Oil Pan Removal
Old 06-09-2008, 09:04 AM
Jhatt from Ludhianna
jfkhan's Avatar
Oil Pan Removal
Hi Guys,
I drive a 2.3cl 1998, is there a special method for droppping the OIL PAN. Yesterday I was changing the oil and noticed a lot of oil drops spread around the bottom of the engine. I guess I need to change the gasket of the oil pan.
I have close to 210,000 miles on the engine. My question is I see the pan and the bolts holding the pan but then I see the pan going into the what I see is the tranny casing and am sure that there are a couple of bolts sitting inside there as well....how do I go about removing the pan and these bolts????
Also if I am at it would like to replace the Oil Pick up screen...i guess thats what it is called....where can I buy this??? R they dealer part only???
Any insight would be help full...
Thankx
JFK
Old 06-09-2008, 09:54 PM
Blenz's Avatar
My only experience is with the 2.2 but it's probably the same. The most difficult part will be removing the exhaust. I'd suggest spraying the exhaust bolts down with some WD-40 or something similar and letting it sit for awhile before removing them.
If I remember correctly, you need to remove a small semi-circular plate to get at a few of the oil pan bolts. I'd also suggest picking up new bolts for the oil pan when you reinstall it. I had one break on me inside the block and it was a pain in the ass.
Old 06-10-2008, 07:21 AM
jfkhan's Avatar
thankx Blenz....for the info....actually I was planning on installing new headers.....so it kind of ties this into it...... now I am a bit concerned about bolt breaking in the header.....
but WOW...no one else had any input on this....that juts amaze's me......
When you post a question on drop's, mods and ricing up the CL every one chims in ...but on some serious technical stuff.....its all silence..........
Thannkx all for atleast looking at my question....
Old 06-10-2008, 08:30 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
Sadly this isn't a very mechanically inclined forum like some other honda forums, you're honestly better off asking this question on an accord forum like h-t or somewhere. Most people on here only know springs and intakes not how to drop oil pans, there's been questoins about them in the past that I've seen if you search u might find something, but most people on here don't drop their oil pans or have never had a need to.
Old 11-22-2014, 02:49 PM
whittles's Avatar
have a hole in my pan and am in the process of changing it. My question is similar and it is about the pan going under the crank case. I have removed the bolts and ready to pull off the case. Any help is appreciated. 99 cl 2.3 manual tranny.
Old 12-19-2014, 09:48 AM
musiclevelz5's Avatar
I believe the only two things you need to remove are the exhaust piece that runs underneath the oil pan and the metal brace that runs between both the front subframe and the power steering subframe.
All the oil pan bolts are visible. You may have to gently pry at the pan after you got the bolts off. I recommend putting the new gasket on the pan with a little bit of black rtv to hold it in place for when you put the pan back on the block.
Old 12-20-2014, 11:52 PM
Myxomatosis's Avatar
rubber mallet, biggest help ever, On my 3.0 I dropped the sub frame, pulled the bolts and tapped with the mallet till it came off
foxriderar77
11-19-2020 10:17 AM
kmarqueling
10-03-2015 01:14 AM
Aleax
09-11-2015 11:31 AM
Allen_442
09-08-2015 06:01 PM
Quick Reply: Oil Pan Removal
