98 cl serpintine belt
Old 01-13-2017, 10:11 AM
6th Gear
StephenH37's Avatar
I have a 98 cl and the ac compressor is done.
I was seeing is there a specific belt I could put on to bypass the ac pully?
Thank you for the help
Old 01-13-2017, 10:19 AM
6th Gear
StephenH37's Avatar
Btw, this has a 3.0 v6 engine automatic
Old 01-13-2017, 10:22 AM
Received 16,260 Likes on 11,971 Posts
obviously, a shorter belt.
which, specific one? I have no clue.
Old 01-13-2017, 11:07 AM
6th Gear
StephenH37's Avatar
That's the issue and need any ideas that may help, because this is my only car and don't have the money to replace the compressor.
So need a solution to get me to and from till I get it fixed.
Old 01-13-2017, 11:10 AM
I know people do a/c deletes and there are shorter belts available. Might take some research... I'm out to lunch, but when I get back to the office, I can dig around for you
Old 01-13-2017, 11:41 AM
6th Gear
StephenH37's Avatar
Thanks a lot sir
Old 01-13-2017, 12:04 PM
in researching for you; Ive found that many people delete the a/c. they measure the new length by either using string or using your old serptine belt .
I cant give you an exact length, BECAUSE the info is scattered among different cars...I found info for the 2nd gen TL and the 3rd gen TL and the new length is different for both cars!
the 2nd gen TL had to use a 55inch belt
and the third gen TL uses a 70 or 71 inch belt.
but both stated that you had to use the shortest available belt
Old 01-13-2017, 12:06 PM
draw it out, if necessary
Originally Posted by vill0169
Hey all,
Will be spending the few months on Casual with the AF and during that time will be commiting the TL to track duty only. I've been searching around and I haven't found anyone that's actually removed the AC system from a TL. I really don't see any reason why it wouldn't be doable (in theory obviously lol). Just wanted to post up a belt diagram I found and get your thoughts on it. Basically I would just shorten the belt up and route it right from the crank pulley to the idler instead of going to the AC compressor.
Hopeful solution
Pretty sure I got all this right but I can edit if necessary.
Old 01-13-2017, 12:54 PM
6th Gear
StephenH37's Avatar
Thanks, yeah I picked up a flexible tape measure and gonna try that.
Now, is there a pully difference in the CL(which I have) and the TL?
Old 01-14-2017, 05:00 AM
6th Gear
StephenH37's Avatar
Bump
