CL: Car won't start, one click noise on each key turn - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 08-26-2010, 11:58 AM   #1
Registered Member
When I turn the key on my 1997 2.2 CL (125k miles) I hear one click but the car won't start. Eventually, after 5 or 6 tries it starts beautifully.
I had the battery checked, it is good, (it is only 14 months old), recharges well. After taking the battery out for the check and putting it back in, the car started immediately and ran ok for about one month when the problem started again.
I cleaned the battery posts, although they did not seem corroded, it does not seem to make a difference. However, coincidence or not, moving the clamp/cables seems to sometimes get the car going on the second try.
Questions: how much should a garage check cost to isolate the problem? How much should it cost to replace the battery/starter cables or cut/fix/re-connect their ends if they are corroded? How much should it cost to replace the starter?
marcov is offline   Reply With Quote
Old 08-26-2010, 12:05 PM   #2
Registered Member
PS. What could be the problem? Why is it that (so far) it always starts nicely after several (5-6) tries but not on the first try. Could it eventually die completely on me and not start even after many tries?
Old 08-26-2010, 02:14 PM   #3
Registered Member
my guess is pgmfi relay or starter
fourthmeal is offline   Reply With Quote
Old 08-26-2010, 03:10 PM   #4
New Member
I just had this problem with my 97 3.0. We replaced the battery and that did nothing to change it. We tried jump starting it and that didnt work as well, except for once it did oddly enough. But i went to the auto parts store and got a new starter for it for 100 bucks; removed the battery and cables, took out the old one and put in the new one and it completely fixed my problem. I hope your fix is just as easy, but all your problems seem the same as mine.
clcurtis is offline   Reply With Quote
Old 08-26-2010, 03:24 PM   #5
Registered Member
I just played again with the battery cables, twisting and tightening them, pulling them around and the car now starts on first or second try, at least today. I'll see how it starts tomorrow. The cables are soldered solidly to the clamps and the battery posts are sparkling clean. Yet it seems as if there is a weak contact somewhere...
Old 08-26-2010, 05:21 PM   #6
Registered Member
on1wheel01's Avatar
If it does it again could be the starter. Mine does it once in a blue moon. I tap the starter with a hammer lightly then harder if she wants to be a bioch. I dunno why I do it cuz I have another starter waiting in the garage to be put on lol.
on1wheel01 is offline   Reply With Quote
Old 08-27-2010, 08:28 AM   #7
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Sounds like the starter, the 1 click you are hearing is the relay engaging. Also could be the wiring is f'd up or freyed since you had success moving the wires around
97BlackAckCL is offline   Reply With Quote
Old 06-19-2012, 02:42 PM   #8
New Member
Happens with my 99 3.0cl. You need knew battery cables. That will fix the problem.
waterballoon41 is offline   Reply With Quote
Old 06-19-2012, 07:16 PM   #9
New Member
starter is bad.
tjallenjr is offline   Reply With Quote
Old 07-25-2012, 04:37 AM   #10
New Member
befor changing you starter, check the fuse box,,and specaly your ECU fuse( check the fuse box diagram ,15 A),,,maybe you have to replaced.
loyal is offline   Reply With Quote
Old 09-14-2012, 06:41 PM   #11
Registered Member
Just had the same problem with my 00 TL. I could tap the starter and it would normally it would crank after that. Replaced starter and everything OK. Most likely it was just the solenoid but replaced entire starter; $500 at dealer.
youraway is offline   Reply With Quote
Old 09-17-2012, 03:06 PM   #12
Registered Member
on1wheel01's Avatar
Dayum gb noobs bumping a 2 year old thread
Thread Thread Starter Forum Replies Last Post
Picked up 2007 rl last year, having a few minor issues tman570 2G RL Audio, Bluetooth, Electronics & Navigation 9 12-17-2015 09:20 AM
OEM Battery Failed Me gemz_acura 4G TL Problems & Fixes 15 09-26-2015 06:12 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 04:40 PM
Battery might be dead or not. jordanboi Second Generation TSX Discussion (2009-2014) 16 09-05-2015 01:33 AM
September 13th Sunday - Touge.ca Cayuga TMP track event 5-9pm! #18 of 20+ Events Mugen TSX Eastern Canada 0 09-01-2015 11:05 PM
Tags
97, acura, car, cl, click, clicker, intermittent, key, makes, noise, sounds, start, tl, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
