Help Help Help
Old 02-06-2017, 03:39 PM
7th Gear
kslocum24's Avatar
Help Help Help
My 2002 Acura Rl 3.5 wouldn't start when I tried to leave the store the other day. I had it towed in to the house and it started up later that evening, so I put fuel injection cleaner in and filled the tank up and drove it around for 30 mins. Upon coming home I noticed that I lost some power going over a hill. The next morning I attempted to start the car, I heard the fuel pump engage but the car still wouldn't start. After that I didn't hear the fuel pump again when I attempted to try to turn it on. Is it the pump or relay switch under the dashboard.
Old 02-06-2017, 03:54 PM
Received 8,582 Likes on 6,629 Posts
Check the PGM-FI relay under the steering wheel.
projektvertx (02-10-2017)
Old 02-06-2017, 04:00 PM
7th Gear
kslocum24's Avatar
Thank you for the tip! my cousin came over and self diagnosed it as a dead fuel pump, but I just don't believe that's the problem since so many acura owners have had the same issue
Old 02-06-2017, 04:05 PM
https://acurazine.com/forums/2g-tl-p...-relay-931252/
PGMFI Main Relay Removal - The Acura Legend & Acura RL Forum
yeah its pretty common for these years of cars to have this issue. A simple reflow of the main relay should help it along. Got a soldering iron?
Old 02-06-2017, 04:06 PM
7th Gear
kslocum24's Avatar
no I don't own a soldering iron, could I buy a new one???
Old 02-06-2017, 04:09 PM
You can, RELAY ASSY., MAIN for 2002 Acura RL SEDAN|39400-SZ5-A01 : Acura Parts | OEM Acura Parts | Factory Acura Parts
39400-SZ5-A01
55 bucks.
Soldering iron is cheaper but whatever you're comfortable with!
kslocum24 (02-06-2017)
Old 02-06-2017, 04:39 PM
7th Gear
kslocum24's Avatar
lol I'm not that confident to mess with the soldering iron on a car. Maybe for messing with an iPhone, but not a car. Thank you sir
Old 02-06-2017, 04:42 PM
It's pretty simple, you remove the relay and check all those solder joints for cold joints or joints that have cracked. It's a much more macro level of soldering than on an iPhone. I'm shocked you made that analogy
Old 02-06-2017, 04:45 PM
7th Gear
kslocum24's Avatar
sorry lol just don't want the shaky hand to tear up my ride. But this picture does simplify the process for me visually
Old 02-09-2017, 04:43 PM
7th Gear
kslocum24's Avatar
Dang replaced the switch but still crank no start. I guess its time to replace the fuel pump. Its located in the trunk under the carpet directly behind the pull down slot in the seat. Easy replacement right?
Old 02-09-2017, 04:46 PM
Are you hearing the fuel pump prime when you turn the key to IGNITION I?.
Old 02-09-2017, 04:55 PM
7th Gear
kslocum24's Avatar
Nope not hearing a thing bud, which sucks because I just knew my fuel pump was good.
