Brake caliper cover
Old 11-26-2015, 08:01 AM
open contact's Avatar
Brake caliper cover
These look so nice, than the boaring plain calipers. they are 200 bucks on ebay. has anyone put one of these on, do they fit and have enough clearance?
Old 11-26-2015, 01:25 PM
spoiler900's Avatar
I painted mine with a $6 can from pepboys. I can probably find an "Acura" sticker for a few dollars more to finish it off. But if money isnt as important these ones do look really cool!
Old 11-26-2015, 02:23 PM
show us some pics.
Old 11-26-2015, 02:25 PM
I am worried it may not clear the rims.
Old 11-26-2015, 08:25 PM
advan031's Avatar
I'm sorry but this is a dumb idea.
Old 11-26-2015, 09:16 PM
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
Expect you will get a lot of flack about them. It seems some people don't like them.
I ran a used set I got on ebay for 3 years on a BMW 335is. Sprayed them high temp flat black. For whatever reason the 335is was the only BMW I ever had with fugly calipers even though they were 4 piston performance versions. They fit with no problems & looked a lot better than what was there even if I painted the OEM'S.
from a short distance away you would not even notice them which was the plan.
Old 11-27-2015, 12:16 AM
spoiler900's Avatar
My $6 pepboys can of caliper paint. Only takes a couple hours to do once the wheels come off.
Old 11-27-2015, 04:45 AM
Treblig's Avatar
I did. No fitment or clearance issues.
Old 11-28-2015, 03:39 PM
jeich182's Avatar
I've wondered why the TLX doesn't have them. Doesn't the RDX have them standard? It would be a nice "premium" detail.
Old 12-01-2015, 02:50 PM
csmeance's Avatar
Received 1,988 Likes on 1,412 Posts
Acura makes them for around $20 each
Old 12-01-2015, 03:14 PM
Be a better driver
RedRyder's Avatar
$200 for caliper covers? I'd either clean and paint the calipers themselves (but mask off the pads) or take off the calipers and have them powdercoated.
Old 12-05-2015, 09:41 PM
Crashmaster's Avatar
The vehicle I traded in for my TLX was a 2012 Honda Crosstour AWD. I experimented with putting caliper covers on it, but after seeing how they fit and such, decided against it. Here is what they look like. A full set of these were like $75 on Ebay. What I didn't like about them was the not so perfect fit, the glue that holds them on, and under close inspection, you can see they are just plastic covers. Nope, didn't like them.
Attached Thumbnails Brake caliper cover-p1010174.jpg   Brake caliper cover-p1010175.jpg
Old 12-05-2015, 11:42 PM
dezymond's Avatar
not a fan, makes it look cheap imo
Old 12-06-2015, 10:41 AM
EddieOnAZ's Avatar
If the calipers on the TLX are about the same size as the ones on the 3g TL you could buy RDX caliper covers and install those, they're black aluminum and look clean, lots of 3g owners have them, myself included.
How they look like behind dirty wheels:
open contact (12-06-2015)
Old 12-06-2015, 11:30 AM
^^^ Looks nice. How do i find the TLX caliper size?
Old 12-06-2015, 01:09 PM
EddieOnAZ's Avatar
I don't know but from pictures alone I'd say the calipers on the TLX are roughly the same size as the ones on the TL.
Old 12-07-2015, 07:01 AM
Stew4HD's Avatar
Received 1,092 Likes on 714 Posts
I had a set of caliper covers for my 4G that I tried on the TLX. They don't work due to the way the clamps fit. The calipers are different from the 4G to the TLX
Old 12-07-2015, 07:11 AM
EddieOnAZ's Avatar
Yeah but the RDX covers have flexible tabs that you bend in order to fit on your calipers. On the 3g the rear fit without even bending the tabs while you had to bend the fronts all the way in order for them to fit, I can't imagine the TLX calipers being so different that they wouldn't fit at all.
Old 12-07-2015, 07:22 AM
Stew4HD's Avatar
I tried to get them to fit on the fronts but they either would rub or not stay clipped.
Old 12-07-2015, 01:47 PM
EddieOnAZ's Avatar
Well yeah you have to stick em on there using either JB weld or RTV silicone, they're meant to go on the RDX so you can't expect them to clip right on to our calipers. Worst case you straight up cut the tabs off and simply stick the covers on there, most people use the tabs as another sticking point bending them more or less depending on caliper size.
I don't know about the 4g or TLX but on the 3g once they're installed you lose maybe 1/8th of an inch in clearance, not enough to interfere with the wheels. So unless the clearance on the TLX is tiny the covers should fit.
Old 12-07-2015, 01:55 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Those caliper covers look like crap.
Old 12-07-2015, 03:11 PM
EddieOnAZ's Avatar
Which ones?
Old 12-07-2015, 06:47 PM
you sure you are not looking in the mirror?
rebstacy
11-25-2015 08:50 AM
gavriil
11-22-2002 12:40 PM
Quick Reply: Brake caliper cover
