Cameras & Photography Because there aren't already enough ways to share photos...
Post Processing Thread
Old 12-05-2014, 10:13 AM
  #121
Received 5,829 Likes on 3,850 Posts
Need some suggestions or (even better) a good write up on using layer masks in Photoshop.
Tools available: Lightroom 1.4 (), Photoshop CS3, Photomatix
I have a photo and there are several distinct areas that I would like to treat differently.
In the picture, there is an area I wanted to be more vibrant, so I created a single exposure HDR of the image. The HDR is toned so that the distinct area appears as desired, but the remainder of the HDR image is too "hot" for my taste.
I opened both the original image and the HDR image in CS3 and placed each one on its own layer.
Then, I added a layer mask to the HDR layer and revealed only the distinct area I wanted to show as more saturated.
Problem is, I have another area that I need to treat differently (hue, saturation, levels) and I don't know if I need to create a separate layer with a mask for EACH different manipulation (hue, saturation, levels), or if I can do them all in one, or if I can do them all in the same layer as the HDR mask.
Ideas?
There are two ways to do this. One is simple and far more effective, the other takes a bit more work.
Method 1:
1.) Go to Amazon.com
2.) Place order for Lightroom 5
3.) Install software
4.) Do everything you just described and much more with total ease.
Method 2:
Use a layer mask in PS. You need to duplicate the base layer, insert a layer mask into duplicated layer, make the adjustments you want for the areas you want and erase back the layer mask where you don't want those adjustments on.
Of the two options, getting LR5 will do a much better job and $77 isn't much for what you get out of it. After using the newer versions of LR, I haven't even touched PS at all. Doesn't help that I only have CS2 but whatever. I only hope and wish LR6 finally comes with the ability to do merge to HDR and generate panoramas without PS intervention.
stogie1020 (12-05-2014)
Old 12-05-2014, 11:48 AM
  #122
Needs more Lemon Pledge
stogie1020's Avatar
Received 2,000 Likes on 1,173 Posts
OK, so thus far I have basically done SamDoe1's method #2. I created a duplicate layer of the original for each adjustment I wanted to make, created a layer mask on each of those duplicate layers, and then made the adjustment needed to each layer.
I think I have it where I want it.
Thanks guys! I have a giant book about photoshop, just never got past the first chapter...
Now, I need to figure out how to crop Italiano's kids into the shot and it will be perfect!
Mizouse (12-05-2014)
Old 12-05-2014, 12:04 PM
  #123
asianspec's Avatar
Received 1,097 Likes on 831 Posts
Old 12-05-2014, 12:13 PM
  #124
Old 12-05-2014, 01:01 PM
  #125
'08 MX5 GT 6spd.
MarbleGT's Avatar
Received 1,192 Likes on 485 Posts
Couple of some recent lengthy edits.
Orig.
Final
IMG_1387 by JordanColePhotos.com, on Flickr
C5 Post-Final Edit by JordanColePhotos.com, on Flickr
Old 12-05-2014, 01:12 PM
  #126
^ Nice! I'm not really a fan of the replaced backgrounds but well done nonetheless.
I'll put up a few before and afters this weekend.
Old 12-05-2014, 01:25 PM
  #127
stogie1020's Avatar
Nice work marble!
Old 12-05-2014, 01:29 PM
  #128
Mizouse's Avatar
Received 2,773 Likes on 1,976 Posts
Didn't I kind of sort of mention this too?
Old 12-05-2014, 01:30 PM
  #129
'08 MX5 GT 6spd.
MarbleGT's Avatar
Thanks!
Old 12-05-2014, 01:53 PM
  #130
nnInn
jupitersolo's Avatar
Received 1,084 Likes on 646 Posts
You might just want to stick to chalk and cave walls.....
:wink:
Old 12-05-2014, 02:31 PM
  #131
stogie1020's Avatar
Don't be so sensitive, Italiano...
I said thanks!
:wink:
how to apply an unsharp mask to a cave wall please?
The following 2 users liked this post by stogie1020:
jupitersolo (12-05-2014), Mizouse (12-05-2014)
Old 12-05-2014, 03:23 PM
  #132
Forgot to toss this in before but you can reduce the opacity of each of those layers in order to tweak the effect as a final once over before saving.
Old 12-05-2014, 03:27 PM
  #133
stogie1020's Avatar
Thanks!
Old 10-21-2015, 04:24 PM
  #134
stogie1020's Avatar
Had some bad CA that LR wouldn't remove and found this really quick method in PS to manually remove the CA.
Old 12-03-2015, 11:57 PM
  #135
I shoot people
is300eater's Avatar
Received 2,783 Likes on 1,409 Posts
so... this was taken back in Jan of 2012, and there were these damn power lines have always bothered me... I've since learned how to remove them in Photoshop
<a data-flickr-embed="true" href="https://www.flickr.com/photos/63271580@N00/23139900859/" title="Gastown, Downtown Vancouver BC"><img src="https://farm1.staticflickr.com/768/23139900859_0f3ab4f85f_b.jpg" width="1024" height="488" alt="Gastown, Downtown Vancouver BC"></a>
Old 01-21-2016, 10:24 PM
  #136
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
So I've been trying to find a higher-end dog clothing brand website to see how they demonstrate their product images.
http://www.rubyrufus.com/
Any suggestion on how to shoot a product to get this result?
And for this image with the dog, how do you get that high-key, washed out look? Seems like this style is used by a lot of brand names goods. I would love to get something close to this.
Old 01-21-2016, 10:29 PM
  #137
The Third Ball
Sarlacc's Avatar
Received 4,824 Likes on 2,571 Posts
You need to create a white seamless back drop to shoot. Needs to be bright and lit with a flash to get deep depth of field and very little shadow. The rest of the shadows can easily be photoshopped out.
Old 01-21-2016, 10:51 PM
  #138
I drive a Subata.
JS + XES's Avatar
Something like this?
For the clothing, I would need to lay it on the ground, so do I open up the top and block all four sides and put the lamps?
Old 01-21-2016, 10:56 PM
  #139
The Third Ball
Sarlacc's Avatar
Sort of...lots of ways to skin that cow:
https://www.google.com/search?q=tabl...w=1191&bih=812
Old 01-21-2016, 11:05 PM
  #140
I drive a Subata.
JS + XES's Avatar
Thank you!
Guess I need something like this..
Old 01-22-2016, 02:52 AM
  #141
Mizouse's Avatar
Make sure you get that old school CRT monitor too
JS + XES (01-22-2016)
Old 01-22-2016, 09:54 AM
  #142
stogie1020's Avatar
No need to get all fancy if you don't want to. I have made a light box out of foam core, tissue paper, and push pins. Two halogen shop lamps and a speedlight for lighting.
Might have cost me $20 total...
Setup:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/jefford_e/3280194961/in/album-72157622260196922/" title="IMG_0604 -jpeg"><img src="https://farm4.staticflickr.com/3312/3280194961_1b59f6a532_z.jpg?zz=1" width="640" height="480" alt="IMG_0604 -jpeg"></a>
Results:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/jefford_e/3280195017/in/album-72157603778324312/" title="IMG_6698 -jpeg"><img src="https://farm4.staticflickr.com/3496/3280195017_f829b6470f_z.jpg?zz=1" width="640" height="427" alt="IMG_6698 -jpeg"></a>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/jefford_e/3280195207/in/album-72157603778324312/" title="IMG_6706 -jpeg"><img src="https://farm4.staticflickr.com/3473/3280195207_535667e011_z.jpg?zz=1" width="427" height="640" alt="IMG_6706 -jpeg"></a>
The reflective glass bottle was tough, and frankly I lost interest and time before I perfected it, but this bottle was my least successful attempt...
<a data-flickr-embed="true" href="https://www.flickr.com/photos/jefford_e/3281015482/in/album-72157603778324312/" title="IMG_6725 -jpeg"><img src="https://farm4.staticflickr.com/3424/3281015482_119d2c67ca_z.jpg?zz=1" width="375" height="640" alt="IMG_6725 -jpeg"></a>
Old 01-22-2016, 10:00 AM
  #143
stogie1020's Avatar
Hell, for shots of your dog wearing the items, you could even tape a white sheet or white roll paper to the top edge of your dining room table and let it drape down to the floor and then towards you (away from the table) to create a seamless background.
Put the dog on the paper/cloth and fire away. No distracting backgrounds (unless you want them), if you keep it taught you wont have too much shadow in the background (you can light it separately like Sarlacc said to prevent this even more) and then fire away at the product shots.
Old 01-22-2016, 01:58 PM
  #144
While having those lights is cool for preview, you'll want strobes for actual lighting. Especially if you're shooting moving targets.
If you want to stay on the cheap with constant light, then you'll need a tripod and a remote release and forget about moving targets.
Old 01-22-2016, 02:21 PM
  #145
stogie1020's Avatar
Agreed (the gin bottle only moved when I took a sip), but it seems like he can get the dog to sit still for a brief period.
Old 01-22-2016, 07:58 PM
  #146
I drive a Subata.
JS + XES's Avatar
Thank you guys!
Just went to Michaels and picked up a bunch of stuff for the set up. Just need to pick up some lamps and bulbs from Home Depot tomorrow. Will make them this weekend.
Trying to find some decent tripod as well.
02-25-2020 09:57 AM
urbtsx
03-04-2017 06:53 PM
neuronbob
09-19-2015 10:45 AM
Da_Web_Head
09-11-2015 06:36 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Post Processing Thread
