
cherubino's Avatar
Originally Posted by kipsy
...and if you do this every 15k it usually changes the fluid every 3 years.
Per Service Manual: Flush ATF at Year#6 then every 90K/5-yr
Old 01-03-2016, 07:14 PM
6th Gear
Actually I had my transmission replaced. I took it to a transmission specialist and was told that my torque converter went out due to the fact that I had never replaced my transmission filter and it clogged something inside and there wasn't enough oil going to my torque converter...to have it rebuild they where charging me $3,200 with only 1 year of warranty so I just went with a used one with alot less miles than my car.
Old 01-03-2016, 09:01 PM
version 2019
cherubino's Avatar
first: AT or MT ?
2nd: mileage ?
Old 01-03-2016, 09:02 PM
6th Gear
Originally Posted by cherubino
first: AT or MT ?
Automatic
Acura604
2G RDX DIY & FAQ
17
10-16-2022 11:06 PM
carid
Sponsored Sales & Group Buys
07-26-2016 04:34 AM
ericcdong
12-04-2015 03:08 AM
sander
12-02-2015 08:21 PM
charmer37
11-27-2015 10:56 AM
Quick Reply: 2004 TSX transmission problem
