1/4 mile times
Old 10-01-2010, 01:02 AM
progression's Avatar
Question 1/4 mile times
Im not sure if this is the right section but i couldn't think of anywhere else to post it. Out of curiosity what is everyones 1/4 mile time in all honesty? I ran a 14.9 in a 2001 cl-s 80k miles. temp was 94 degrees outside and no mods with slight weight reduction.
Old 10-01-2010, 01:52 AM
CH46ESeaKnight's Avatar
Where did you run at? Whats the elevation? I also did a 14.9 at 5000 ft elevation with just a CAI, and Option UD pulley.
I think my trap speed was about 97 mph maybe 98. been awhile. I was there with a friend that had a SC'ed 6 speed and he was only running 14.1. but his traps were I think up around 106, 107.
You don't have any mods at all?
Old 10-01-2010, 02:04 AM
i ran at raceway park nj, no mods at all. i was pretty surprised with my time. just took out my spare tire etc and that was it.
Old 10-01-2010, 12:11 PM
Jacobpockros's Avatar
No offense to your friend, but he definatly does not know how to race his car. There are members on here who have ran 14.3's on completely stock 6-Speeds.
Old 10-01-2010, 12:28 PM
2003 Accord Coupe V6
SatinSilverAV6's Avatar
I am guessing you have a 6spd? At 5000ft elevation the Auto would be in the low 16's with traps around 87-88MPH. Here in tucson at SIR where the Elevation is 3075ft a stock Acura CL-S auto is running 15.9@89MPH in cold dry weather. Even 6spd CL-S acuras are running low 15's here.
Old 10-01-2010, 12:29 PM
That is a great time for the hot temp. With a better D/A you should be around a 14.7 or so!
What was your 60ft and MPH?
Old 10-01-2010, 01:17 PM
I could be getting the trap speed mixed with my other car, but the cls did pull a 14.9 best. Ussually it was running 15.3's. But no, I'm auto trans. I did remove the back seats, and passanger seat, and of course the spare tire and stuff. I had the tires down to about 10 psi. If I remember right the 60 ft on the 14.9 run was 1.9.
This was at the Pueblo Motor Sport park in Pueblo Colorado. It was in OCT I think so it was also chilly.
Old 10-01-2010, 01:35 PM
Nice time at that elevation! All that weight reduction and your mods makes a big difference. Thats a hell of a 60ft!
Old 10-01-2010, 09:05 PM
i dont remember my 60ft and mph but im probably going again in two weeks and hoping for a better time. ill be sure to save the time slip this time around
Old 10-01-2010, 09:38 PM
Also I forgot to mention I had about 5 gallons of Sunoco 260GT Plus unleaded fuel left over from a dyno day with one of my boosted cars. It was 104 octane, so I put it in an mostly empty tank and drove the 45 miles to the track with it.
On th launch I was able to mash it to the floor and got very very little tire spin at 10 psi. It just hooked and went. I let the tranny do all the shifting,I decided not to use my superior gate shifting skillz I could tell right away it was going to be a good time.
Old 10-01-2010, 09:47 PM
Heres my 1/8th mile time from a couple months back, im the one on the right:
This track is known to have bad traction because it was made on a parking lot.
Old 10-02-2010, 10:34 AM
Lone Wolf
brian6speed's Avatar
"On launch, the extra power becomes wheelspin and hop. The limited-slip differential that is standard with the manual-transmission CL Type-S subdues torque steer, but the 2.3-second 0-to-30-mph clocking was identical to that of the blown CL and a stock example tested the same day, and the 5.7-second 0-to-60 time was a scant 0.3 second quicker. The supercharger's push comes at higher velocities—it gets to 130 mph in just 23.6 seconds compared with the stock machine's 33.0. And in top-gear acceleration, the trip from 50 to 70 takes just 9.4 seconds as opposed to the stock car's 11.3-second time. But the start leaves the quarter-mile ET just a half-second quicker than stock at 14.2 seconds with a 104-mph trap speed."
That is copied from the car and driver article on the supercharged CL. They got a 1/4 time of 14.2 with the supercharger and you are saying someone who got a 14.1 dsn't know how to drive? He did better than whoever the magazine had drive their car.
The supercharger adds power but it dsn't really help our quater mile times as much because you cant get the power down. The supercharger is best for passing speeds.
Old 10-02-2010, 11:14 AM
Don't forget this was all at 5000 ft elevation. He also had a full exhaust, Comptech headers. I think that was all he had though. Like you said, his car really shined from a roll. Once he got into third gear he would pull pretty good.
Old 10-02-2010, 01:47 PM
I think your getting confused. I was referring to post #5 where he said stock 6-speeds were running 15's.
Old 10-02-2010, 02:52 PM
I think brian6speed was talking about your post #4. he quoted #4.
Old 10-03-2010, 09:23 PM
StreetKA's Avatar
i did 14.3 completly stock and i saw guys with mods that they did 13.8-13.7.
i did 14.3 only once and my average was 14.5
you must remember that adding supercharger you also adding the weight to the front end.
sticky tires headers pulley cai thermal gaskets and i would say '10 TL SHAWD IM are best mods you can do. also lightweight 17's will help alot. removing only passenger seat you can get there quicker 0,1 - 0,2 s
i would try to go there again and see what is the differenace now but my motor mounts aint best condition so i'll wait.
my wish is to hit the high 13" but i think with my 18 wheels that will be difficult
Old 10-04-2010, 12:14 PM
^You can do it as long as you have good tires. 18 inch rims won't be bad as long as they are light weight.
Old 10-20-2010, 08:29 PM
StreetKA's Avatar
so i went to a track today, i didn't get what i was hoping for but... i still have all bad mounts and not so good tires...
i did run 14.1 tonight and im sure i could have done better... i'll try again when i get my mounts fixed
also on the halloween they have dyno day in a local shop so i will be there too
Old 10-20-2010, 08:41 PM
14.1 isn't bad, but i think a CLS6 with headers should be running 13.9's. Tires and mounts should do the trick for you once you do it!
Old 10-20-2010, 08:47 PM
StreetKA's Avatar
i can tell that with good launch i should ran flat 14 or a bit beelow but i could feel that when you shift there is a engine movement that doesnt help and wheel hop... i have videos but nothing really worth to upload
i beat 2010 STI and lose with e46 M3 this shit was stock and ran 13.3 so please dont tell me that anyone that owe CL can beat it.
Old 10-20-2010, 09:04 PM
StreetKA's Avatar
ok i did:P
http://www.youtube.com/watch?v=s1CiQWBjYBQ
Old 10-20-2010, 10:41 PM
Why would i say that a CL can run faster than 13.3 seconds?
Nice video by the way. I wish we had a 1/4 mile near by
Old 10-20-2010, 10:44 PM
Guys, stop posting bullshit.
Old 10-20-2010, 11:04 PM
B A N N E D
friesm2000's Avatar
a TL though, but anyways a 16.1 with the automatic, then 15.3 with the 6-speed, then a 14.5 with roughly a 60 shot of the (and that is not with the best of launches either; still working on that )
and it is bandimere speedway also at 5800 feet (also the track scales says the car weighs 3550 with me in it too)
Old 10-21-2010, 04:25 AM
StreetKA's Avatar
Car with me weights 3580. Low fuel and no spare tire
Old 10-21-2010, 07:57 AM
StreetKA's Avatar
Sorry it was 3545. Car alone 3314. That means i need to go for diet :lmao:
60ft was 2.17s
Old 10-21-2010, 09:13 AM
B A N N E D
friesm2000's Avatar
same, no spare and gas light was on
Old 10-21-2010, 10:18 AM
StreetKA's Avatar
15.3 is slow man. Must be something wrong with the car. What mods you have ?
Old 10-21-2010, 12:22 PM
"and it is bandimere speedway also at 5800 feet"
Thats in Denver Colorado. If I remember right when I lived in Colorado Springs, I did one calculator that said the CLS with 260 hp would loose about 42 HP at 6000Ft elevation.
Old 10-21-2010, 01:19 PM
StreetKA's Avatar
Yes i forgot about that but then what is the reason to build the track at this elevation?
Old 10-21-2010, 01:28 PM
If that is your surrounding then what are you gonna do?
Old 10-21-2010, 02:23 PM
StreetKA's Avatar
true
Old 10-21-2010, 02:51 PM
B A N N E D
friesm2000's Avatar
about correct... (or roughly about a second slower in the quarter mile)(just means we don't need as much safety gear )
not like we can exactly dig down a couple of thousand feet, to be at sea level
but if we wanted lower we would have to go out east a bit (and don't forget that Colorado is the highest state in altitude overall)
also remember i said "without the best of launches", which is going to add to the time some
and because of less power, i don't accelerate as fast, so it makes me have to actually shift into 4th gear, basically right at the end of the track, which does not help times either
Old 10-21-2010, 02:53 PM
StreetKA's Avatar
http://www.youtube.com/watch?v=tj08VJ7j9Ek
if you listen to it closely and volume up you can hear how the engine woble(sp?) after rough shift...
http://www.youtube.com/watch?v=90NYUOjeJy4
http://www.youtube.com/watch?v=gLMQE...layer_embedded
Old 10-21-2010, 03:26 PM
travel further down the mountain
Old 10-21-2010, 03:33 PM
Nice videos StreetKA. Do you have your clutch dampner removed or have an aftermarket clutch? Mine sounds a little different when it shifts.
Old 10-22-2010, 04:22 AM
StreetKA's Avatar
Stock clutch. Im telling you that its bad mounts.
Old 10-22-2010, 12:14 PM
I got the Shifts
phee's Avatar
e46 are fast man. thats a solid loss. go pick on an e36 like i did
Old 10-22-2010, 12:19 PM
You should fix the mounts then.
Before, i was only running 9.7's in the 1/8th, then i replaced my clutch and motor mount with new oem ones and it probably helped me get my 9.3's the next time i went.
Old 10-22-2010, 12:31 PM
StreetKA's Avatar
Thats alot 0.5s should give me 13.6 and i would incredibly happy if i did. I dont know what ppl run the first 60ft i dont think thats there alot to improve but still if i run below 2.1 i would be happy
What was your 60ft jacob?
On the back i have 235/40 bridgestones with alot more meat. I may switch it over to a front to improve the grip at the launch. I lowered pressure to 20psi at the front it helped alot too.
Quick Reply: 1/4 mile times
