Here we go....Acura TLX SH-AWD road test (Edmunds)
Here we go....first official Acura TLX SH-AWD road test (Edmunds)
First real hard numbers test
2015 Acura TLX Road Test Specs | Edmunds.com
0-60 mph (sec.) 6.4
0-60 with 1 foot of rollout (sec.) 6.0
0-60 mph, trac ON (sec.) 6.4
0-60, trac ON with 1 foot of rollout (sec.) 6.0
1/4-mile (sec. @ mph) 14.4 @ 97.6
1/4-mile, trac ON (sec. @ mph) 14.4 @ 97.3
Skid pad, 200-ft. diameter (lateral g) 0.84
Skid pad, 200-ft. diameter (lateral g) ESC ON 0.85
Acceleration comments Launch technique makes no difference in the TLX. Rapid pedal transition is as quick as power braking. Shift strategy (i.e. using manual mode) doesn't matter, either. In a sense this is good because it means anyone can achieve the TLX's best acceleration. No wheelspin off the line. Sport+ mode makes no difference here. Downshifts are rev-matched.
Braking comments Better than the last TLX we tested but not impressive. Minimal pedal fade after five stops but the brakes still smoked at the end of the session. Runs ranged from 129 to 135 feet, which isn't particularly impressive.
Handling comments Slalom: Stable and quick without any drama through the slalom. Stability control heavily limits throttle (even turned "off") but does so in a linear manner so that the intrusion doesn't upset the chassis. Goes right where it's pointed, but body roll and tires limit speed. Slalom: Amazing ability to rotate and go where it's pointed on the throttle. Fun to drive in this kind of corner where you can truly experience what SH-AWD does and how effective it can be. However, low-grip tires hurt performance.
So no 6 second barrier breaking so far...
Overall capable car, crappy tires, average to below average braking and adequate acceleration.
Call me repetitive but, again, it seems the perfect competitor of the Buick Regal GS AWD.
At this point either Acura has really dropped the ball on the sport side or they have already planned a Type S down the road...
0-60 mph (sec.) 6.4
The following 2 users liked this post by saturno_v:
internalaudit (10-24-2014),
rockyfeller (10-25-2014)
0-45 mph (sec.) 4.1
0-60 mph (sec.) 6.4
0-75 mph (sec.) 8.9
Braking, 30-0 mph (ft.) 31
60-0 mph (ft.) 129
Slalom, 6 x 100 ft. (mph) 64.7
Sound level @ idle (dB) 43.7
@ Full throttle (dB) 73.5
@ 70 mph cruise (dB) 62.0
0-45 mph (sec.) 4.1
0-60 mph (sec.) 6.4
0-75 mph (sec.) 8.9
60-0 mph (ft.) 129
So a slight improvement over the 4G TL in some areas, equal in others, and slightly worse in others (i.e. braking).
2009 Acura TL Road Test Specs | Edmunds.com
0-45 mph (sec.) 4.4
0-60 mph (sec.) 6.7
0-75 mph (sec.) 9.7
1/4-mile (sec. @ mph) 14.9 @ 94.8
0-60 with 1 foot of rollout (sec.) 6.4
60-0 mph (ft.) 122
Slalom, 6 x 100 ft. (mph) 65.3
Skid pad, 200-ft. diameter (lateral g) 0.83
Sound level @ idle (dB) 39.9
@ Full throttle (dB) 74.3
@ 70 mph cruise (dB) 69.1
i am blocked at work.
are those #s for 4G SHAWD or FWD?
I thought the SHAWD was faster than that.
Acura really needs to get a TLX Type S out if they want to call this thing a "Red Carpet Athlete"
Vehicle
Model year: 2009
Make: Acura
Model : TL
Style: 4dr Sedan w/Tech Package (3.5L 6cyl 5A)
Drivetrain
Drive type: Front-wheel drive
Engine type: V6
I guess I over looked the SH-AWD part for the 2015.
0-45 mph (sec.) 4.1
0-60 mph (sec.) 6.4
0-75 mph (sec.) 8.9
60-0 mph (ft.) 129
0-45 mph (sec.) 4.1
0-60 mph (sec.) 6.4
0-75 mph (sec.) 8.9
60-0 mph (ft.) 129
http://www.edmunds.com/car-reviews/t...tl-sh-awd.html
2012 SH-AWD results:
Acceleration
0-30 (sec): 2.1 (2.4 with T/C on)
0-45 (sec): 3.7 (4.3 with T/C on)
0-60 (sec): 5.7 (6.3 with T/C on)
0-60 with 1-ft Rollout (sec): 5.4 (6.0 with T/C on)
0-75 (sec): 8.3 (9.1 with T/C on)
1/4-Mile (sec @ mph): 14.0 @ 99.0 (14.5 @ 97.2 with T/C on)
Braking
30-0 (ft): 29
60-0 (ft): 120
Handling
Slalom (mph): 64.6 (63.8 with T/C ON)
Skid Pad Lateral acceleration (g): 0.87 (0.79 with T/C on)
Sound
Db @ Idle: 41.3
Db @ Full Throttle: 77.6
Db @ 70 mph Cruise: 62.4
so TLX SHAWD is significantly slower than the model it replaced even with "better' 9AT.
So 2015 TLX V6 SH-AWD is worse than the outgoing 2012 TL V6 SH-AWD
And the 2015 weighs less than 2012....
2015 = Curb weight, as tested (lbs.) = 3,756
2012 = As tested Curb Weight (lb) = 3,842
EDIT... except the 2015 wins in the area of noise...
@ Full throttle (dB) 73.5 for 2015 vs 77.6 for 2012.
@ 70 mph cruise (dB) 62.0 for 2015 vs 62.4 for 2012.
Success!
Success!
I am just curious how Matt Hargett can be selling this car as so exciting to drive and how much better, quicker, more engaging than the previous TL when it doesn't seem to be the case. He should know...he was involved with both cars.
*sigh* OK...I admit, I am getting moody and crabby and likely because winter is on the way but this is annoying for me.
HeartTLs (10-29-2014)
But "Red Carpet" = luxury = quietness, no?
Isn't that why Acura hid the exhaust tips?
Didn't Acura tout how more refined the new TLX is?
http://www.acura.com/PressReleaseArt...014&id=7891-en
About the 2015 TLX
The all-new 2015 TLX was designed to deliver a unique and compelling blend of sports-sedan dynamic proportion, premium luxury refinement and super-handling performance, appealing to a broad cross-section of luxury customers with three all-new powertrains and advanced chassis technologies that respond intelligently to the will of the driver. The TLX lineup features three distinct model offerings that deliver new levels of quietness and ride comfort for a luxurious driving experience.
^^ Nope, because Acura is a green company...they love little bunnies! Actually so do I but the one at the Hugh's mansion....
So you guys are just ignoring the link to the Autobytel video showing 5.8 seconds?
And the Temple of VTEC showing mid to high 5's 0 to 60 times?
What makes Edmunds an expert on 0 to 60 tests? As well The same cars can vary slightly and did Edmunds have optimal conditions as other reviewers etc?
There are enough tests to show this car cando under six seconds albeit not low fives.
There were enough
There were enough
The following 4 users liked this post by SMMN:
Edmunds tests
2009 TL SH-AWD 5 sp. auto
0-45 mph (sec.)4.5 0-60 mph (sec.)6.7 0-75 mph (sec.)10 1/4-mile (sec. @ mph)15.0 @ 94.3 0-60 with 1 foot of rollout (sec.)6.4
2009 TL FWD 5sp. auto
0-45 mph (sec.)4.4 0-60 mph (sec.)6.7 0-75 mph (sec.)9.7 1/4-mile (sec. @ mph)14.9 @ 94.8 0-60 with 1 foot of rollout (sec.)6.4
Received 2,328 Likes
These cars need to be driven hard for a while as the ECU 'learns' what the preferences are for the driver.
See Jeff Palmer's thoughts on TOV regarding all this.
disturb... I am basing my comments on how the car felt when I test drove it. I was soooo pumped on getting one because I love the styling, the price, the dealer.....I just was very disappointed after test driving it.
I make my opinions and decisions based on what I experience, not what I read
Ken....How long is required? Are we talking days/weeks?
I'd imagine days at most. More like dozens of hard miles, the car learns especially in Sport and Sport+ mode that you prefer harder/quicker shifts and are willing to eat up more gas. I'm guessing the throttle mapping becomes more aggressive.
It's quite comical actually. Can't compare the TLX to a Buick otherwise, lol
There were enough
There were enough
Reminds me of those people who tweak and overclock their computers to squeeze a few more benchmark points out of it, while it makes very little difference when they actually use their computer for doing something useful. It's fun to show the numbers in forums and what not but that's about it.
Trying to comparing tests done by the same people/organization because of different testing procedures, locations, equipment, etc.. Probably as close to an apples to apples comparo.
How do Autobytel's and ToV's #s compare between the 4G TL SH-AWD and 5G TLX SH-AWD?
For reference:
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > TLX > > Re: I was told the TLX transmission logic "learns" (new 0-60 times)
We're looking at 5.5 for 0-60.
As a reference, Edmunds (same source) tested the 2004 TL (non Type S), 5 speed auto, 270 HP in 2004
2004 Acura TL Road Test Specs | Edmunds.com
0-60 mph (sec.) 6.5
1/4-mile (sec. @ mph) 14.96 @ 90.71
0-60 mph (sec.) 6.5
For reference:
At this point even other cars transmission logic "could learn"....
There were enough
There were enough
The following 3 users liked this post by oonowindoo:
Everyone (even the A/T guys) seems to be using the lowest times ever posted for the M/T AWD TL with summer tires as a baseline, and comparing it to the slowest times posted for the A/T TLX with its all seasons.
Most of the performance oriented sedan or coupe nowadays with AT are faster than the same model that has 6mt.
6mt does not offer better MPG or acceleration like it used to. The new 8AT, 9AT are just better at it.
Compare different magazine 0-60 test #s are just as useless as compare WHP #s from different Dyno machine.
so, literally there is no improvement with the TLX in terms of how fast it is.
as 1999 acura's will hit the same trap speed.
this goes with the notion that as we're tearing down these engines, acura is DETUNING them.
less moving parts + less weight WILL equal reliability and more efficiency
however; its still trapping the same as my car, a 2006 TL 6MT.
Smoov posted numbers for the A/T version, and they aren't that impressive, but everyone seems to be ignoring them for some reason.
Launching a manual at 4k rpm, and sidestepping the clutch is a lot different, and will lead to better times than just brake torquing an A/T.
I wounldn't say detuning them, they are tuning them with a priority other than for maximum performance.
Look at the MDX. It could have easily been setup for much more power, but it actually has a drop compared to the outgoing one.
With a lighter car, it needed less, and gave them a big bump in economy while still hitting their performance targets..
this means that power is a by product of staying with the J-series engine.
look at what Chevy does with the LSx Engines.
it's the same engine, but more powerful with each iteration.
Acura is staying UNDER 300 Crank HP for a reason.
Does 300+ Crank HP break things?
is 300+ Crank HP too much for the masses?
Vettes are getting 30+mpg on the highway.
5.5 is pretty good; within .3 of the best times reported for the 4G MT, and certainly quite competitive. I believe the Q50 (non-hybrid) is in the exact same range.
The Q37 Sport did 5.2 and 4.9 with optional sport tire package (both C&D tests)
Edmunds (same testing source as the TLX SH-AWD test) run a regular Q50 (non Sport) at 5.5 0-60 (13.7 1/4 mile) almost a full second quicker....
Of course there were some improvements to the tranny, but other than for 9 speeds, it is a regular A/T not a performance, automated dual clutch.
8/9 ZF AT is not the same ole 5AT from 10 years ago + 4 more gears.
The shifting speed is a lot faster.
The whole point is not saying the new TLX SHAWD is slow... it is not. In reality, it is probably about the same as 4G. But that is where the problem is.
With improved 9AT, lighter, "more power", i would expect it to be faster.. probably trap 2-3mph higher.
Not about the same as the old one.
justnspace (10-24-2014)
d1sturb3d119 (10-24-2014)
I think that is where the problem is. The Acura i used to know was:
"With a lighter car, We give it more, and gave them a big bump in economy while still exceeding their performance targets and its competitors.."
So in another word, Acura is just trying to maintain but not to improve, which is the same problem i have with Infiniti right now (I have had 2 G35C and 1 G37C), they need to stop milking that same VQ. Regardless what they claim it has 280hp or 330hp. in reality, it is pretty much the same.
