Acura CL ABS light is on
Old 10-12-2016, 05:01 PM
Rami Jas's Avatar
Thumbs down Acura CL ABS light is on
Hello my dear community!
My lovely and first car I have still with me after many things we faced together some of it is good and I won't let it go easy !
let,s talk about the problem. For the past couple months my ABS light came on by itself and it will go away by itself too . I already changed the reserve assembly the one next to the fuse box on the passenger side, and the light is on since that time !
So than I tried to check if there is any air bubbles in the system and my next step is to get rid of the air bubbles by open the break hose and the break screw that located next to the break hose (after you remove your tire) and No . I'm really disappointed because I didn't fix it and my scan tools didn't help me to figure out what's going on . So If there is anyone who had the same issue before and solve the problem like a piece of cake ! post a reply or add a comment please.
Thank you
Old 10-17-2016, 05:29 PM
Rami Jas's Avatar
I would like to add another thing . When I turn the car on, there is a buzzing noise that will stay for 20 seconds and then the ABS light comes on !
Any idea
Old 10-17-2016, 10:04 PM
Notahonda's Avatar
Have you checked for trouble codes?
​​​​​​​https://www.ericthecarguy.com/kunena...cura-abs-light
Old 10-21-2016, 01:26 AM
Rami Jas's Avatar
Question
No I didn't.My scanner doesn't support ABS codes! But it could be the speed sensor or the ABS sensor. Not sure yet!
Old 10-21-2016, 02:56 AM
Notahonda's Avatar
In the link I posted.. There is a video by Ericthecarguy showing how to obtain the abs codes without using a scanner.. you will be counting flashes of the abs light which will tell you the trouble codes.
Old 10-25-2016, 01:55 PM
Nicholas_23's Avatar
Rami , same problem here. I believe its the pump itself . Ive noticed mine has started to leak where one of the lines screw into the pump. Ive read somewhere there is some whicked pressure in these systems and should be evacuated before a person goes poking around with one. I might be one the hunt for a new pump in the near future . Let me know what your fix was is you fix it
Old 11-04-2016, 09:32 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
Any idea
That sound is the ABS pump priming. The ABS light either comes on from a bad wheel speed sensor or due to the abs pump going bad. Usually replacing the wheel speed sensor that's faulty does the trick
Acurachi
10-19-2016 05:02 PM
EE4Life
06-27-2016 06:19 PM
EE4Life
09-11-2015 10:13 PM
EE4Life
01-07-2015 08:24 PM
csmeance
08-26-2010 02:13 AM
Quick Reply: Acura CL ABS light is on
