Where to find the fuse box 97CL 3.0
Old 06-23-2004, 08:51 AM
luck1e's Avatar
I'm unable to find my fuse box, I know there's one under the hood but I can't find my internal fuse box Can someone post a Helms Map of where to find the fuse box. The problem I'm having is my car is overheating. I have no leaks in the radiator. So I think I just blown my fuse. Also my wind shield wipers aren't working. Lights work and everything esle.
Old 06-23-2004, 09:00 AM
fastest time 13.4@107 !!!
fastvtecCL's Avatar
internal fuse box is down by your peddles(driver side) on the left side
Old 06-23-2004, 09:05 AM
luck1e's Avatar
I looked there, also on my passenger side and the glove box, I couldn't find it. I found a control box on the driver side but that's about it.
Old 06-23-2004, 09:08 AM
fastvtecCL's Avatar
hmmm thats were it is on my 99 3.0CL
Old 06-23-2004, 09:18 AM
luck1e's Avatar
Thank you anyway. I'm going to look in the trunk next :-/
Old 06-23-2004, 03:55 PM
Autobot
DanMan1464's Avatar
you must not be looking hard enough
i have a 1997 and its next to the drivers left foot rest thing. It's a sideways door near the ground.
There's another one under the hood at the top left in the 3.0's
Old 06-23-2004, 04:02 PM
ib_jimmy's Avatar
what u mean u can't find it man! its in the same place for almost every import car. and honda havent change.
Old 06-23-2004, 05:22 PM
ENGAGE MY VTEC BABY!!!!!!
97Acura3.0CL's Avatar
its next to the drivers side next to the foot rest on the left, there should be a cover that says "Fuse Box"
also there is a fuse box under the hood and if you looking under the hood its in the top left corner and says again "Fuse Box" and has all the labels of the fuses on the cover so you know what fuse is which
Old 06-23-2004, 05:59 PM
ghost_masterCL's Avatar
So if I wanted to disable my air bags, I could just pull out the air bag fuse? Not that I'm going to because I'm in no hurry to die, but I know someone whom I woulnd't mind see cracking their skull open.... :P jk.
Old 06-23-2004, 08:28 PM
Chinisimo's Avatar
it has the same color panel covering it. look harder.
Old 06-24-2004, 12:02 AM
i think if you pull the fuse for the bags dont they deploy anyways?
Old 06-24-2004, 08:12 AM
luck1e's Avatar
Thank you everyone I found it, I wasn't looking hard enough.
Acura9915
02-24-2020 01:27 PM
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
lovic87
09-15-2015 06:07 PM
Snafunk
1/2G MDX (2001-2013)
09-03-2015 08:01 PM
Quick Reply: Where to find the fuse box 97CL 3.0
