Helpppp, I Got Check Engine Light Code P1318 And Tcs Light At Same Time
I Change Ignition Modules, Nothing, Car Is Not Failing, Just The Lights, Check Engine And Tcs Appear At The Same Tiime
Could be emissions problem. If your millage is under 150k (or 14 yrs, which yours is) you qualify for a free service at the Acura dealer where they fix ur emissions issues, free plugs, coils (3.2TL) oil change, and other emission issues. Check out the link as well. Call the Acura phone# in the link and verify. Then call your dealer and request the service. Good Luck
http://www.nsxprime.com/FAQ/Reference/tsb/98-031.htm
Catalytic Converter is definitely covered by the extended warranty. 3.2TL has a 3-way Catalytic Converter. They hook the car into the OBD port and run diagnostics. If no codes come up they determine the Catalytic Converter to be working fine. I have an OBD-II hand held device cost around 3 grand min. I can even reprogram my car computer for more power by changing different parameters. Not something u wanna mess around with if u don't know what ur doing.
mada51589
05-03-2022 08:54 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
