How to remove the bluetooth from 2007 TL ?
My 2007 TL-S's battery dies very frequently. I heard one of the reasons is the bluetooth always searching and it use up a lot of energy from the car so draining its battery. Can someone show me how to manually take out the bluetooth device? I heard it is located in the dome. Thank you.
awissing (08-04-2016)
Auto dim inop after HFL disconnected...
[QUOTE=thoiboi;15566720]https://www.google.com/search?q=site...sm=93&ie=UTF-8[/QUOTE. Auto dim inop after HFL disconnected...Just wondering if I did something wrong or they just run thru the same connector?
Sorry to have confused you--I sort of hi-jacked the thread. My battery is the original, so it is now 5 years old. And 12.3V is not an acceptable charging voltage. Isn't the voltage regulator built into the alternator?
You didn't just sort of, you completely did it.. The thread had nothing to do with your issue nor is it even the same generation car ..
Get a new battery and be done with it
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
