Does this seem like a logical price?
Old 02-25-2009, 02:56 PM
1997 Acura CL 2.2 Premium's Avatar
I am looking to get my timing belt replaced at 200K miles. It was done at 100K miles at the dealer when the previous owner had the car. The dealership said they recommend a 100K mile package which replaces/repairs as follows:
Timing Belt
Water Pump
Valve Adjustment
A/C Filter
Transmission Flush and Fluid Replaced
Brake Fluid Replaced
Air Filter
Cabin Filter
Lubricate All Joints
Spark Plugs
Wheel and Tire Balance and Rotation
All the above was quoted for $1300. The previous owner had the same package done at 100K miles and I figured at least get the timing belt and water pump done. Give me your thoughts.
Old 02-26-2009, 07:25 PM
clusterfunk's Avatar
i got quoted $550 for this
timing belt
water pump
valve adjustment
air filter
spark plugs
@ AMMCO, if that helps. oops, im a 3.0
Old 02-26-2009, 08:56 PM
Boats and Hoes!
Mike86's Avatar
Honestly that seems high and I don't see why all of that needs to be done. Is there a mechanic with a good reputation you could take it to to get a second opinion and quote? The dealer is the most expensive place to have repair work done. The timing belt is a gimmie, that needs done. The water pump really doesn't have to be replaced right now unless it's going out. Things like air filter and spark plugs are super easy things to do yourself and will save you money. Tranny flush and joint lube can be done at a lube oil change shop for alot less. You don't need your tires balanced unless their out of balance, rotation is an easy diy. Be careful of going to dealers for repairs.
Old 02-27-2009, 11:24 AM
My local mechanic quoted me $595 for the following:
Replace timing belt
Replace balance shaft belt
Replace water pump
Replace valve cover gasket set
Replace serpentine belt
That is a much better price. The dealer is out of there minds. Thanks for the replies.
Old 02-27-2009, 11:36 AM
Boats and Hoes!
Mike86's Avatar
There you go that sounds reasonable. Yeah the dealer is a ripoff
Old 02-27-2009, 03:25 PM
shogo2.3cl's Avatar
Timing Belt
Water Pump
Valve Adjustment
A/C Filter-----Do yourself
Brake Fluid Replaced----Prolly dont need this
Air Filter----Do yourself
Cabin Filter----Do yourself
Spark Plugs----Do yourself
Wheel and Tire Balance and Rotation---rotate yourself and if there is no bouncing then you don't need balancing
Save yourself a ton of cash and do the easy stuff yourself instead of paying the dealership there 90 bucks a hour in labor(or whatever they charge) and the 2x the cost on parts fees
Old 02-27-2009, 03:30 PM
on1wheel01's Avatar
yea that's to much i had almost all that done for around 600
Old 02-28-2009, 03:30 PM
First EVER K24 Turbo CL
starboy2nv's Avatar
over priced. you should look into getting a private mechanic that can do all your maintenance ....
Old 02-28-2009, 04:13 PM
Myxomatosis's Avatar
I thought we dont even have cabin filters or at least it was determined that it wasn't worth the time....can't remember
yeah as previously said, timing belt, water pump and valves, that's it and you might want a second estimate from another shop before signing anything. hell, you can even do the trans fluid yourself, Honda quoted me $150 for the AT fluid....hmm, yeah I'll do that for $25.
Old 02-28-2009, 10:23 PM
6spd FTW
Tehvine's Avatar
Yeah 97's do not have cabin air filters.
Old 02-28-2009, 10:54 PM
Custom User Title
Gnate's Avatar
x2, that's what I do now.
When i first got my CL at 104,xxx my mom's ripoff mechanic did all of that shit you listed in your original post for around 1,200
Now I know better.
PS, your name is way too long and possibly cliche.
Old 03-02-2009, 11:47 AM
EMT
Tragic Bliss's Avatar
the dealer will always be overpriced unless ur selling the owner crack.
Old 03-02-2009, 12:09 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
Replace timing belt
Replace water pump
That's a great price, I'd replace my timing belt again if I could get it done for that price, I paid the dealer like $1300
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Does this seem like a logical price?
