suBaRuZ
Old 10-30-2014, 08:31 AM
  #441
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,135 Likes on 4,805 Posts
J, I disagree with you. Kindly remove yourself from this conversation
With this car, you do feel downforce on the street. The rear end is a bit loose at highway speeds, and can be easily upset on spirited onramp runs. The rear diffuser helped with that a lot. I was not expecting it to be that noticeable, but it was.
rockstar143 (10-30-2014)
Old 10-30-2014, 09:20 AM
  #442
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Hey, I don't claim to know everything! I'll take your word for it.
Slamming it to where you don't have all that wind making it's way into the wells wouldn't help? I remember it helping a lot on the RSX and TL.
Guess you guys wouldn't know much about that
Old 10-30-2014, 09:51 AM
  #443
civicdrivr's Avatar
You shouldn't lower this car more than 1.5". I'm probably a little too low in the front TBH. You get to a point where the roll center is so off that all you get is bump steer, and the car no longer handles the way it should.
Costco (10-30-2014)
Old 10-30-2014, 02:43 PM
  #444
I get bump steer on the TL. damn...I'm too low, huh?
Old 10-30-2014, 04:05 PM
  #445
civicdrivr's Avatar
It varies from car to car based on the geometry, but it doesn't matter because its not a sports car.
The S2k though...
Old 10-30-2014, 05:48 PM
  #446
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
My problem with the Type 2 is I'm not sure how useful it really is. It does seal off the opening left when you swap exhausts, but it doesn't stick out far enough from the bumper to really route air. I wish they did the CFD analysis.
Heh, that word has anal in it.
I thought about that too, didn't see and CFD analysis on the T2. I even bumped the thread that the creator of the diffuser made, no response yet though.
The catback I got has a massive muffler, in the same shape, size, and location as stock. Maybe I don't need it? Or I'm not fast enough on the track to notice the difference
I know, at work I call them Anal ysts.
Are you guys really that concerned with downforce and all that sh*t. I think they kill the clean look and for something that you might benefit from at the track, or like 1% of street driving. Fk that.
As Morgan mentioned, it makes a difference. But I'm on the fence at the moment.
Old 10-30-2014, 05:53 PM
  #447
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
Have you properly raised your car yet though? You gotta do that first man.
Old 10-30-2014, 06:16 PM
  #448
Costco's Avatar
In due time. I haven't found the right rally-spec springs I want to get.
Old 10-30-2014, 06:34 PM
  #449
civicdrivr's Avatar
00TL-P3.2 (10-31-2014)
Old 10-30-2014, 06:54 PM
  #450
Costco's Avatar
yes.
Old 10-30-2014, 07:15 PM
  #451
I drive a Subata.
JS + XES's Avatar
Old 10-30-2014, 08:47 PM
  #452
MEKO's Avatar
Received 2,321 Likes on 1,600 Posts
Anal-yiest
To not kill the the clean look, I say Type 2.
If I was those track guys up there^^^would go with Type 1 though, but I think that plastic thing on the bumper wuld help the air flow passing from Type 2.
Type 1 just passes that plastic bumper thing. Get out of my way.
Doesn't it bolt on to the sway bar? That would be enough to cover the gaps, no?
Jeremy, look at the size of this thing.
Air would rip off my bumper
https://i.imgur.com/xpGSv4D.jpg
Shit
Not again
I just saw this page
Old 10-30-2014, 08:59 PM
  #453
MEKO's Avatar
Birrrrrrr!!!! Pata pata pata pata
I love that gravel machinegun
I don't really know what bump steer is.
Googled but wouldn't alignment get rid of it? Anyways, I am getting lost when it's suspension.
Lowering the TL didn't end up well, so I am staying away from it.
Yes thought of getting TRD lowering springs but my pain being pretty strong in the past made me stop even thinking about it
Ohh I got something to show you guys... wait
Posted it on
The "Photos You've Taken of Exotic/Desirable Cars" Thread
Old 10-30-2014, 10:21 PM
  #454
civicdrivr's Avatar
To get the most out of the aero, you don't want the air to cling to the bumper. That causes drag, disrupts the air coming off the trunk lid, and reduces down force.
This is going to sound crazy, but you don't want to speed the air up under the car. Fast air = high pressure = lift. Look at those crazy high speed race cars from Auto Union and MB back in the 30s; they were super slippery but preferred to be airplanes.
What you do want is slow air. Slow air = low pressure = downforce. The flip side is that you don't want to slow it down too much, as that would cause the transmission and differential to overheat.
The diffuser basically causes the air coming out from under the car to stay low. You can see it in the CFD analysis. That helps pull the air off the back of the car, which creates the low pressure area just behind the car, which gives you down force. Spoilers do the same thing, but they cause more drag in the process.
I'm still reading up on aerodynamics, so I'm not going to pretend I know everything about it. But its a topic that really caught my interest over the past year and I've been reading up on it anytime I can.
The following 2 users liked this post by civicdrivr:
Costco (10-31-2014), MEKO (10-31-2014)
Old 10-30-2014, 10:22 PM
  #455
civicdrivr's Avatar
Oh, and yes it does use the lower sway bar bracket bolts.
Old 10-31-2014, 12:18 AM
  #456
MEKO's Avatar
True, I agree with all those magic things.
Even though, I know that fast air means high pressure, I always thought that rear difuser makes the air faster Which would be stupid as you mentioned.
How does that sharp difuser slows down the air to make tires feel more weight at the rear....? I don't know. Magic
Those front splitters would really reduce the air cooling the tranny and diff then...
Old 10-31-2014, 01:10 AM
  #457
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Whachu know about aero? you need to ask the master of Aero!
Old 10-31-2014, 08:04 AM
  #458
civicdrivr's Avatar
Originally Posted by MEKO
http://i0.kym-cdn.com/entries/icons/original/000/013/034/yeahsciencebitch.PNG
Front splitters do reduce air cooling the tranny and diff, but not a whole lot, especially at sub-300whp. It's when you get up to 4-500hp, on track, for 30 minute sessions that the tranny starts to cry. The diff is actually pretty stout, so as long as you're running a good fluid, you'll be fine. You could always get one of those finned diff covers.
I believe the reason that the air slows down is not due to the sharpness of the diffuser, but where it is directing the air to go. Since it pushes the air further away from the rear of the car, that takes out of the air pocket right behind the bumper/trunk lid, which causes the air to slow down.
So yea, witchcraft.
MEKO (11-01-2014)
Old 10-31-2014, 08:10 AM
  #459
civicdrivr's Avatar
FYI - I also have the JDM y0 underpanels to smooth flow out under the car. If I keep the car, I'm getting their front splitter with tie rods.
MEKO (11-01-2014)
Old 10-31-2014, 08:24 AM
  #460
there is no fkng way Morgan just openly posted that my fkng TL is not a racecar. WTF.
Old 10-31-2014, 08:33 AM
  #461
civicdrivr's Avatar
You had a racecar, but you decided to be a responsible adult instead.
Never go full responsible adult.
usdmJON (11-04-2014)
Old 10-31-2014, 09:09 AM
  #462
hey, my TL is manual and when I go reverse it's RWD. Give me SOME cred here, bruh.
Old 10-31-2014, 09:51 AM
  #463
civicdrivr's Avatar
That doesn't make it a sports car. Sports boat, maybe.
Old 10-31-2014, 10:49 AM
  #464
even has a Suisse flag!
The following 2 users liked this post by rockstar143:
civicdrivr (10-31-2014), MEKO (11-01-2014)
Old 11-01-2014, 03:56 AM
  #465
MEKO's Avatar
Size matters Costco, the longer it is the better it is. We need Type 1
I was going to pull the trigger on those JDM panels but... gave up as always
"Never go full responsible adult"
Old 11-01-2014, 01:00 PM
  #466
MEKO's Avatar
41:37 For BRZ
I loved that Dynamics Class but we didn't test any cars in a channel
Just blocks hahaha
Old 11-04-2014, 02:58 PM
  #467
I drive a Subata.
JS + XES's Avatar
Found a GT wing that fits your personality.
Old 11-04-2014, 03:05 PM
  #468
civicdrivr's Avatar
Someone's been browsing FT86Club
Old 11-04-2014, 11:13 PM
  #469
MEKO's Avatar
^Ooo yis
Only thing I love in that forum is, what did you do to your car today thread haha
I went over all 53234 pages
Subata driver, why you do dis to me
I want this
Old 11-04-2014, 11:16 PM
  #470
MEKO's Avatar
It snowed on sunday, today weather was great outside
This shit is getting weird
And just passed 17k miles today.
Dammit
I am positive on nameless, I will do it. Especially now they have new design front pipe I guess, better fit, no rattle or anything.
And waiting to hear more about that new grimspeed intake. Let's see how people will like it or not.
Old 11-04-2014, 11:32 PM
  #471
Costco's Avatar
I got in on that Grimmspeed groupbuy. Can't freaking wait. Should be coming in some time this week!!!!!
Old 11-04-2014, 11:38 PM
  #472
MEKO's Avatar
I am jelly
First the header I want, now this
Ok let me know, if you say go for it I'll do it.
But I don't want to delete the sound tube dammit
One member already received his
Old 11-05-2014, 02:18 AM
  #473
I drive a Subata.
JS + XES's Avatar
Woah.
Linky?
Old 11-05-2014, 02:26 AM
  #474
この道は毛むくじゃらのマンコだらけ..
onebadna1nsx's Avatar
oooohhh looks goood!!
Old 11-05-2014, 06:07 AM
  #475
civicdrivr's Avatar
I think it made 7whp over stock on an independent dyno. Not sure if that's tuned or not though.
Old 11-05-2014, 07:14 AM
  #476
  #477
stock intake really that restrictive?
Old 11-05-2014, 07:15 AM
  #478
I heard Morgan's motor was breathing better than any other FRS at one point
civicdrivr (11-05-2014), Costco (11-05-2014)
Old 11-05-2014, 08:53 AM
  #479
civicdrivr's Avatar
I have a super top secret way of opening up motors to get the most out of them.
But no, the stock intake is actually pretty damn good. To put it in perspective, a high flow filter and a smooth intake tube (instead of the stock ribbed one) will net 4-7whp. I'm curious to see what the Grimmspeed intake will do tuned.
rockstar143 (11-05-2014)
Old 11-05-2014, 08:57 AM
  #480
Isn't that a more cost effective option than reinventing the whole wheel? Is it for bragging rights?
