HID Lights 2004 Acura
Old 04-23-2015, 02:17 PM
Jeep92's Avatar
Can someone help me with a DIY on how to change the HID lights on my 2004 Acura Rl I would greatly appreciate your help.
Thanks.
Old 05-05-2015, 08:41 PM
Jeep92's Avatar
I guess know one has any experience with changing the HID lights. The dealer wants 1200.00 bucks they say the they have to replace the igniter and ballast.
Old 05-06-2015, 12:17 PM
3.5RLv-tec?'s Avatar
Go tell the dealer they can suck your thumb lol. Are both headlights dead? And how do you know the ballast is bad? If I were you, I might buy the bulbs and ballast online, $300 max on a good quality set. If you don't know what you are doing, go to retrofit source dot com and email the guy and ask for help; make sure you tell them OEM replacement, they are pretty good with HID related. Hope that's help.
The following 2 users liked this post by 3.5RLv-tec?:
Comfy (05-29-2015), Jeep92 (05-07-2015)
Old 05-06-2015, 09:57 PM
Jeep92's Avatar
Hid
Yes, the dealer is a joke 3.5RLv-tec I pretty hand so I've some research and ordered a set of light online and will change them myself. If that works I wont worry about the igniter and ballast because I wondered how all of that could be bad at one time, anyway thanks for the feedback.
Old 05-21-2015, 08:56 PM
Jeep92's Avatar
Good evening everyone I took on the task of just changing the bulbs and ordered them from amazon, 2 Phillips D2R 71.00 bucks and it was relatively easy and the light came back on with ease no 1200.00 bucks for Acura I work way to hard for that igniter and ballast bull s-it!!.
Old 05-29-2015, 07:33 AM
8th Gear
eldest928's Avatar
Hey Jeep92..So you just swapped the bulbs and left the ballasts alone? I guess what I mean by that is u replaced the factory bulb with the Phillips bulb but are still using the factory ballasts?
Old 05-29-2015, 07:58 AM
Received 16,260 Likes on 11,971 Posts
yes. you only need to change ballast if it went bad.
D2S bulbs are PLUG AND PLAY and work with your factory ballast. However, if ballast are dead, you'll need to replace ballast. I suggest going aftermarket from The Retrofit Source Inc if you need to.
Old 05-29-2015, 08:41 PM
Sounder's Avatar
The mechanics of changing the bulbs are very simple. A couple minutes per side. MAKE SURE you disconnect the battery first. Those ignitors carry 25k volts.
Old 05-30-2015, 09:12 PM
Jeep92's Avatar
Eldest928 the bulbs aren't aftermarket, the Phillips bulbs are what's in the car from the factory.
Old 06-12-2015, 10:04 AM
Geedee33's Avatar
I am in the same predicament but my low beam bulb on pax side comes on and then goes out. Could this be temp related? This has been going on for months now. Dealer wants 1000.00.
I thought if bulb was bad it wouldnt light at all. Id appreciate any guidance.
Old 06-12-2015, 04:40 PM
Jeep92's Avatar
Geedee33 that's sounds like what mine was doing it went out then turned pink and eventually went out.
Old 06-12-2015, 11:08 PM
Sounder's Avatar
Maybe a bad connection. See my "headlights" thread.
Old 06-13-2015, 02:11 PM
Geedee33's Avatar
Went to dealer. Bulb tests ok bthey want 1000 to replace inverter and ignitor. Im tempted to do it myself if i can find a chiltons manual to do it
Old 06-13-2015, 08:52 PM
Sounder's Avatar
The ignitor is $145 or so at oemacuraparts.com The job is very easy just be sure to disconnect the battery. There are no manuals as far as I can tell.
AndrewS
19
03-14-2024 06:59 PM
pozebly
09-23-2015 07:30 AM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
voigt
09-02-2015 10:44 PM
Quick Reply: HID Lights 2004 Acura
