XM Signal Dropping Out More Frequently
Old 09-26-2015, 09:52 AM
4th Gear
us285126's Avatar
My car is a 2005 Aucra TL with Navi.
Lately my XM signal seems to drop out more frequently. There have always been spots on my commute where I temporarily lose signal, but it seems like there are more of them lately. Could this be a symptom of an antenna problem? Is there a replacement antenna that is "stronger?"
Old 09-26-2015, 10:05 AM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
I just had the XM receiver in my daughter's 09 Accord replaced. There is a TSB for XM receivers that cut out and come back to display the artist / channel etc, but no sound. If you cycle the ignition the sound works. Not sure if you fall into those symptoms or not. Also not sure if you car / vin fall into the specified range. Off the top of my head the TSB is 10-024 (if memory serves).
Old 09-26-2015, 10:10 AM
4th Gear
us285126's Avatar
Thanks for the info. Do you have any details on how to find the TSB and determine if this might be my issue?
Old 09-26-2015, 11:08 AM
NBP04TL4ME's Avatar
You can Google it but I quickly found it here - TSB 10-024 No XM Sound, But XM Station Information Is Displayed (2009 only) - Honda Ridgeline Owners Club Forums. There is a PDF attached.........
Old 10-02-2015, 11:56 AM
JakeS's Avatar
My signal is usually fine, the issue I have seen is when changing to another station the sound will work but no artist info and etc come in.
Old 10-02-2015, 01:32 PM
NBP04TL4ME's Avatar
Print out a copy of that TSB and/or search to see if there is a similar one for your Acura and call and talk to your dealer to see what they say. What you are describing is similar but different than what is covered in the TSB, but they might be able to provide some empirical data - "yeah, we see that all the time" or "nope, that's a new one." Guessing you are out of warranty unless you have an very long extended warranty still in place, but you may wind up tackling this on your own, if it's that bothersome for you. I would much rather be able to hear the music and not see the music info than vice versa. Let us know how you make out.
Old 10-02-2015, 01:34 PM
JakeS's Avatar
I know I am out of warranty but worth a shot to see what dealer says.
But yeah I rather hear sound and not the info then the other way around.
Old 10-02-2015, 01:41 PM
NBP04TL4ME's Avatar
Always worth a shot..................
I don't know what the XM receiver cost as it was all done under warranty, but it did fix the issue in my daughter's car. As an FYI, I had to call XM to get the new radio ID switched over. Apparently each receiver has it's own unique ID and it has nothing to do with the car or the radio head unit. XM was going to charge me $15.00 to do this and I refused, but the CSR got an okay from her supervisor to waive the fee after I pointed out it was a defective XM part.
Old 10-02-2015, 01:47 PM
JakeS's Avatar
It's easy to get XM to waive fees haha. I am not even sure who is paying for mine right now. It's not on my account but it keeps working.
If its the receiver is the problem I will probably just leave it till it breaks then do the fix the info isn't that big of a deal and it works 75% of the time.
Old 10-02-2015, 02:03 PM
NBP04TL4ME's Avatar
emailnatec
29
09-28-2018 04:27 PM
MetalGearTypeS
08-29-2016 08:28 PM
rhdune16
09-28-2015 11:31 AM
h22lude
09-27-2015 06:22 PM
4drviper
09-23-2015 07:42 PM
Quick Reply: XM Signal Dropping Out More Frequently
