Eco mode is excellent for snow
This is the first snow day with my 2016 2.4 Tech here in the Hudson Valley we had 5" of snow.
Eco mode reduces the gas pedal sensitivity which helps with wheel spin in the snow. Uphill, down hill with precision! No snow tires stock Good year tires. Between using Eco mode and the PAW system the TLX held up well while a hand full of other cars were fishtailing left and right.
Just in case anyone was wondering how does a TLX without the SH performs in shitty weather.
Eco mode is also better for ice, had to find that out the hard way last night. Barely made it up a hill, and the hill to get up to my house was even steeper so I had to park it on a level street for the night.
What is more likely the problem is that you have your VSA on. Keep in mind that going up a hill, your VSA will be applying braking to any wheel which starts spinning and will also decrease engine power. Hills can then be very difficult to go up. I would suggest that you turn off your VSA next time. Your VSA button is to the left of the steering column. Hold it in until it beeps. You will then see a light on the dash showing you that it has been disabled. Keep in mind, that Acura put that button there for a reason; so you have the option of turning it off. Because there are some occasions where you need to turn it off.
So now I drive exclusively with it off and I find that I have much more control of the car, no VSA cutting out power causing the car to go nowhere or the car to start sliding sideways due to wheels locking and open diffs. I find that it all depends on how you start moving vs if your VSA is on. Gradual pedal movement along with wheels that are not inhibited is the easiest to control. Another thing to note is that cars with AWD (not SH-AWD, but other normal part time systems) rely on front wheel slip to some degree to send power to the rear, however with VSA on that is prevented from working so you start going sideways a little and no power is prompted from the rear.
While VSA off will surely help you get unstuck, I wouldn't leave it off all the time. If you happen to be turning on a corner and your back end decides to slip away (ie, black ice), your VSA will correct it.
Reducing throttle response is helpful with wheel spin from a start and even uphill. I Had a plow truck in front of me fishtailing going uphill ( not sure if it was a RWD) but I was fortunate to not experience any wheel spin. I did slightly skid when coming to a stop. But snow tires would reduce that.
I'm assuming the PAW system helps with fishtailing, so between that and using eco mode it helps.
If snow is falling put on the green mode
Eco Mode/Just a rumor?
Here's the response I received from my dealer's Service Manager:
SOUNDS LIKE A RUMOR MY FRIEND, ECO IS JUST TO SAVE GAS AND MONITER DRIVING HABITS. SNOW & ICE IS WITH THE TRACTION OF TIRES
It helped me,so I decided to share with fellow TLX drivers.
You could try to modulate this yourself, but some cars just have a hair trigger accelerator. My 5 series with snow tires would spin the rear wheels if you just breathed on the pedal, and I would routinely be out accelerated in the snow by grandmas in Camrys. The torque was just to great, and it would routinely trigger the traction control. It had a Sport button, but a snow button would have been very helpful.
When it is slippery out because the roads haven't been plowed yet, etc, I always use the Eco setting. Id rather get trraction off the line without activating traction control, etc.
My 05 Cadillac CTS had the same button with the same concept. I wonder if the snow button could had been considered an eco mode for that car.
never had too many issues other than the constant sliding around when trying to get moving on low traction surfaces.... to solve that problem I decided to get a car that is more capable in said snow.
I live in Ontario, Canada and we get a fair amount of snow. My TLX is my first AWD car. I love being able to stomp on the gas at a stop sign or green light in the winter and let the car sort it out. I'm running Blizzaks for the winter, so they help quite a bit as well. The other thing that surprised me is that you can make the car drift when you want to do so. I thought the stability control or the overall SH-AWD would prevent me from living the days of my youth sliding around corners in my dad's Cutlass. However, by appropriately applying the throttle, it steps out nicely. I'll give the ECO mode a try and see what it does when I'm being a better role model.
We are having a cold, snowy, and icy winter. I have been driving around in Eco mode for the past few weeks, as it suits the type of driving you need to do in these conditions. Last year, I was driving a 2015 SH-AWD, but the 4 cylinder with PAWS (and the same Michelin X Icers I had last winter) feels just fine. Take-offs need to be slower, but that suits my driving style, especially in these conditions.
Having the AWD model... I doubt you'll need to use the ECO mode. This mode would be more beneficial to owners with FWD.
AWD has less worries about wheel spin.
I have to add that the transmission has behaved very well in the cold weather (as in a lot of minus 20s C with colder wind chills). I garage my car, unheated, without ever plugging in. I have had only of couple of minor 2-1 downshifts clunks, usually because I ride the brake, take it off, then break firmly as I stop at slow speeds, which is generally unnecessary. Leaving it in Eco, vs the Eco to Normal to Sport routine I was following has been good, and certainly makes for quick upshifts.
There are four lights!
Currently in a deep freeze with nice shiny ice surfaces thanks to the graders that come by. That said, my TLX is the best winter vehicle I have driven. This is coming from a guy that owned multiple Subarus and a BMW xDrive. I do have Michelin X-Ice 3 on all four corners of the vehicle and working in tandem with the SH-AWD, the vehicle is very confident. I've been driving in Sport mode and I haven't had much issues but like someone mentioned, the SH-AWD alleviates much of the wheel spin.
