CD changer gives error ER-E1
Old 07-13-2002, 08:19 AM
On the way!
fla-tls's Avatar
I tried to eject a CD last night, and it failed to eject. I ended up getting all but 1 or 2 of them out, but now, when you press the CD button it says CHEK for a few seconds, and then ER-E1 (which is not in the manual). There is no sound (i.e. electric motors moving, etc.)
Has anyone had this experience - and is there a quick way of getting those discs out?
Old 07-13-2002, 08:28 AM
Iggy's Avatar
If the disk door is open try taking another disk and gently push the edge of it under the stuck disk. This sometimes helps to nudge the stuck disk closer to the eject/load wheel. Also, many people have complained that using CDRs can cause problems because they are a little thicker than mass recorded disks. good luck.
Iggy
Old 07-13-2002, 08:44 AM
On the way!
fla-tls's Avatar
I went to go look. The loader door's not open, and when I flip it open I see what looks to be the tray/holder of the CD is on a wierd angle and not aligned with the door.
I have that bad feeling that my head unit is screwed...
Old 07-13-2002, 10:02 AM
eCo
Yeah, if multiple commercial disks are sticking on you, you should get the dealer to replace it. I've pulled stuck disks out with a hemostat without damage, tho. So you might try that as a temporary fix.
eCo
Old 07-13-2002, 11:57 AM
On the way!
fla-tls's Avatar
The wierd thing is that I can't see any disks at all. I'm thinking that the original CD I tried to eject only came partially out of whatever slot they put it in in the changer - and the thing that moves it up to the player got stuck.
Oh well - off to the dealer....
Old 01-22-2004, 05:43 PM
4th Gear
komodrc's Avatar
Angry ere1 fault code
I just go the same error code this weekend. THe CD changer was changing between CDs when all of a suddent it stopped and gave me the error code. I am taking it to the dealer but I am not sure why this has happened, AGAIN. You see, it also happened right after I bought my car last June
Old 01-22-2004, 07:01 PM
On the way!
fla-tls's Avatar
Old thread - but as I remember, you could see the mechanism that moves up and down to load CD's was on a weird angle.
They had to replace the head unit and mail the CDs back to me.
Old 01-28-2004, 10:22 AM
nyctl's Avatar
depends on how comfortable you are with electronics. do not try if you are squeamish
i took my radio out when nudging with another cd didn't work.
the front facia pops out easily
i unscrewed the top portion of the unit
to reveal the cd magazine.
i unhooked 2 tension springs on each side of the unit and was able to extricate each cd.
i replaced the springs and screws and was off to listening to my cds again.
i repeat
don't try this if you're not electronically inclined. i've been taking apart small electronics since i was 10 but i'm no expert : )
Old 01-29-2004, 01:38 PM
4th Gear
komodrc's Avatar
Thumbs up
Thanks for the advice, but i took it to the dealer. they replaced the whole unit. i bought some TDK audio cdrs and it seems to be ok. I also burned them at 4x speed
Old 09-05-2009, 06:50 PM
5th Gear
na350zTLS's Avatar
Whats up Im new but Having the same problem but my thing is that when i hit load or eject nothing happens.....Help some one
Old 04-29-2010, 02:00 AM
finalcross's Avatar
hey this is a old thread. but how much did it cost for the dealer to fix it?
Old 05-24-2010, 02:30 PM
7th Gear
NEALBENZ's Avatar
Just bought a 2002 tl and its doin the same thing, im thinking it would be more to go to dealer . Probably gonna go aftermarket
Old 05-31-2010, 04:17 PM
6th Gear
Lt06's Avatar
how much it cost taking it to the dealer?
Old 06-26-2010, 07:47 PM
thekidandyou's Avatar
i got the same issue also.. yet im thinking i might just have to buy another cd player... yet i want the same one to replace back in the car
Old 06-26-2010, 08:18 PM
I Drive Like A Dick 8≈
Nersh7's Avatar
HIT IT HARDER lol, mine does this all the time. With a swift bang to the side of it, it fixes the problem.
Temporarily
Old 06-26-2010, 08:23 PM
Dude i dont know to send u a cookie or what.. It is working now!!!!!!!!!!!!!!! Ugh im back to playing my cds again!!!!!!!!!!!!!!!!1
Old 09-28-2010, 01:37 PM
velvetlevel's Avatar
hey guys easy fix once the hitting stops working!!- disconnect the radio fuse and put the sterio "on" a couple of time so all the juice is out,then put the fuse back in-you will hear the cd changer checking for cds as normal,then put the code in and enjoy! did it this morning myself after mine got stuck in half open possition for a week.
Old 09-29-2010, 09:34 AM
SKACORE138's Avatar
Similar problem on my 2008 MDX
I am having a similar problem on my 2008 MDX Base model. I don't get any error codes, but about half the time, if I have a cd playing and hit another button to change to a different cd, the player will change to the new cd but then just say "DISK 2 BUSY". It will sometimes stay like that for several days. It won't let me change, load, or eject anything.
Any help would be greatly appreciated!
Old 10-03-2010, 09:31 PM
shezi01's Avatar
hey velvetlevel.
I had this error few times and i tried to use the fix you had mentioned. I took the fuse out and i tried to put the stereo on and it working and did this few times and then put the fuse back in and it never asked for the radio code.
Also i made a mistake thinking there was a relay for HU and took out no.8 on the driver side and now i have SRS and engine light on. Do i have to take it to the dealer and pay them $49.95 to reset it or is there a way i can reset by unplugging the battery. any help would be appreciate it.
Old 10-03-2010, 10:57 PM
Nersh7's Avatar
https://acurazine.com/forums/2g-cl-problems-fixes-70/how-reset-srs-light-742517/ try reading through that to fix the srs light.
Old 10-05-2010, 08:05 AM
shezi01's Avatar
Thanks that helped and also unplugged the battery and i think that also reset the engine light and the cd changer which was the original problem.
Old 12-02-2010, 02:12 PM
Sorry Shezi01,i don't know,,i'm not a regular guest on acura forum,tho had 2 TLs and this forum was a great help!!
Old 12-07-2010, 07:05 PM
texholdem's Avatar
Temporarily
Hitting worked for me, thanks a lot!
Old 01-04-2011, 09:31 PM
cheapo23's Avatar
im having the same problem how much is it to repair one of these things
Old 03-28-2011, 10:38 PM
bobike's Avatar
i will spank man player tomorrow too, will see if it works for me. thanks guys
Old 04-24-2011, 12:15 AM
200232TL's Avatar
I've had the same problem and still do. I haven't tried the fuse trick, but will, it seems good. What I do and most of the time after about 10 min. is keep hitting different CD number and track number buttons, along with the load and eject button, with out letting it get to the error message. Most of the time, after 10 min, it will glitch and start working again. The cd player will work normally usually unless you change the cd alot. Hope this helps and thanks for the advice about the fuse.
Old 04-24-2011, 12:53 AM
200232TL's Avatar
Question
Hey i tried this, but i forgot to turn it on to let the juice out. I don't know if that my problem, but now when I turn on the radio and use the cd player (I had one cd in there already) it says that all the Cd places are taken and then it displays: "CHEC", then "ER E1". What do I do?!?!
Old 06-16-2011, 12:35 PM
kqxqx's Avatar
I have exactly the same problem, even though I did let the joice out and then put the fuse back. I even disconnected the battery and still no luck.
Old 10-09-2011, 09:23 AM
4th Gear
kpaxson's Avatar
When I first had this problem, unplugging the battery worked, hitting it sometimes worked but now just "chek" er messages and shows all cd spots are full. I tried the fuse thing to no avail. What I am wondering is the comment about letting the juise out. I have taken the fuse out when the car is running (with radio on) and when the car is not running. How do you turn the radio on as the post says when the fuse is out? Anyway nothing worked. (door is not open). I wanna play my cds or at least get mine out. Help..
Old 10-09-2011, 05:20 PM
2_Late_I_Won's Avatar
mine was doing the same thing but my door wasn't opening. I quick jab/slap on the side jarred it loose. I then sprayed some electrical cleaner on the inside. It hasn't been a problem since
Old 10-10-2011, 11:35 AM
4th Gear
kpaxson's Avatar
The hit the side trick worked before but not now. Use to work to unplug the battery, no more. Fuse idea didn't work. Hitting all the cd numbers, forward, eject, load doesn't work. Not sure what to do now. Just buy aftermarket cd player I guess. I liked this 6 cd player in the dash instead of the changers in the trunk but it has been a problem for a year.
Old 12-05-2011, 08:29 AM
pgruhn's Avatar
I have the same code ... Hitting it is NOT working for me ... now on to the next method ... take it out and see what I can see
Old 12-06-2011, 10:48 AM
Racers'edge's Avatar
I've got the same trouble a couple of time, I bought an air spray can and clean (only pressure air) the unit, after that it work fine but not for long, this method worked two or three time until I decide not to feed my radio with nice cd, and then I change the unit...
Old 12-15-2011, 09:04 PM
Boulder's Avatar
Just bought my TL with the same error code. You know what that means. Time for an upgrade!!!
Old 12-29-2011, 12:15 PM
ptbguitarman's Avatar
Old thread, I know. I just replaced my stereo in my 03 TL. THEN realized the old unit was not bad. Don't do what I did, before you do anything know that Err1 will display after 10 (I think) failed security code entries. So, step 1 is to disconnect power to the radio by fuse or battery terminal, wait a few minutes and let it reset. When it comes back on it will ask for the security code which is entered using the preset keys. This code can be obtained from your dealer, just give them the stereo serial # and they will give you the code. To get the serial # hold preset buttons 1 and 6 then turn on the stereo. Disregard any alpha characters, put the two numbers together in order, and you have the serial #. Hope this helps others to avoid spending needless fliff on an unnecessary replacement stereo!
Old 04-19-2014, 12:32 PM
phillip2488's Avatar
Fixed...pull one of the battery terminal for 5 sec. Then put it back..onece key is turned u should here the radio resetting itself. But u have to know ur radio codes
Old 08-28-2016, 01:18 PM
Duongdang's Avatar
Thank you very much!
Temporarily
Thank you Nersh
Unbelievable! It really works.
Old 09-20-2016, 09:39 AM
thender's Avatar
I had the same issue with my '02 TL.
i left it alone for a few days, then tried to eject the CD's. Over the course of a week I got them all out.
had a local shop install a USASPEC iPod adapter, and now just use that.
it was a LOT cheaper than fixing/replacing the factory unit (I don't trust eBay used units) and much better functionality.
Just my $0.02.
-Ton in SoCal.
phillyguerrilla
09-26-2015 11:27 AM
Matthew Purpura
09-25-2015 06:10 PM
09-21-2015 08:44 AM
Big mo
4G TL Problems & Fixes
09-12-2015 07:22 AM
chrisr
5G TLX Problems & Fixes
08-31-2015 08:24 PM
Quick Reply: CD changer gives error ER-E1
