A16 Service - AcuraZine - Acura Enthusiast Community
A16 Service
Thread Tools Search this Thread
Old 01-04-2008, 08:12 AM   #1
Aint Doing Sh*t
batman's Avatar
A16 Service
Has anyone else had this service? Geez seems like every service its $200+. Does the RDX need this much servicing or am I being robbed by Radley's service department.
batman is offline   Reply With Quote
Old 01-04-2008, 09:16 AM   #2
XIS
Lizard King
XIS's Avatar
How many miles are you at? It says you need the oil changed, tires rotated and rear differential fluid changed. $200 seems high. I just had the oil / filter changed and tires rotated (B1) for $80...
Here is the list of service codes...
A Replace just the engine oil.
B Replace the engine oil and the oil filter, rotate
the tires, inspect the front and rear brakes,
check the parking brake adjustment, and
inspect several other items listed in the O/M.
1 Rotate the tires.
2 Replace the air cleaner element, check the
drive belt, and replace the dust and pollen
filter.
3 Replace the transmission fluid and transfer
fluid (if equipped).
4 Replace the spark plugs, replace the timing
belt (if equipped), inspect the water pump,
and inspect valve clearance.
5 Replace the engine coolant.
6 Replace the rear differential fluid
XIS is offline   Reply With Quote
Old 01-04-2008, 09:29 AM   #3
Aint Doing Sh*t
batman's Avatar
17xxx its well past two bills. closer to three. It's just crazy to be paying a small payment for service. Hurts the pocket after awhile.
Old 01-04-2008, 10:29 AM   #4
mau108's Avatar
do it your self, you can do it for less then 120. (even less if you have the hook ups for the fluids )
mau108 is offline   Reply With Quote
Old 01-04-2008, 10:41 AM   #5
XIS
Lizard King
XIS's Avatar
Find an independant shop that is certified instead of the dealer and I bet you can get it done for almost 1/2 the price.... or DIY
Old 01-04-2008, 11:30 AM   #6
Registered Member
Animagix's Avatar
200 for an oil change seems an awful lot. I'm sure they observe other areas too but, I would go independent most of the time, and occasionally back to acura for bigger jobs (ie. timing belt, etc)
Animagix is offline   Reply With Quote
Old 01-04-2008, 01:21 PM   #7
Registered Member
XLR8R's Avatar
Quote:
Would you keep returning to a doctor who kicks you in the nuts and asks if it hurts?
Find an independant Honda specialist (usually a former dealer tech) and you'll get better care for lower cost. I know a great independant who credits customer bills for core returns such as water pumps.
Otherwise, DIY. The RDX is exceptionally easy to do routine services on, with no special tools.
XLR8R is offline   Reply With Quote
Old 01-06-2008, 12:48 PM   #8
Acura Technician
I wouldn't feel comfortable with a shop using rebuilt water pumps on my cars, you should ask for new pumps.
If you have AAA you can find a shop through them that has agreed to service vehilces and warranty repairs to their standards.
Make sure the shop you take it to uses ASE certified technicians, and specify you only want certified techs working on your vehicle ( this will usually mean no speedy,jiffy, or other quick lube type places.)Make sure the shop is using Acura/Honda fluids for everything other than engine oil.
Sonomaa is offline   Reply With Quote
Old 01-06-2008, 01:40 PM   #9
Registered Member
XLR8R's Avatar
Quote:
The installed components he uses are all new, unless you request a reman.
I am talking about the core credit he gets when sending a removed part back for reman. Most shops would keep this and never mention it. He credits the customer's bill for it.
Old 01-21-2008, 06:09 PM   #10
Registered Member
A16
Yeah, I just had this service A16 done on my car. Close to $300 in santa Monica Acura. It is basicaly oil change and rear differntial oil change. I agree, it is too much indeed. But I dont have the tools, space, etc to do it myself.
stathis is offline   Reply With Quote
Old 01-22-2008, 09:57 AM   #11
Go Buckeyes
A16
Mine was done 2 weeks ago (17500miles), cost was just over $200, a little steep but the bagels and coffee are free
bialkoni is offline   Reply With Quote
Old 01-22-2008, 10:43 AM   #12
dio
Registered Member
I just had this service done 16,868 miles and it cost me 223.09. I
didnt get the tire rotation or balance but I agree cost is high and it does hurt the wallet.
dio is offline   Reply With Quote
Old 01-22-2008, 12:35 PM   #13
Sporty X type
Lrpba300's Avatar
Quote:
No, they aren't! You just paid service BIG TIME for them!!
Lrpba300 is offline   Reply With Quote
Old 01-22-2008, 12:38 PM   #14
Sporty X type
Lrpba300's Avatar
Batman, I thought that talking with you on line you'd be a DIY'er! It is VERY easy to do the oil / filter change & Mobil 1 oil costs about $30-35. Look in the DIY section & see my post on it. There is alsop someone that shows the rear diff. change. Also very easy to do. You can rotate tires very easy if you have a good floor jack. jm
Old 01-22-2008, 12:57 PM   #15
Go Buckeyes
Quote:
duh, I guess you didn't get the joke, I could do on my own but would have to do on the street(no driveway) safety concern(very busy street), need to find a certified tech to do the work or a garage that will let me do it myself for a small fee.
Old 01-22-2008, 08:40 PM   #16
Sporty X type
Lrpba300's Avatar
duh!, I did get the joke! I was just continueing on with the line of joking!
Old 01-22-2008, 09:13 PM   #17
Aint Doing Sh*t
batman's Avatar
New Baby+school+Work=No time. My project EG civic has been sitting in the garage for months.
Old 01-22-2008, 09:57 PM   #18
Sporty X type
Lrpba300's Avatar
Oh! That explains a lot! Now get on that Civic & show us the results!
Old 01-31-2008, 09:36 AM   #19
Registered Member
Crown Acura is charging me 450+ but also wants to do a transmission flush alond with balancing my tires
rdx0810 is offline   Reply With Quote
Old 01-31-2008, 10:01 AM   #20
Alpha Geek
Note to self; AVOID Crown Acura.
lumpulus is offline   Reply With Quote
Old 01-31-2008, 10:08 AM   #21
dio
Registered Member
Quote:
thats a total rip off!!!
Old 01-31-2008, 06:30 PM   #22
Registered Member
What makes them believe you need a tranny flush? Do you have 70000 miles on it? My f150 w/120000 that tows my boat's never been flushed, just changed. Please do not pay for a flush. You make all consumers look like marks.
Pote757 is offline   Reply With Quote
Old 01-31-2008, 08:45 PM   #23
Aint Doing Sh*t
batman's Avatar
Not only NO but HELL NO. I only let them do what the book says and nothing more. Tell them to pound sand and go to another dealer. If there isn't another one then whatever they do outside of what you said is at their cost. Don't let them rob you.
Old 02-01-2008, 05:58 AM   #24
Registered Member
Hey Lumpulus,
Im not sure where you are located,we have a crown acura in greensborro,nc.
Anyways if this is the same place,let me recommend A great ALTERNATIVE.
TRIAD AUTO IS LOCATED IN GREENSBORRO,NC. All they service is Honda and Acura,usually they charge about 1/3-1/2 what Crown charges.My A1 service was $60,I am due for A16 service so I will let you the price.Their website is www.notthedealer.com
buckeye#1 is offline   Reply With Quote
Old 02-01-2008, 06:29 AM   #25
Registered Member
link to website is.WWW.NOT-THE-DEALER.COM
TRAID AUTO
336-393-0220
Old 02-01-2008, 10:37 AM   #26
Registered Member
Thanks buckeye#1 for the info, i am in greensboro.
Old 11-25-2008, 10:39 AM   #27
Registered Member
I barely have 12,716 miles and I need the a16 service done.
Khanyam3 is offline   Reply With Quote
Old 11-25-2008, 10:48 AM   #28
big shot.
....the first rear diff fluid change is @ 15k because its break in fluid, see ur manual.
after that, its every 30-50k avg based on ur driving etc.
nothing to be suprised about if u get the warning at 13k miles...thats right on target.
MMike1981 is offline   Reply With Quote
Old 12-04-2008, 11:47 AM   #29
Registered Member
Cool, sounds good.
Old 12-04-2008, 12:00 PM   #30
Registered Member
I got quoted for $108.00 on the differential fluid change from cerritos acura. What do you guys think of the price? This going to be my first time servicing the rdx there.
Old 12-05-2008, 11:21 AM   #31
big shot.
Is that JUST rear diff? or rear diff & oil...the dealer is going to want to do both diff & oil thats what A16 is.
if just rear diff...seems OK, but id cal some other dealers obviously just to know where that price is among others in the area...
Thread Thread Starter Forum Replies Last Post
Ready To Take the Plunge but With Questions 08KBP_VA Second Generation RL (2005-2012) 37 05-11-2016 09:51 AM
Ft front axle leaking Mike734 2G RL Tires, Wheels & Suspension 1 03-02-2016 09:24 AM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
CLOSED: 2007 TL Base Auto, Fort Meade, MD jmaxima03 Member Cars for Sale 1 09-27-2015 11:22 AM
Wifey got a new ride 95oRANGEcRUSH Car Talk 35 09-25-2015 01:50 PM
Tags
2006, a16, acura, code, codes, engine, flr, honda, list, maintenance, mdx, price, rdx, seavice, service
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
