ABS light on 1997 CL 2.2
Old 10-07-2004, 08:46 AM
3rd Gear
lastsupper's Avatar
On my wife's 97 CL 2.2 the ABS light keeps coming on, someone recommended changing the brake fluid, is this a fix? Because I have never heard of brake fluid needing changed.
Old 10-07-2004, 08:50 AM
Always drivin 100+
97CLgenius's Avatar
Do a search on finding codes for your car. Under the glove box there is a blue plug with 2 outlets. If you take out that plug and close the circuit with a paper clip, then turn your key to the on position, the ABS light will blink giving you the codes for what is wrong. Search on codes to get the print out of what codes mean what. I use that feature all the time and it's great.
Old 10-07-2004, 11:17 AM
Slooo97CL's Avatar
i think you are getting confused between the ABS and SRS light.
https://acurazine.com/forums/showthr...ight=srs+LIGHT
Old 10-07-2004, 01:15 PM
who got the best deal?
red99cl2.3's Avatar
nope hes absolutly right, under the glove compartment you can get a code for ABS SRS AND CE light
Old 10-08-2004, 08:36 PM
bignoodleboi's Avatar
i agree with 97CLgenius i had a ABS light showing up and i took tat blue connector out and close it with a paper clip and counted the light on da ABS warning light... didn't find any problem but the ABS still on so i checked all the fuses and changed out the R/C MIRROR (7.5 A) fuse in the under-dash fuse/relay box, and BAM the ABS light went off
i got some info about how to erase the code got it from All Data.
" Remove the ABS B2 (15A) fuse in the under-hood ABS fuse/relay for at least three seconds to erase the ABS control unit's memory "
oh yeah that blue connector is really helpful.. you can dianostic the car with that by reading the trouble code the car may have.
mada51589
05-03-2022 08:54 PM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Stu2414
08-30-2015 07:30 PM
Quick Reply: ABS light on 1997 CL 2.2
