HID Lights 2004 Acura
Can someone help me with a DIY on how to change the HID lights on my 2004 Acura Rl I would greatly appreciate your help.
Thanks.
Thanks.
I guess know one has any experience with changing the HID lights. The dealer wants 1200.00 bucks they say the they have to replace the igniter and ballast.
Go tell the dealer they can suck your thumb lol. Are both headlights dead? And how do you know the ballast is bad? If I were you, I might buy the bulbs and ballast online, $300 max on a good quality set. If you don't know what you are doing, go to retrofit source dot com and email the guy and ask for help; make sure you tell them OEM replacement, they are pretty good with HID related. Hope that's help.
Hid
Good evening everyone I took on the task of just changing the bulbs and ordered them from amazon, 2 Phillips D2R 71.00 bucks and it was relatively easy and the light came back on with ease no 1200.00 bucks for Acura I work way to hard for that igniter and ballast bull s-it!!.
Hey Jeep92..So you just swapped the bulbs and left the ballasts alone? I guess what I mean by that is u replaced the factory bulb with the Phillips bulb but are still using the factory ballasts?
D2S bulbs are PLUG AND PLAY and work with your factory ballast. However, if ballast are dead, you'll need to replace ballast. I suggest going aftermarket from The Retrofit Source Inc if you need to.
Eldest928 the bulbs aren't aftermarket, the Phillips bulbs are what's in the car from the factory.
I am in the same predicament but my low beam bulb on pax side comes on and then goes out. Could this be temp related? This has been going on for months now. Dealer wants 1000.00.
I thought if bulb was bad it wouldnt light at all. Id appreciate any guidance.
Maybe a bad connection. See my "headlights" thread.
AndrewS
19
03-14-2024 06:59 PM
rockyboy
01-25-2016 06:00 PM
