Viper Alarm Battery
Old 02-24-2005, 10:44 AM
OCD in the OC
ccarbajal08's Avatar
Viper Alarm Battery
Do you know anyone who can help me figure out how to program a replacement Viper car alarm remote? Thanks!
Old 02-24-2005, 11:04 AM
VP Electricity
elduderino's Avatar
Hehe... made my living doing that for too many years... but I don't know all the new ones.
You need to post the follwoing about the remote:
When you press the button, does the light come on green or red, pulsing or solid?
What numbers are on the back - both molded and paper label if any?
You may need to take the screw out and see the number on the IC.
If all else fails you will need to get the date code and model number off of the brain, but I think the above should let a current DEI installer ID that and tell you the RIGHT programming steps.
Old 02-24-2005, 11:05 AM
VP Electricity
elduderino's Avatar
OH, and make/model/year of the alarm helps lots if you know it...
Old 02-24-2005, 11:25 AM
I NEED MONEY!
VeeralS05's Avatar
if its the LCD viper alarm
- Press the button
- Press and hold the button till it chirps
- Press Lock..Unlock...Lock on the remote
Old 02-24-2005, 04:59 PM
Boom goes the Dynamite
I'm Batman's Avatar
We can help you if you know the model of the alarm.
Old 02-26-2005, 12:44 AM
East Coast Boost.!
Titand19's Avatar
i was curious also
i have a 791 and got an extra remote but did not program it yet
Old 02-26-2005, 07:10 PM
njtls's Avatar
ive got the 791 aswell and i dropped the remote one to many times?...is programing a new one as simple as holding and pressing buttons?
Old 03-01-2005, 01:32 PM
OCD in the OC
Here's more info if it helps.
Green. Fairly solid.
DEI
1-800-274-0200
RPN471T
2(66) Rolling Codes
FCC ID: EZSDEI471
Old 03-01-2005, 03:57 PM
VP Electricity
elduderino's Avatar
OK, word is that that remote was used with a ton of alarms of various models (sorry about that).
The various models program differently.
Checking to see if there's an easy way to determine this short of disassembly.
PM me your email so I can send you a manual if I get the right one...
Old 03-01-2005, 04:40 PM
VP Electricity
elduderino's Avatar
You can try the standard procedure:
door open,
key on,
press in-vehicle pushbutton (kow where that is?)and release,
then press in-vehicle pushbutton and hold,
and transmit. The difference is ch.1 can be for programming arm/disarm, arm only, or auto learn for automatically assigning all channels, depending on the unit.
Old 03-01-2005, 04:56 PM
OCD in the OC
where is the in-vehicle push button?
Old 03-01-2005, 05:42 PM
VP Electricity
elduderino's Avatar
It is usually mounted where it can be reached while sitting in the drivers seat. It's a small (2-3mm around) button, momentary push type.
It might be near your knees around the base of the steering column, or in the driver's kick panel (behind the hood release?), or above your shins in the black panel above the pedals. It might be in the center console pocket or the glove box, but not terribly likely.
The better it's hidden, the more secure your car is, so don't start hating if you don't find it right away - it means you probably have a better install.
Old 03-01-2005, 10:26 PM
I'm Batman's Avatar
Sometimes the installer doesn't put those in. He uses it during the install and then takes it back out. You might consider going back to the store that did the install for the programming.
Old 03-01-2005, 10:52 PM
VP Electricity
elduderino's Avatar
BTW, those installers are going to hell. We hated those guys on the phones.
It's also the emergency bypass switch (with the ignition key) in case the remote stops working.
Old 03-02-2005, 07:38 AM
I'm Batman's Avatar
Dude - Did you work at Vista?
Old 03-02-2005, 09:43 AM
VP Electricity
elduderino's Avatar
Why, yes, I did.
Old 03-02-2005, 09:51 AM
I'm Batman's Avatar
How long ago?
Old 03-02-2005, 09:55 AM
VP Electricity
elduderino's Avatar
91-95. Por que?
Old 03-02-2005, 09:57 AM
I'm Batman's Avatar
I am currently.
Old 03-02-2005, 10:08 AM
VP Electricity
elduderino's Avatar
Say hi to Eugene, Bryian, Wallace, Kenny, Jimmy J, Ken, Charlie, J.D., etc.
Send me a PM.
MetalGearTypeS
08-29-2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
10-13-2015 05:14 PM
Sue1910
2G CL Problems & Fixes
09-27-2015 12:34 PM
Quick Reply: Viper Alarm Battery
