Passat TDI Turbo Blown?
Old 07-28-2015, 05:02 AM
Stage 1 Audi S5
1StGenCL's Avatar
Received 1,157 Likes on 682 Posts
Mom has a 2013 Passat TDI with 177k on it and recently it went into limp mode so it was towed. Dealer is saying that the turbo needs to be replaced for $2,500. I know the dealer isn't the best place but beyond that, it seems that the HPFP ($8-10k to fix I'm reading) and the turbos go on these all the time, is it worth fixing? VW knows there is a problem and extended the warranty to 120k but clearly she is out of it and they don't care.
She is livid because she drives a lot and wanted a car that got good mileage and would be problem free but this is clearly not the case, it has had numerous, expensive problems. People are reporting turbo failure at as little as 1,000 miles and some are having more than one fail within a few thousand miles, any insight here?
Old 07-28-2015, 05:50 AM
Received 16,260 Likes on 11,971 Posts
VW's and GM's are experiencing blown engines from turbos. (a co-worker had his ATS 2.0T's engine replaced because it blew from pre-detonation due to heat or low octane)
You would think VW would have it down PAT by now
Old 07-28-2015, 06:14 AM
Jakes_tl's Avatar
With 177K I don't think that is bad for a turbo to go out. At that mileage anything can go wrong.
The following 3 users liked this post by Jakes_tl:
1killercls (07-28-2015), neuronbob (08-02-2015), YeuEmMaiMai (08-01-2015)
Old 07-28-2015, 06:22 AM
they are blowing, WAAAAAAAAAAAAAAAAAY before that.
look at the GTI's.
some dont even get through the dealer without the engine blowing.
if i recall, there was a certain vin range for the newest GTI's that blew.
my co-workers ATS blew with less than 20,000 miles on it.
Old 07-28-2015, 06:23 AM
always run premium fuel and make sure that engine ISNT pinging/knocking.
Old 07-28-2015, 06:24 AM
of course it's cheaper to replace the engine than to do a major recall.
my co-worker was like....but its being replaced with same engine....it'll do it again.
and he came from an 08 335i. LOL he should have kept the bimmer, as he didnt have any trouble with HFPP
Old 07-28-2015, 06:42 AM
AZ Community Team
Legend2TL's Avatar
Received 4,026 Likes on 2,504 Posts
Is it a 2003 or a 2013? 177K is alot of miles for a 2 year old car. I replaced the turbo on a friend's gas 1.8T 1999 Passat, if not for the side turbo bracket it would have been a easy job (~3 hours). The friend got a new replacement turbo off eBay, despite being only $240 it has been OK for the past couple years.
As for your mom's car, if nothing else was wrong (HPFP) I would replace the turbo. From what I've read the newer VW diesel motors last awhile.
+1, 177K miles is not bad for a turbo considering their environment.
You know this is a diesel engine right?
It's supposed to detonate, that's the operation of diesels.
Old 07-28-2015, 06:44 AM
sorry, didnt know.
i was going off the GM turbo engine.
Old 07-28-2015, 07:04 AM
Jakes_tl's Avatar
I never did care for german cars but still I never knew GTI's and the ATS's were that bad.
I think this is the reason that Honda just doesn't want to use turbo's because reliability really isn't the same with forced induction.
Old 07-28-2015, 08:30 AM
2024 Honda Civic Type R
RPhilMan1's Avatar
Received 1,454 Likes on 923 Posts
That is simply not true. Don't paint with such a broad brush.
And please, Mr. Unnecessary apostrophe. One turbo, two turbos.
Old 07-28-2015, 08:39 AM
Jakes_tl's Avatar
I didn't say it was true or that is a fact, just what I am thinking.
Old 07-28-2015, 09:19 AM
AZ Community Team
Legend2TL's Avatar
You're not alone, I've thought the same for Honda and turbo's.
Turbos typically are not motor lifetime components. The bearings and seals are in a very harsh environment and operation.
Old 07-28-2015, 11:28 AM
Received 5,831 Likes on 3,852 Posts
If properly maintained, the turbo should last the life of the vehicle. The bearings are oil and the seals are just as good as any other engine seals.
That said, there are tons of people who don't change their oil, use the wrong oil, run 87 instead of 91, and otherwise abuse their cars.
That said, if OP's mom drove this car for 177k miles and the turbo just blew that's not bad. A $2500 bill for a car that old is not unheard of.
Old 07-28-2015, 11:34 AM
9 mpg.
D's Up's Avatar
I thought 177k was a typo. How'd she managed to rack up that many miles in 2-3 years? At that mileage I'd expect things to start breaking and become costly. Dump the car and ask mom to pick up the new Camry. 200k trouble-free miles in the blink of an eye.
Old 07-28-2015, 11:46 AM
AZ Community Team
Legend2TL's Avatar
No other oil seal on a piston engine comes close to the environment of the turbine side of a turbo. The temp and pressure create problems for a flexible seal on the shaft to allow oil to circulate to the bearings. Add in the extreme heat that can coke the oil to the bearings and 100k rpm.
They're hard requirements to get turbo's to last for the 100k, let alone 200k.
Water cooled bearing help and electric water pumps for heat soak back after the engine shuts down but turbo's are rough on their bearings and seals.
Do agree alot of turbo life depends on usage and maintenance. It helps to use synthetic oil, waiting for engine warmup before using alot of boost, then taking it easy on the throttle before shutting down the motor to allow the oil and water to cool down the turbo some.
The KKK T03 turbo I replaced had water jacket but no electric water pump and had a seized shaft at 130k miles. 177k is pretty good, best I remember is a colleagues wife who got 200k on her Saab turbo before it's seals and bearings failed. She was a nuclear physicist and knew about driving and maintaining a turbo. Never heard of any turbo making it to 300k miles.
Jakes_tl (07-28-2015)
Old 07-28-2015, 01:39 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
I'd go aftermarket turbo.. a big ass one.
Old 07-28-2015, 01:41 PM
Majofo's Avatar
benjaminh (07-28-2015)
Old 07-28-2015, 01:47 PM
AZ Community Team
Legend2TL's Avatar
Old 07-28-2015, 02:15 PM
GEEZER
1killercls's Avatar
Received 2,214 Likes on 1,418 Posts
I have a 2007 B7A4 2.0T with 70k miles. I have a Stage One tune, test pipe and otherwise pretty stock. I drive it like a raped ape everyday and other than having to buy two new Cooling Fans and a control module last year the car runs better than the day I bought it.
I go full syn oil changes every 8k miles, have had every little recall done, (Cam Follower comes to mind) and it is a great car. Cars break...car break more often with more miles on them.
Old 07-28-2015, 03:46 PM
Stage 1 Audi S5
1StGenCL's Avatar
To clear up a few things, yes, the car has 177,xxx miles and it is indeed a 2013. She drives a lot and was looking for a car that got good mileage and would last awhile. We have had numerous diesel trucks to pull the horses and they go forever, turbos don't blow (well unless you count the crappy engine ford used a few years ago, everything blew).
I guess I don't understand turbos, I don't expect it to blow with 200K, sorry I don't. As you can see, I've been on here forever and love cars but never realized turbos go like this, my fault BUT I feel I'm way more educated on cars then the average consumer so I can't imagine people expect this.
Big question is, these turbos are blowing all over and as low as 1,050 miles so I'm worried it could go againin the next few thousand plus it seems the fuel pump goes A LOT and that is 8-10k to fix, just wanted some first hand experience. Yes, VW forums are better but I love you homos :gheyhug:
Old 07-28-2015, 03:54 PM
brahs be jelly
MTEAZY's Avatar
Are you being serious?
It's VW.
Old 07-28-2015, 03:57 PM
Jakes_tl's Avatar
A turbo blowing at 177K is not bad at all on the other hand turbos blowing at 1,500 miles or 10,000 miles that is BS for sure - sounds like a major flaw for sure.
Old 07-28-2015, 04:03 PM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Damn your mom must be driving from Florida to Cali 3 times a month...
177k and blown turbo I don't see anything strange about that.
Maybe it's time to get something else.
Old 07-28-2015, 04:27 PM
seizure force field!
v6cord2k5's Avatar
Probably time to go to a Jetta SEL TDI. No such turbo issues being reported on the TDI forums.
Old 07-28-2015, 04:34 PM
Turbos regularly last over 100k miles no problem, I'm not sure what you're talking about. If they didn't, it would be in the preventative maintenance for the car.
Also, the bearings on the turbine are not physical bearings, it's a layer of oil that the shaft floats on. This oil is constantly pumped by as the turbine is spinning to get cooler oil in there all the time. Modern cars run the oil pump after to get the hot oil out of the turbine housing and get cooler oil in there. Older cars had to have turbo timers to have the same effect otherwise you'd get burnt or gummed up oil in the turbine housing due to the hot oil sitting and not cooling off.
Water cooled ones help more still.
hory sheet!
I don't think the turbo going at 177k is a huge deal. If she's had that many trouble free miles then a $2500 repair at that high of mileage is not a big deal to me.
Why is the fuel pump a $10k repair?
Old 07-28-2015, 04:41 PM
v6cord2k5's Avatar
OP mentioned "it has had numerous, expensive problems."
Premature turbo failures are common on Passats. So much so that there is a running thread on TDI Club where owners document their failures. OP's mom should have dumped it while she had the chance.
Old 07-28-2015, 05:19 PM
Stage 1 Audi S5
1StGenCL's Avatar
There are indeed running threads on the turbos and I believe the fuel pumps so I'm leery of having her getting it fixed. The car is worth nothing and she hates it but it seems to sell it, she should get it fixed.
I just can't tell if they have addressed the issue because if it blows the new turbo in a few thousand miles, she may drive the car through the front window of the dealer, limp mode or not. As for the pump, I haven't read deep into it but I keep seeing 8 plus for the repair but maybe it's old.
She has had a lot of mechanical issues and has argued her way out of a few of the bills and warranty covered some but it seems to eat money. I get she travels a lot but she has been through Acuras and a Lexus with crazy mileage with few to no problems.
Old 07-28-2015, 06:05 PM
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
get her a Prius... but she probably need the battery changed within 1 year... which will probably cost more than 1 turbo.
I don't see any realistic alternatives for someone who drives 177k miles in 2 years. that is 1.5 oil change per months and new tire evey 5-6 months.
Old 07-28-2015, 06:07 PM
oonowindoo's Avatar
just forget about the VW and maybe rent her a car with unlimited mileage is actually a better alternative and the rental car company probably will ban her after a few months due to excessive mileage on an unlimited mileage car.
Old 07-28-2015, 07:51 PM
Evil Mazda Driver
PortlandRL's Avatar
Are you referring to the joy that is dealing with a high-mileage 6.0 Powerchoke? Half our bus fleet has that engine and let me say there's a special corner in hell reserved for the man who came up with the variable-geometry turbo in that thing. I had one conk out on me on one of our oldest buses and from a stop to about 25 mph, I was using the accelerator as an on-off switch. Sometimes I would left foot brake it and rev it up to about 2500 rpm before the light turned green just to get semi-normal acceleration out of it.
The bus lasted about six hours of my eight hour route and after running it up a hill with a 14% grade, I quite literally killed it. The thing sounded like it was running on five cylinders.
Old 07-29-2015, 07:18 AM
Stage 1 Audi S5
1StGenCL's Avatar
Haha She writes it all off and makes really good money with her position, just lots of driving but she's her own boss. She goes through cars pretty quickly though, she was hoping to get another 100k or so out of this.
Portland - Please tell me you drive a short bus
Old 07-29-2015, 07:49 AM
AZ Community Team
Legend2TL's Avatar
There are physical bearings on turbo's, take one apart and you'll see. They are typically sleeve bronze or ball bearings. The oil lubricates and cools the bearings.
http://www.turbos.bwauto.com/product...ingSystem.aspx
Radial bearing system
With a sleeve bearing, the shaft turns without friction on an oil film in the sleeve bearing bushing. For the turbocharger, the oil supply comes from the engine oil circuit. The bearing system is designed such that brass floating bushings, rotating at about half shaft speed, are situated between the stationary centre housing and the rotating shaft. This allows these high speed bearings to be adapted such that there is no metal contact between shaft and bearings at any of the operating points. Besides the lubricating function, the oil film in the bearing clearances also has a damping function, which contributes to the stability of the shaft and turbine wheel assembly. The hydrodynamic load-carrying capacity and the bearing damping characteristics are optimised by the clearances. The lubricating oil thickness for the inner clearances is therefore selected with respect to the bearing strength, whereas the outer clearances are designed with regard to the bearing damping. The bearing clearances are only a few hundredths of a millimetre.
The one-piece bearing system is a special form of a sleeve bearing system. The shaft turns within a stationary bushing, which is oil scavenged from the outside. The outer bearing clearance can be designed specifically for the bearing damping, as no rotation takes place.
Axial-thrust bearing system
Neither the fully floating bushing bearings nor the single-piece fixed floating bushing bearing system support forces in axial direction. As the gas forces acting on the compressor and turbine wheels in axial direction are of differing strengths, the shaft and turbine wheel assembly is displaced in an axial direction. The axial bearing, a sliding surface bearing with tapered lands, absorbs these forces. Two small discs fixed on the shaft serve as contact surfaces. The axial bearing is fixed in the centre housing. An oil-deflecting plate prevents the oil from entering the shaft sealing area.
As for lifespan, a colleague's S4 ate both turbo's by 50k who followed maintenance and always used synthetic oil. Also let engine idle for a couple minutes before shutting down.
Turbo's should last over 100K, but they are wear items.
One thing that can be done to a turbo is rebuild it with new bearings and seals. My friend's Passat KKK turbo was seized and the compressor made contact with the housing. Once the balanced compressor or turbine make contact they are ruined.
Old 07-29-2015, 11:35 AM
oonowindoo's Avatar
it just does not sense to buy anything expensive if she is going through cars every 2 years and it is not a lease.
Try to convince her to get a hyundai or Kia. she can test it out for us how reliable the new KIA/HYundais really are.
Old 07-29-2015, 01:05 PM
Stage 1 Audi S5
1StGenCL's Avatar
While I get what you are saying, if you were spending that much time in a car, wouldn't you want a nice one? She was worried about going to a Passat in terms of comfort and features and after this experience, I know her next car will be nicer. Just trying to figure out if this is worth fixing.
Old 07-29-2015, 01:08 PM
Majofo's Avatar
Fix it, pass it. Don't go FI on the next one. There is just inherent wear when dealing with boost. 177K really isn't a lot when you consider it probably wasn't under boost for much of those miles. But it still saw consistent heat and wear. RLX with upgraded tires?
Old 07-29-2015, 01:17 PM
oonowindoo's Avatar
as much as i dislike RLX, i think that might be a good buy, especially used ones. Their resale value with low mileage makes it a good buy.
Old 07-29-2015, 01:51 PM
Design and Function of a Turbocharger - Bearing system | BorgWarner Turbo Systems
They are not and if you read the quote you posted, it explicitly says what I've been telling you. Ball bearings have this horrible problem of expanding and contracting with heat. Floating a sleeve (and therefore the turbine shaft) on a film of oil does not have this issue. The problems start occurring when there's sludge buildup in the housing and therefore reducing oil pressure to the shaft which causes the sleeves to grind on the housing and fvck all kinds of shit up. With proper maintenance/use (use the right oil, change it often, run the engine for a bit after you stop, do a longer cool down period after hard driving, etc), this does not really happen and therefore the bearings never fail mostly because the bearing is actually a film of oil which is constantly pumped through. Newer turbo cars will run the oil pump for a period of time until the oil temp in the turbo reaches an acceptable level to prevent sludge.
The S4 ate all kinds of parts all the time, it's not really a stellar example of reliability by any measure.
I agree with your last point, the issue is low oil pressure to the shaft which cause the sleeves to grind against the housing. Once that happens, you're screwed. The cause of the low oil pressure is not running your engine/oil pump for ~30s after stopping to pump fresh, cool oil into the turbine housing. Not doing that causes the oil to sludge up in the housing over time.
Now all this being said, the seals can and do leak but if the pressure is maintained in the housing, it's just the same as any other leak in that it shouldn't be a problem other than checking your oil level. I'm pretty sure the seals can be rebuilt too.
The following 2 users liked this post by SamDoe1:
benjaminh (07-29-2015), RPhilMan1 (07-30-2015)
Old 07-29-2015, 02:16 PM
oonowindoo's Avatar
Can we not turn every thread into a technical bulletin?
All i need is look at my other monitor right now to look at the endless spreadsheet if i want to see technical stuff.
Old 07-29-2015, 02:23 PM
benjaminh's Avatar
Not worth fixing imho.
How about an Acura TLX? Nicer than a Passat inside and out, almost certainly more reliable, and only costs a bit more.
PS I really like the tech stuff. Keep it coming, as far as I'm concerned lol. Turbos are coming to Acura very soon....Probably for model year 2017.
Old 07-29-2015, 02:40 PM
lol, I'm in the technical mindset right now. Working on gear drives.
Quick Reply: Passat TDI Turbo Blown?
