TechArt: GT Street (Based on Porsche 911 Turbo) News
Old 09-17-2011, 01:25 PM
  #81
Coal
05TLdcc's Avatar
Old 09-27-2011, 10:23 AM
  #82
Yumcha's Avatar
Received 22,649 Likes on 13,889 Posts
Post 2011 TechArt Porsche GTStreet RS Power Kit
Press release...
With its power of 700 hp and 900 Nm torque the TECHART GTStreet RS based on the Porsche 911 GT2 RS made the visitors of the Frankfurt Motor Show excited. Now TECHART presents another exciting power kit with more then 700 hp. The TA 097/T3 for the Porsche 911 Turbo ensures excellent acceleration figures and a new top speed for the super sports car.
Equipped with a plus of 174 kW (200 hp) and 230 Nm torque compared to the series model the 3.8-liter boxer engine fulfils impressive 515 kW (700 hp) and a maximum torque of 880 Nm. Excellent performance data underline the experience and skill of the TECHART engineers in the further development of the engine system. With fascinating 2.8 seconds for the classic sprint from 0 to 100 km/h the super sports car undercuts the fabulous time of the power kit TA 097/T2 by a tenth. The 200 km/h barrier is broken in 9.0 seconds. The forward propulsion stops not until impressive 352 km/h.
The engine conversion involves the installation of the TECHART sport air filter, TECHART manifolds, the TECHART Turbo chargers VTG, the TECHART high performance intercoolers as well as the TECHART engine styling package in carbon-fibre. All modifications are perfectly attuned to each other via the reprogrammed engine management.
  #83
Yumcha's Avatar
Old 10-01-2011, 10:20 PM
  #84
Coal
05TLdcc's Avatar
I have a blank check..... Give me a white and black one
Old 04-08-2014, 09:46 PM
  #85
Yumcha's Avatar
Recent variant...
Old 04-09-2014, 12:41 AM
  #86
この道は毛むくじゃらのマンコだらけ..
onebadna1nsx's Avatar
Yesss plzzz!!!
Old 12-14-2016, 04:39 PM
  #87
Yumcha's Avatar
Post 2016 TechArt Porsche 911 Turbo GTstreet R
Press release...
The new TECHART GTstreet R will thrill you. Every second. On the racetracks of the world, or in the streets of metropolitan hotspots – the GTstreet R occupies center stage. Like its legendary predecessors, the new GTstreet R is representing the ideal symbiosis of outstanding performance and unrestricted suitability for daily use. Based on the Porsche 911 Turbo and 911 Turbo S (991), TECHART has built a sportscar that sets new standards. Again.
Exterior design and aerodynamics:
The expressive, lightweight carbon fiber body parts put the 911 Turbo in the spotlight. At the same time, the aerokit optimizes the road handling of the GTstreet R by increased downforce. Active aerodynamics provide a total downforce of 321 kg at 300 km/h in Performance Mode. This enables breathtaking lateral acceleration and driving stability at all speeds.
The carbon fiber GTstreet R front apron with its active front spoiler lip optimizes the airflow onto the water- and oil coolers with additional air intakes. A central air outlet helps to reduce the aerodynamic lift. The integrated front lights are tastefully surrounded by carbon airframes. Laterally positioned flaps increase the downforce and reduce the drag coefficient at the same time. The lightweight carbon front lid, which bears a three dimensional TECHART logotype at its inside, underlines the vigorous appearance of the TECHART GTstreet R with its dynamic shape.
The carbon front fenders feature front wheel arch air outlets. Both, the heat generated by the brakes as well as the overpressure produced by the turning wheels are discharged through racy visible carbon slats. The carbon side skirts continue the GTstreet R design line and interlink the extended wheel arches at front and rear aesthetically. For maximum airflow to the intercoolers, the rear side sections of the GTstreet R feature powerful carbon air intakes.
The rear apron incorporates distinctive air outlet ducts – typical for the TECHART GTstreet styling. A trim panel made of visible carbon fiber creates visual impact by connecting the three dimensional taillights. A carbon rear diffusor frames another GTstreet R highlight: the high performance sport exhaust system. Four central carbon fiber tailpipes release the exhaust fumes while generating an extraordinary and powerful soundscape.
On top of the engine lid, the active GTstreet R rear wing catches the eye with its contoured carbon wing profile, carbon side panels and two aerodynamic carbon fiber winglets. In Performance Mode, the GTstreet R wing is raised automatically and its angle is adjusted by up to 15 degrees. A large aerodynamically shaped carbon air intake unit ensures sufficient air supply for the engine at any time.
Driving dynamics & performance:
To provide the required grip, TECHART fits enlarged tire dimensions to the GTstreet R. The road contact is ensured by 265/35 ZR 20 tires at the front (also available: 265/30 ZR 21) and 325/30 ZR 20 tires at the rear (optional: 325/25 ZR 21). Customers can chose among 20-inch or 21-inch wheels. The forged 20-inch TECHART Formula IV Race centerlock wheels are equipped with roadlegal UHP tires. The 21-inch TECHART Formula IV wheels feature a weight optimized rim construction and are equipped with road tires. Both wheels can be individually customized in color and surface finish.
TECHART provides different options for the chassis such as the TECHART VarioPlus coilover suspension with PDDC connectivity or the TECHART Noselift front axle lift system. TECHART Noselift makes common obstacles like parking garages, ramps or speed humps a thing of the past as it instantly provides 60 mm of additional ground clearance at the front axle at the push of a button. Individualization of the brake calipers is quality-made with a temperature-resistant coating and ensures a perfect color match.
Needless to say that the new TECHART GTstreet R demonstrates its performance skills not only in terms of its visual appearance but also when it hits the road. TECHART boosts the performance of the engines of the 991/I and 991/II 911 Turbo and Turbo S models with a range of impressive powerkits, which generate a total power output of up to 471 kW (640 hp) and a maximum torque of 880 Nm. In addition a second stage of powerkits, unleashing a total of 530 kW (720 hp) will be available as of early 2017.
In combination with the 911 Turbos’ active all-wheel drive system, the driving performance of the GTstreet R reaches a new level.
Besides its stunning sound and appearance, the new TECHART high performance sport exhaust system features another highlight. TECHART introduces a continuously variable pneumatic valve control as a novelty in the new GTstreet R. The stepless valve adjustment optimizes the exhaust back pressure depending on different load conditions and avoids unwanted frequencies effectively.
Interior design:
Entering the new GTstreet R, the whole know-how and workmanship of TECHART’s interior manufactury reveals. TECHART created two different GTstreet R interior variants. The interior package »Exclusive« flatters with finest leather, the »Clubsport« version sets sport-focused Alcantara highlights. Among a wide range of refinement options included in both interior packages, the »Clubsport« interior includes a color-matched roll bar, 6 point harnesses and door opening loops.
Both interior versions come with door panel inserts and seats with GTstreet R design stitching. Dashboard, center console, roof liner, sun visors and door pillars are covered in leather or Alcantara. The mode switch at the steering wheel, the air vents, the air vent adjusters, the PDK gear selector, the gear lever surround and the seat adjustment are lacquered in custom color. As an option, TECHART carbon fiber interior parts complete the tailormade surrounding, such as trims, panels or seat backpanels in different visible carbon fiber finishes, to mention a few.
Settled in the sport or in the sport bucket seats, the ergonomic TECHART sport steering wheel awaits the driver. Coming with a smaller diameter, a straight-ahead marker, paddle back-covers as well as fully individualized in terms of colors and materials, no wishes remain unfulfilled. Color-matched instrument dials, door entry guards and aluminium sport pedals round off the unique interior design. As a sign of exclusiveness and originality, the glove compartment features a milled GTstreet R signet with a sequential number on its lid, and, inside the glove compartment, an exclusive handmade GTstreet R wallet contains the vehicle documents.
Old 12-14-2016, 04:40 PM
  #88
Yumcha's Avatar
  #89
Yumcha's Avatar
Old 12-15-2016, 08:26 AM
  #90
Received 5,293 Likes on 3,627 Posts
Colors are a bit too wild for me, but I like it.
Old 12-15-2016, 11:12 AM
  #91
Yumcha's Avatar
I agree...if it was a dark gray maybe to go with the black stripes?
Old 12-15-2016, 11:35 AM
  #92
Or even invert the colors & make the green the accent.
Old 05-19-2021, 09:43 AM
  #93
https://www.motorauthority.com/news/...-s-coming-soon
German tuner Techart has been spotted testing a prototype for a new generation of its GT Street R based on the 992 Porsche 911 Turbo S.Porsche's 911 Turbo and 911 Turbo S offer plenty of performance straight out of the box. Much more than the average buyer will ever need, in fact. Nevertheless, there are always those buyers that want more, and that's where companies like Techart step in.
Techart, located close to Porsche's hometown of Stuttgart, has been making Porsches go faster for more than three decades, and the company's GT Street R and more hardcore GT Street RS are the most widely recognized products in the portfolio.
The new GT Street R should debut soon, judging by the lack of camouflage gear on the prototype. The car features more aggressive fascias front and rear, plus a huge rear spoiler that makes the swan-neck design on the latest 911 GT3 look modest in comparison. You'll notice in some of the shots the wing has its own integrated wing that can be extended for extra downforce.
Techart has also added pumped fenders up front, which feature vents similar to the design used on the 991 911 GT3 RS. The extra-wide fenders have allowed Techart to fit wider wheels which can be seen to be wearing Michelin Pilot Sport Cup 2 tires measuring some 265 millimeters in width. The odd-looking wheel covers are there to improve aerodynamic properties.
It isn't clear what powertrain mods have been performed, but the new exhaust tips nestled within the carbon-fiber rear diffuser hint at some added power. Techart has a Stage 1 performance upgrade for the 911 Turbo S that lifts output by 60 hp and 74 lb-ft of torque, bringing the new totals to 700 hp and 664 lb-ft, but the GT Street R is expected to pack even more. Count on the hp figure reaching closer to 800 horses.
There aren't any shots of the interior, though we know from previous iterations of the GT Street R that Techart tends to offer upgrades such as roll cages and custom steering wheel and seat designs.
While Techart tends to focus on performance tuning, the company can also dial up the luxury of your Porsche. Case in point is the company's recent work on the Porsche Panamera Sport Turismo.
NiteQwill
09-15-2020 02:52 PM
06-10-2016 08:48 AM
05-10-2016 02:49 PM
11-11-2015 12:35 PM
Quick Reply: TechArt: GT Street (Based on Porsche 911 Turbo) News
