Maint Minder Sub Item 3 -- Replace Trans Fluid
I've been reading on other sites that there is a fair amount of anxiety over power-flushing a Honda transmission. Many have had bad experiences with it. Others have indicated that Honda doesn't recommend it. Independent tranny shops often refuse to power-flush a Honda.
Then I noticed that my very own local Acura dealer recommends power-flushing ALL Honda/Acura transmissions. (This procedure is sometimes privately referred to as "wallet-flushing").
I haven't yet found Honda material specifically advising against flushing the trans. However, the RDX Service Manual for Sub Item 3, Replacing the Transmission Fluid, ONLY has a procedure for draining/refilling 3.5 of the 8.2 quarts. There is a procedure for cleaning the trans cooler with hot pressurized fluid, but this is not a trans flush.
Has anyone had this done on their RDX, or had experience with other Hondas?
Well, now I have found Honda material on this:
I DIY, so I'm planning to drain/refill three times with 11 quarts. This will still cost less than $40.
Does anyone else have their dealer recommending flushing despite Honda's position?
Acura Service News Feb, 2006
Flush Systems: A Big Taboo
In Acura vehicles, the transmission, as well as the
systems that handle lubrication, cooling, fuel, and
power steering, are designed to give thousands of
miles of trouble-free service if you follow the
maintenance schedule to the letter.
Flush systems are a popular aftermarket offering
these days. These products look impressive and
make lots of claims, but American Honda strongly
recommends you avoid using them on any Acura
vehicle. Here’s why:
• The maintenance schedule neither requires
nor approves of aftermarket flush systems.
• Flush systems take time to do; this adds to
your service client’s wait time.
• Flush systems haven’t demonstrated an
improvement in vehicle performance or
reliability.
• Flush systems using solvents may leave
solvent in the system you’re flushing. This will
dilute the fluid or lubricant and degrade its
performance.
• Flush systems using filters can filter out vital
additives and degrade the fluid’s or lubricant’s
performance. This is particularly true for
coolant.
• Any damage caused by flush systems isn’t
covered by warranty.
reliability.
performance.
coolant.
no need to flush, just drain and refill.
my dealer only doing drain and refil, so power flush is just a way to suck more money out of you. If I were you I would decline. You are correct, some were advised against power flush.
jamestheunderdog
07-19-2016 07:58 PM
nanos
11-12-2015 08:41 PM
