Help on DVD, Headrest and Navtool installation !
Well thats my plan for this summer but before i buy everything i want to be sure im getting the correct things.
Navtool:
PIE X3
1/2 DIN Mobile Multimedia DVD/CD Player
And now the problem: I dont know where to find some headrest, "Taupe" color or 2 screen 7" and i can try to cut.
My interior color:
Do i need to put some switch for the dvd?
Please tell me if im missed something and help me out find some good headrest Thanx
Navtool:
PIE X3
My interior color:
NavTool, check. Good unit. You will need to run the switch into the cabin somewhere. This will switch between normal vid screen and aux input on the NavTool.
PIE X3, check. I have to install mine, but I did one for another member. You will have to tear down the dash a bit to install it. Switch options are the lower cubby hole in the center console, glove compartment under armrest, or cutting a hole in the dash--I would use the plastic panel under the steering wheel.
You didn't mention brand of DVD or where you wanted to mount it. Some have used the rear seat armrest, others have used the large cubby hole in the center dash. The latter location requires some significant cutting, fyi.
As for the headrests, the cleanest would be to cut out holes in the existing ones and mounting the screens in them. Requires a ton of balls, but good results can be obtained with patience and attention to detail. If you want to go aftermarket, try visiting some car audio shops to see what models they have that match your color the closest. Get the make/model, go online for the cheapest price and then see if the local shop will beat it!
do i have to purchase the full kit of the pie x3 like this: PIE X3 + X3-CHRY04 Triple Input Auxiliary Aux Audio Interface & 3.5mm RCA Cable or only the pie x3?
i already purchased the navtool from ebay
Is the
Myron and Davis by Johnson Safety Inc AD212 3/4 DIN In-Dash Car DVD / MP3 Player
a good dvd? i mean it read every dvd format? anyone has experience with this dvd?
Is the
Hey bro can u post it where i can find it? please
Also does any of u has a ny experience with the Myron and Davis by Johnson Safety Inc AD212 3/4 DIN In-Dash Car DVD / MP3 Player?
i dint find anything...check your PM please.
I got mine from SonicElectronix.com. It seems they are out of stock on the vehicle harness. You want the X3-HON03 harness.
A quick Google search found this:
http://www.logjamelectronics.com/piex3auxconv.html
Search is your friend.
BANNED
BoricuaTL
04-08-2016 01:08 PM
