Pls Help Activate Radio After Battery Replacement - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Audio, Bluetooth, Electronics & Navigation
Log In
LinkBack Thread Tools Search this Thread
Old 08-01-2011, 05:04 PM   #1
Registered Member
Trader Rating: (0)
Please help...my car is 06 6spd NAVI. After replacing the battery, the factory radio/navi unit prompted to enter the code, but did not specify which one. It seems that the radio has a separate Key Code from Navi......I have entered Navi code and the navi started working, however radio is dead. I had restarted the car but the code prompt never came back on again. What do I do?
__________________
2006 WDP/Ebony TL NAVI 6spd
former ride: 2000 Nissan Maxima GXE 5spd
Kostyan is offline   Reply With Quote
Old 08-01-2011, 05:18 PM   #2
Registered Member
garrett's Avatar
Trader Rating: (0)
look in the book that came with your car there should be a buisness sized card with the radio code on it.
if not you can goto the link below for the code.
https://radio-navicode.acura.com/
garrett is offline   Reply With Quote
Old 08-01-2011, 07:34 PM   #3
Registered Member
Trader Rating: (0)
my original question was misunderstood. The radio/navi unit did not prompt me to enter the code for the radio, not that I do not have the code.
I was prompted to enter the code, and the screen did not contain info which code needs to be entered. I'd entered NAVI code but how do I enter the radio code from here..when I turn the ignition on, there is no longer a prompt to enter a code....
__________________
Old 08-01-2011, 07:35 PM   #4
2004 Acura TL
wilzrsx's Avatar
Trader Rating: (7)
you enter the radio code by using the 1-6 keys on the radio itself. if you go to turn on the radio, it'll say CODE on the display
__________________
2004 TL AM 5AT Navi | A-Spec Lip Kit w/ Decklid | A-Spec Wheels w/ 15mm Adaptec Spacers | A-Spec MT Suspension | SH-AWD TL IM | PnP Intake Runners | ZDX TB | Outlaw/P2R IM Spacer | Airaid 4" Intake | UR Crank Pulley | 3G TL-S Precats | ATLP V2-R J-Pipe | CT-E RSB | JnC Headlights w/ Osram CBI and VLEDS 5k V3 Triton Switchbacks | OEM TL-S Tail Lights | RDX Caliper Covers |
wilzrsx is offline   Reply With Quote
Old 08-01-2011, 07:57 PM   #5
Registered Member
Trader Rating: (0)
wilsrx, I turn on the ignition, push the radio button, and there is nothing on display, really. The top display (the clock one) says CO.
__________________
Old 08-01-2011, 08:18 PM   #6
2004 Acura TL
wilzrsx's Avatar
Trader Rating: (7)
try to enter in your radio code when you see that
__________________
Old 08-11-2011, 06:11 PM   #7
New Member
Trader Rating: (0)
Thanks for the info.
I tried that, but it seems I entered it wrongly, now I don't know how to recover from it. Whenever I hit the power button, it complaints about CODE ERROR! do you know how to come out from that situation?
Thanks again,
irustemp is offline   Reply With Quote
Old 08-11-2011, 07:24 PM   #8
Registered Member
cinobyte's Avatar
Trader Rating: (0)
Always can call Acura they helped me with my other car and they were very helpful. I had lost my radio code
cinobyte is offline   Reply With Quote
Old 08-11-2011, 07:49 PM   #9
Coolest A-zine Member
Trunk Monkey's Avatar
Trader Rating: (1)
It's either:
1. In your owners manual on a business card, etc.
2. On the glovbox (inside, outside parts when you open it)
IF NONE OF THESE...
Call Acura
It's not prompting you b/c it's not supposed to for the radio code. I'm sure someone will chime in here shortly but I think the radio code is 5 digits and the Nav. code is 4. Could be the other way around though. You'll get it...
__________________
'13 Accord Sport (black)
(SOLD)
'04 Acura TL
--JBL MS-8/12" IDmax-Audison SR1dk
/Image Dynamics CXS62v2-ID Q450.4/SDS
Trunk Monkey is offline   Reply With Quote
Old 11-05-2011, 12:44 PM   #10
5.0h So SLOW
JayVee's Avatar
Trader Rating: (21)
if its saying "CO" is because u need to push 2 more # keys from the 1-6 as mentioned above from the memory kets...Do not push more then that, its only so u can continue to spell CODE. Seems to be stuck at only 2 charaters "CO". Once u have the full word CODE...Make your further attempt to entering the code on the business card as mentioned above also. Good Luck... *I just did this myself this morning after picking up my car from the shop last night *
correction... its on a decal sticker card with other ID # and CODES. It was the very first one listed as SERIAL ANTI-THEFT CODE#... But then again, mine has no NAVI. But hope this guides you and others in the right direction to DIY
__________________
(White) 2012 Mustang GT 5.0 Coyote: "1 White Horse & 2 Snails... Try to keep up"
JayVee is offline   Reply With Quote
Old 11-06-2011, 01:14 AM   #11
Registered Member
Trader Rating: (0)
you gotta hold the 1 and 6 on the radio (not navi) at the same time and tap the on/off radio. it will give you a serial number which you can either call acura or the stealership and they will give you the code for free.
TL_PILOT is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
OEM Battery Failed Me gemz_acura Problems & Fixes 15 09-26-2015 07:12 PM
Rental Review: 2016 Hyundai Sonata Hybrid PortlandRL Car Talk 2 09-14-2015 01:01 PM
'06 Navigation Flickering & Radio not working Ol'Dave Problems & Fixes 0 09-08-2015 04:38 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
Tags
2000, 2004, activating, acura, battery, change, code, key, mdx, radio, replacement, started, swap, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
