1997 Acura El - Block Heater Install
Old 09-22-2016, 10:41 PM
New Member
jay33's Avatar
I need to install a block heater on a 1997 EL (I'm quite certain it doesn't have one). I have located the appropriate part number (zerostart 310-0006). The part catalog notes that it is threaded and would be installed in the LR (I believe Left/Rear position - so I believe driver side near back of engine). Am I correct to assume that as it is a threaded part that it isn't really a 'frost plug' I am needing to bang out but something that is also threaded? Has anyone done this job on a same/similar Acura and, if so, how difficult was it? Is it something that a mechanically inclined person can likely do themselves? Do you need to remove anything to get to the work area and/or is it particularly difficult to access? Thank you for any advice.
gavriil
01-18-2024 10:53 AM
EE4Life
06-27-2016 06:19 PM
kurtatx
02-15-2016 09:48 AM
EE4Life
09-11-2015 10:13 PM
EE4Life
01-07-2015 08:24 PM
Quick Reply: 1997 Acura El - Block Heater Install
