Axle nut, reverse thread? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 04-10-2005, 08:15 PM   #1
AzN-SoLjA
I've taken off the tire and the cover plate, but the axle nut is stuck and a friend said it could be reverse thread. Any immediate help would be appreicated. 97' CL
The0FaLLen0 is offline   Reply With Quote
Old 04-10-2005, 09:01 PM   #2
Registered Member
wilp99's Avatar
naw pimp. its just tight as hell u need a breaker bar.
wilp99 is offline   Reply With Quote
Old 04-10-2005, 09:02 PM   #3
Registered Member
wilp99's Avatar
just a stupid question but did u remove the cotter pin?
Old 04-10-2005, 09:47 PM   #4
AzN-SoLjA
The hub that goes over the spines on the axel is stuck and wont come off. Theres a puller on it but it wont come off. What should i do.
Old 04-10-2005, 11:17 PM   #5
Trailblazer = SUCK
LCARUCA 97's Avatar
i had to use a 1" drive socket and one of the legs off the engine hoist to break mine free.
LCARUCA 97 is offline   Reply With Quote
Old 04-10-2005, 11:45 PM   #6
Registered Member
wilp99's Avatar
hit it with a big ass hammer with the nut on flush with the end of the axle. or use a deadblow. plastic hammer filled with sand. or a big ass rubber mallet.
Old 04-10-2005, 11:47 PM   #7
Registered Member
wilp99's Avatar
have u taken anything else but the nut off? balljoints, tie rod anything? well, first get it to go in alittle so u can breake the rust then u have to take off the ball joints upper and lower and tie rod to remove the axle. wait what the hell r u doing ne ways?
Old 04-11-2005, 12:56 AM   #8
AzN-SoLjA
lol thx for the help im just replacing my bearings because my front left one is dying and is making really grinding sounds and i havnt drivin it for a while xcept today to this house to get it fixed. we got to the axle hub thing it should slide right ( with a little muscle ) off and i should be able to take the rotor off shouldnt i? we cant get this little hub off and weve used a puller with no success. so tommorow we are using a torch to heat it up and the puller to get it off. but any advice is appreciated.
Old 04-11-2005, 01:41 AM   #9
The movement has started
baka_t's Avatar
1000lb 3/4 impact gun will do the trick.
baka_t is offline   Reply With Quote
Old 04-11-2005, 08:32 AM   #10
AzN-SoLjA
Quote:
we finaly got the nuts n crap off we just cant get that little hub off to get to the rotor, this is where were stuck and i cant have my baby back.
Old 04-11-2005, 05:19 PM   #11
Registered Member
wilp99's Avatar
what year is it? 97 is pressed on, theres a way to get it off without getting it pressed off but ull have to do a search. 98-99's are bolt on.
Thread Thread Starter Forum Replies Last Post
NavTool Video Interfaces for 3rd Gen MDX navtool.com 3G MDX Discussion (2014+) 32 01-20-2016 12:43 PM
NavTool Video Interfaces For TLX navtool.com 5G TLX Audio, Bluetooth, Electronics & Navigation 31 11-16-2015 09:30 PM
Feature Comparison- 15/16 TLX vs. 16 Accord blacktsxwagon Fifth Generation TLX (2015+) 42 10-27-2015 11:12 PM
Passenger side rear view tilts in reverse..... STC Third Generation TL (2004-2008) 4 09-23-2015 05:36 PM
Tags
2001, 97, acura, axle, cl, front, nut, nuts, remove, reverse, reversed, rsx, thread, threaded, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
