98 v6accord motor+tranny+ecu
Old 12-02-2004, 03:42 PM
The movement has started
baka_t's Avatar
Will this fit perfectly into a 97v6 cl? I'm in desprate need of a new motor, being that I have 145k, and there is a guy locally, selling this for $500.
Old 12-02-2004, 03:58 PM
a jawful a somethin awful
sumdumguy's Avatar
wow! nice price. make sure everything is working on that. isn't it the exact same motor and tranny? ever since I came to the site people have been saying that
all 3.0 parts transfer from a 98 accord, right?
Old 12-02-2004, 04:13 PM
112K and on 1st tranny!
DrDre1443's Avatar
rrrrYES! THAT IS CORRECT, SIR!....ah ah ahhhh
Old 12-02-2004, 04:32 PM
What can I get ya?
moforose3.0's Avatar
It will fit and it sounds like a great deal. Go for it.
Old 12-02-2004, 05:22 PM
I'm a llama :(
Motohip's Avatar
Yeah, hope it's in good shape. Do you know the mileage? Make sure it's not stollen
Old 12-02-2004, 05:45 PM
2600lb CL
Cocoa's Avatar
From my understanding is that the motor mounts wont fit perfectly. I believe the mounts would be off by an inch. Their chasis is a bit difference from ours.
Old 12-02-2004, 06:22 PM
What can I get ya?
Everything should fit fine, I dont see why the mounts would be off.
baka_t's Avatar
It's not it was in a side damage accident.
Old 12-02-2004, 09:03 PM
I'm a llama :(
Motohip's Avatar
How many miles?
Old 12-02-2004, 09:07 PM
baka_t's Avatar
50,xxx
Old 12-02-2004, 09:15 PM
baka_t's Avatar
50,xxx
Old 12-02-2004, 11:57 PM
roomate has a CL too
ju5tchi11in's Avatar
motor mounts should not be bad even if they are off... the motor is the same one j30 so it will fit in there but might not line up with the motor mounts. check it out should be able to tell if not you can just cut them off and weld on the correct ones.
Old 12-03-2004, 12:56 AM
baka_t's Avatar
I guess ill be the gunniea pig, and try it out.
Old 12-03-2004, 01:18 AM
SSM Accord V6 6 Spd
EPS CL's Avatar
I think Rick (dustbuster4) put in a new engine into his Cl from a 99 AV6.
Old 12-03-2004, 01:23 AM
baka_t's Avatar
I'm really hoping that the transmission would fit, because of the fact that dr evil is making stronger rebuild components that will help us v6 guys out that are trying to make hp with our cars. Currently, they do not support the cl transmission because of differences, the main concern seemed to be the valving.
Old 12-03-2004, 08:33 AM
sumdumguy's Avatar
you should check with "dr. evil" to see if the mounts and such will match up. since he knows about the honda tranny, he should know mounting locations.
Old 12-04-2004, 07:17 AM
wilp99's Avatar
everything should fit. however the wiring harness is different for the tranny on the 97 cl and the 98/99. its only one more sensor but the computer is prolly gonna thro a code for that one sensor and make ur tranny shift hard. its a secondairy shaft speed sensor. id do alittle more research just to make sure. the motor should be aiit tho. good luck. oh yea HELLO EVERYONE... IM IN TURKEY, they have some fly ass women here.
Old 12-04-2004, 10:24 AM
DrDre1443's Avatar
^^^^^^If only he knew to go next door to Greece!
aznbo187
53
04-16-2008 11:28 PM
Average Jose
06-23-2003 05:47 PM
grnfool
02-17-2003 07:03 PM
Luckyax2
11-07-2002 07:18 PM
Quick Reply: 98 v6accord motor+tranny+ecu
