Is the v6 accord auto trans compatible in 99CL 3.0?
Old 02-26-2008, 06:01 PM
3rd Gear
BrokenCL's Avatar
I have a 99 cl 3.0 automatic transmission that needs to be replaced. I found a good deal on a trans but it is off of a 3.0 v6 accord auto. Is the transmission compatible as far as the mounting and wiring harness goes, are all the solenoids, pressure sensors vss the same?. How about 97 and 98 Cl trans, will it work in my 99 ? Thanks for the help.
Old 02-26-2008, 06:31 PM
666 Speed
artbran's Avatar
only a 98 or 99 tranny will work in your 99. And as far as the accord tranny's go, if i remember correctly, they have different bell housings which will not work.
Oh and the 97 CL tranny will also NOT work because of more sensors and it just being a different tranny all together with the same internals
I had the same exact problem 2 years ago.
Old 02-26-2008, 08:02 PM
Jim Truett's Avatar
The Accord transmissions are different. The bellhousing will bolt up, but the left side cover has the ATGPS (auto trans gear position switch) mounted to the left side cover, and from what I have been told, it will not physically fit between the frame rails.
As far as I know you have three options:
1. Buy a reman: Acura Warranty Trans
2. Pay someone to rebuild it, just get a good warranty.
3. Rebuild it yourself: My Thread With Pics
Old 02-26-2008, 11:11 PM
3rd Gear
BrokenCL's Avatar
thanks for the quick response to all.
Jim that warranty trans is under $1150, is that a complete trans with tc minus sensors/switches/solenoids? I was under the impression that a reman. trans would run me close to $2000
Old 02-26-2008, 11:26 PM
666 Speed
artbran's Avatar
Broken, Where are you located? if you are close, I'll give you my dead tranny out of a 99 3.0 and you can have it rebuilt then dropped into your car...
Old 02-26-2008, 11:27 PM
Jim Truett's Avatar
I never got around to calling that dealer to get all of the details, but I have seen them at Phoenix Hard Parts for $1250 as well. What kind of failure have you had? You may not need a new converter. I didn't.
When shopping around, you need to refer to your transmission part number, which should be B7ZA for your '99. Phoenix lists a M7ZA on the website which is a '97 model, and not compatible with your car. They may offer a B7ZA as well. There is a sticker on the transmission near the starter that will have the part number on it.
Old 02-26-2008, 11:30 PM
davzilla's Avatar
fuck me runnin. that would have been a better option. at tleast i wouldn't be waitng for the damn filter for three weeks.
Old 02-26-2008, 11:36 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
And here I always thought bellhousing was belthousing
Old 02-27-2008, 08:22 AM
666 Speed
artbran's Avatar
Lol Noob
Old 02-27-2008, 10:13 AM
Skuuuurrrrrt!
GhettoNinja06's Avatar
Back at ya blackack.
Old 02-27-2008, 11:31 AM
DoubleSh0t's Avatar
Old 02-27-2008, 11:38 AM
(Mid-Atlantic)
Can't even see the pic, but just for fun
Old 02-29-2008, 03:01 PM
wilp99's Avatar
the accord trans just bigger (wider) than the cl trans it will bolt up but wont fit in the frame... the cl trans will work in the accord, giving it is a 98/99 cl trans. the 97 trans was the first in the series to be put to a j30 block (kind of a one off) since the accord didnt get a j series engine till 98.. good luck pimp.
Old 02-29-2008, 07:40 PM
(Mid-Atlantic)
Stole my pic lol, u can just use it off my server
Old 04-29-2010, 04:32 PM
thatsme06's Avatar
OK I know its an old thread but trying to figure this out I have a 98 accord here with the B7XA in it. Will the B7ZA bolt up and work? I have a B7ZA available this is why I'm asking. Thanks ahead
Old 04-30-2010, 01:25 PM
Jim Truett's Avatar
No. The end housing is different with no provision for the ATGPS.
Old 04-30-2010, 03:44 PM
thatsme06's Avatar
Oka thanks for clearing that up
Old 04-30-2010, 11:04 PM
Skuuuurrrrrt!
lmao, forgot I owned Chris with his own pic!
Edit: Damn, that was more than 2 years ago! Wow, I thought then that I'd have my car where I want it to be all dropped with new wheels and what not by now..
Old 05-01-2010, 01:15 PM
(Mid-Atlantic)
at least my pic is still on the net somewhere
Old 09-27-2010, 03:46 PM
madsteez's Avatar
just for clarrification:
does this mean the B7XA is not a direct replacement for the B7ZA?
This says that the B7ZA will not work in the Accord,but im confused if the B7XA will fit in the cl?
http://cgi.ebay.com/ebaymotors/Honda...item3ef9be0431
compared to:
http://cgi.ebay.com/ebaymotors/REMAN...item2a06aff152
Old 09-30-2010, 11:16 PM
mzionb's Avatar
b7za b7xa are not the same
Just brought a b7za from a wrecked 99 cl with 85k, thinking it would work in my 98 honda 3.0l. They do look the same but are different. If anyone needs the b7za, i have one ready to go. Would like to trade for b7xa or sell out right.
Old 10-01-2010, 08:50 AM
(Mid-Atlantic)
What's different, the mounts and sensor locations?
Old 10-03-2010, 02:40 AM
mzionb's Avatar
the mounts are ok, both trannies have the same holes for either type mounts. sorry no homo. The b7xa has a pole that sticks out to turn the neutral safety/position sensor, while the b7za has no pole sticking out, but it does have the place to mount the position sensor. Internally there may be a place to add the pole but i have not been inside to see.
Old 05-28-2015, 10:15 AM
levenezia's Avatar
Long shot, but do you still have the B7ZA? I doubt it, but am interested if you do! Thanks!!
Old 05-29-2015, 06:49 PM
musiclevelz5's Avatar
Why do you need a 99 cl trans? Is your trans having issues? Your best bet is to get it rebuilt. Where are you located?
TypeS860
09-03-2021 06:42 PM
IBankMouse
06-13-2020 12:53 PM
oyayjoe
01-01-2019 10:17 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Quick Reply: Is the v6 accord auto trans compatible in 99CL 3.0?
