Question about idling
Old 03-01-2002, 11:50 PM
matts8008's Avatar
I recently noticed that when letting off the gas in my 2.2 CL from a complete stop, there is very little if any power when I dont have my foot on the gas. I used to be able to start moving a little without touching the gas. This is an automatic. I have also noticed it rolls backwards more when I'm on a hill, have it in drive, and not touching either of the pedals. Anyone have any ideas or experience this?
Old 03-01-2002, 11:57 PM
mbuna's Avatar
it could be a lot of things, but i would start by asking if you get you tranny fluid changed regularly and how many miles the car has, because when the torque converter starts to wear out you can get those kind of problems. also seen my moms car act that way after 10k miles of 87 octane piss, fuel injectors so dirty had to floor a HONDA to get it to start.
Old 03-02-2002, 12:00 AM
matts8008's Avatar
It is a 97 with 65k miles. I bought it used so I am not sure about the tranny fluid. I do run 87. Perhaps I should try some injector cleaner and see what happens?
Old 03-02-2002, 12:07 AM
mbuna's Avatar
try injector cleaner and brand name gas in the super variety to clean it out. then stick with the medium stuff at least( I use premium, I love my car too much not to)and get the tranny serviced with HONDA atf. and for all you people who think gas is just gas think again, the higher prices are for the extra refining (read clean) not the octane additives.
Old 03-02-2002, 01:05 PM
Not Fast But Built 2 Last
Ricka220's Avatar
What octane is reccomended
For a 2.2?
Old 03-02-2002, 11:11 PM
Not Registered
Bdog's Avatar
Re: What octane is reccomended
Originally posted by Ricka220
For a 2.2?
87 octane is what Honda and Acura say because of the low compression ratio. As long as it is a good quality gas all three grades run the same in my car that I can notice.
Old 03-02-2002, 11:18 PM
mbuna's Avatar
87 I bet, but...
my mom's 98 2.3 accord knocks on 87 octane when you punch it, and it's rated for 87. Besides just fill your car up into the neck of the filler nozzle, or better yet your lawn mowers gas can and look at what color virtually all 87 octane gas is. yellow-brown or rusty orange, the color of petro-chemical filth. This dirty component of cheap gas coats your fuel systems, leaves carbon residues on valves,heads, pistons, etc, etc. Eventually compression rises due to the deposits and your car will knock unless you use 89 or better octane. Hondas have wonderfully intricate, very well balanced engines that like any internal combustion engine don't respond well to deposits throwing it off balance. So if you love your CL (and I know most of you do, or you would'nt be here) use clean premium fuel to feed your baby. Besides what if you lose to some american iron because your car starts knocking and the computer retards the timing, which kills shitloads of power when it happens.
Old 03-03-2002, 09:35 AM
In Da LBC with Snoop Dogg
dajuice27's Avatar
At the very least, use mid grade gasoline. I use nothing but Premium and I try to use the same type of gasoline whenever possible. Also use that fuel injector cleaner every 2,000 miles instead of 3,000 miles - something like Chevron Pro-Gurad to keep the carbon deposits from forming and extending the life of your engine.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Eggs999bacon
09-24-2015 10:08 AM
Quick Reply: Question about idling
