1997 cl3.0
Old 11-07-2016, 09:48 AM
3rd Gear
bobhauke's Avatar
1997 cl3.0
My CL3.0 has about 270k miles. It runs pretty good normally. However, a little over a week ago I was driving to work (I drive over an hour one way) and it started sputtering like it was misfiring. Well, I drove home sputtering all the way. So far I've changed the spark plugs, spark plug wires, distributor and rotor, fuel filter, and the fuel pump. The pressure was released after the pump was installed so there wasn't air in the line. Still sputtering. When I first start it up, it runs fine, but after a few minutes it starts to sputter a little. If I idle around town it's fine. If I try to step into it a little it sputters. Kind of stumped. I have ideas, but would like other input. Advice?
Old 11-07-2016, 10:15 AM
3rd Gear
bobhauke's Avatar
Forgot to add, I just cleaned the EGR completely as well.
Old 11-07-2016, 02:42 PM
Notahonda's Avatar
​​​​​​​what parts of the EGR did you clean? The valve itself and/or the passages in the intake manifold? If it runs well during cold starts and sputters only after it is warmed up, this suggests that you may have a vacuum leak.. possibly at the EGR valve
Old 11-08-2016, 10:14 AM
3rd Gear
bobhauke's Avatar
​​​​​​​I cleaned the passages and the valve. That makes sense as when I took the valve off there was no gasket.
Old 12-31-2016, 02:33 AM
Duarte12's Avatar
how do you clean the valve? I just cleaned my passage ways. I read that the EGR Valve should be replaced when you clean the passage way. I thought it was like a sensor and you couldn't clean it.
1999 Acura Cl 3.0 6 cylinder J30A1 Auto Tran. FWD
Old 12-31-2016, 05:36 PM
Notahonda's Avatar
​​​​​​​the EGR valve itself should not require cleaning or replacement. the ports usually clog first. If the EGR gasket is missing or broken that could cause a vacuum leak and engine stumbling.
Old 01-01-2017, 05:55 PM
Duarte12's Avatar
Cleaning Valve
so what is this guy talking about? Cleaning the valves?
Old 01-01-2017, 11:28 PM
Notahonda's Avatar
​​​​​​​he said he cleaned the valve but noted there was no gasket. The lack of EGR valve gasket could have explained the stumble. Cleaning the EGR valve itself probably did no harm or good.
Old 01-08-2017, 08:47 PM
Duarte12's Avatar
Thumbs up
Originally Posted by notahonda
he said he cleaned the valve but noted there was no gasket. The lack of egr valve gasket could have explained the stumble. Cleaning the egr valve itself probably did no harm or good.
​​​​​​​ooooooooooooo ok
jay33
Canada
09-22-2016 10:41 PM
Nicholas_23
09-06-2016 10:20 AM
whoisjohngalt
1G TL (1996-1998)
04-17-2016 12:27 AM
Dayin Henry
1G RL (1996-2004)
03-02-2016 12:47 AM
Quick Reply: 1997 cl3.0
