brake pedal seen to slip/grind when braking and abs sensor light on
Old 09-29-2016, 11:23 AM
6th Gear
pvtplum1290's Avatar
Hi i have a 2007 acura rdx and this morning going to work i got the following code attach in the pictures above also my brake pedals seen to slip (grinding noise) mostly every time i slowly brake or completely brake at slow mph mostly happen, Any thoughts will be deeply appreciated ??
Old 09-29-2016, 11:27 AM
Received 8,582 Likes on 6,629 Posts
How are your tires? When was the last time you replaced your brake pads/rotors and brake fluid..?
Old 09-29-2016, 02:29 PM
6th Gear
tires still have tread about 30k since bought, all brake pads replace about 1 yr ago from the outside view they still pretty thick especially the rear ones
Old 09-30-2016, 12:37 PM
DRR98's Avatar
When you get a chance...
Google All-Wheel drive:77
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=all-wheel%20drive%3A%2077
https://acurazine.com/forums/1g-rdx-...nction-682423/
Maybe try a hard reset by pulling the + battery cable off for 10 mins
pvtplum1290 (10-03-2016)
Old 10-02-2016, 10:12 PM
6th Gear
i will defiantly take a look
